- DYNO Results for my SC400
- For those with Gauges(boost) i have a question regarding Vacuem Line Running
- Help!! Bad gass maybe??My car stalls everytime I stop
- 1UZ-FE V8 Air Forced Induction?
- 3sgte swap
- 1uz-fe swap?
- Gas Leak Mystery
- ct12a internals
- engine response
- Name that part
- What does the orange light means
- Hallman Boost Controller opinions?
- Tuning a 1j??
- budget fuel management
- Update Update On 1jz Swap...
- 1JZ Engine vs 2Jz Tranny
- fastech motorsport sc 1.5jz build
- Where do these parts go?? Electrical Connector & Vacuum Line (PICS INSIDE)
- 1jz Map sensor location
- Central Fla. help
- Should I get the INJEN SHORT RAM INTAKE?
- Need EXPERT advice!!! (pics)
- MASS air sensor
- Will LMS CA Intake fit on SC3?
- does anyone know of any dyno in the las vegas area
- Custom FMIC piping pics?
- 1JZGTE / 2JZGTE motors
- SC400 Air Conditioning Removal
- 4 row FMIC on SC300?
- obd1 1jz swap in 96+ sc300??
- Turbo in a SC400 Auto? Possible?
- ic hole
- Fastest SC?
- valve cover gaskets
- Timing belt/tensioner.
- What is the best aftermarket intake for SC400's
- Anyone Have The Cabin Kickpanel Connector Pinout Diagram?
- 1JZGTE MPG Q's
- SC400 transmission mount replaced. (seperated)
- engine dies after intake work
- another day..a step closer to 1jz swap..fixed last problem..NEW PROBLEMS
- mkIV pedals
- Clicking noise
- 2JZ-GTE VVTI in my 98 SC300
- Which shifter?
- Stroked SC300 progress
- getting closer to starting the 1jz..another weird problem
- what is the difference.....?
- Boost guage installation
- oil on plugs
- New to me, maybe not to you (ps pump 1jz)
- JDM Spec coolant hoses fit US Spec?
- Transmission Trouble on Lexus SC300, Please Help
- A/C Compressor Interchangability
- SC300 -> 2JZ-GTE
- Anybody passed emission with JDM motor?
- EGR Code 71 Check Engine Light Question.. Help needed
- Cleaning the engine head/pistons/etc.
- Want to do Compression Test...Where is Fuel Pump Fuse?
- Is this a rip off on ebay ?
- Bleeding clutch line?
- stupid 1JZ question (tranny related)
- Stuck Thermometer>>>Overheating>>>Blown HG?
- White Smoke= Bad. Whats the Prescription?
- those who kept 1jz auto tranny, problem mating driveshaft?
- Why no BFI?
- SC400 dyno results with nitrous
- Automatic to manual conversion?
- 1JZGTE automatic ( JZZ30 ) ECU pinout diagram?
- Supra Swap\
- Considering 1JZ Swap
- hp capability?
- Are these the front cats?
- jzgte temp and tach fix
- 1JZ representing !!!
- Shifter Bushings
- started 1jz swap..came across something..ALTERNATOR PLUG
- nitrous on a 1jz
- Headers
- Anyone have Chaser 1JZ wiring diagrams?
- Lets talk "rears"
- 1995 Supra NA motor into SC300 ?
- NA-T numbers in... 630rwhp at only 25psi
- need help bad (electrical issue)
- power steering leaking from boot
- Is anyone running NOS?
- a/c problems...help wanted plz.
- Auto transmision overdrive
- Cup holder makes a good guage pod
- anyone use the powerhouse manifold?
- manual conversion Q
- Smooth Muffler? advice needed
- Please Help! Clutch Broke?!?
- resetting ECU on ge motor
- spark plugs
- Sc400 - Rpm @ 70 Mph?
- anyone heard of these people?
- Transmission Problem? Need some advice...
- Open Downpipe 1jZ
- Should I get the MSD 6A?
- Finally making some headway...
- Tuning Shop In South FLA?
- Tach adaptor for 5spd??
- What is so great about the SC300?
- 2jz-gte swap SC400 Project
- 2jz wiring
- Is it hard to change timing belt?!?
- I did it! I solved my SC400's grinding problem.
- Replacing Soarer ceramic tubos with Starlet steel ones.
- stock 5spd tranny w/ 1jz?
- help putting up video of my new exhaust set up
- Exhaust
- Boost Logic?
- '97 sc300 issue at a stop or in park
- custom single exhuast, going 1J and what to expect
- Header or is there another way...
- CE light popped on the way to work
- Power Steering???
- where to get arp head studs?
- Finding A/C leak?
- So who makes headers now?
- single turbo 1jz roll call
- Non-turbo Supras' application of turbo timer harness
- Transmission HP Capacity?
- what exhaust ????
- header install questions on sc400..
- Definately a repost...BUT
- Leaking Antifreeze when turned off
- Blitz Nur Spec exhaust fitment
- Handling question
- Apexi Ws2
- Car occasionally taking time to change from Park to Drive/Reverse
- Clutch/PP question on 6 speed SCs
- Pass emissions with 1 cat?
- Help here please
- Question about interior wiring diffrences between SC300 & SC400
- sc 300 engine swap
- Can someone help identify this part??
- LSDs?
- transmission fluid change on 93 sc 400
- Muffler
- Oil usage?
- vvti Question?
- update on my 1jz....
- Need help with Alternator issues on a GTE Swap!
- Turbo Timer with swap?
- 2JZ-GTE torque specs...
- Bolt On Mods
- 2JZ-GTE Swap Questions
- Putting a JDM2jz?
- more carbing bling
- check engine ligh, whats the cause for yours
- relay, ecu for 1992 lexus sc
- 1j power?
- Replacment for stock twins??
- SC300 engine idles strange
- 1jz help PLEASE HELP!!
- Cannot find Valve Covers
- Twin Turbo Headers (DIY)
- grounding kit for trunk mounted battery
- Soarer swap options with '96 and up SC300's?
- ecu's
- Help!!!
- vpc maf problem?
- using is300 maf on SC300
- no injector pulse no spark on 1j help please
- anyone know where to get a overhaul kit?
- 2JZ-GTE oil pan
- Starter change on SC300
- Going Single on the 1JZ
- Well the twins went! :(
- walbro gss341 or gss342
- Pic under valve covers after 100k
- Drier
- 1JZ radiator swap worth it?
- whats the slip?
- NA Auto => TT auto
- strange missfire, hesitation
- Auto shift knob part#???
- Power Steering resevoir??
- 1jz turbo/compressor maps
- CA emissions vs. non-CA emissions what's the difference?
- Can someone with a 1JZ PLEASE tell me where these two connectors go?! (Pics inside)
- What sensor is this?
- trac light
- Replacing Alternator and Leaky Power Steering?
- grounding kit
- R154 Driveshaft.
- Which Car?
- Finally bit the bullet....
- Look what i found
- Increase in gas mileage.
- JDM Toyota Soarer - Motor Options?
- tranny problem?
- Good 3in Muffler?
- 2JZGE-A340E to R154 swap for sc3
- sc 400
- 1995 SC400 Engine Light & Trac Light On
- Does anyone have the tech specs for airflow, etc.. off a scanner?
- stock BOV's suck!
- think i got ripped off?
- Auto Trans problem, need help !
- Passing emissions with 1jz
- 5-Speed SC400
- 1jz sc starts up but dies when throttle is pushed
- overheating.. replaced everything except the HG
- need help obd2 to obd1 conversion
- exhaust help
- Blown Motor, Need Advice...
- 1jz q
- AC not working right
- Supra TT clutch fit SC300?
- Need help where to find best price for trd lsd!!!
- '93 SC400 Starting Problem
- 1jz acting wierd :(
- spec stage2 clutch and aluminum fly
- High cold-start idle, normal warm idle, rich/gas smell
- 2jzgte and 1jzgte stock swap cost in ca?
- need help with final drive!
- what kind of power should i get???
- BFI long term use
- geting auto trany to support 400hp mark
- What are my options for upgrading injectors
- Big Problem Soarer Swap help....
- 10k mile update 1JZ swap
- soarer harness q..
- Could I use these on a BFI???
- Not an LSD, right?
- looking coolant after cold snow storm
- Please help with easy question... 1JZ wiring
- White smoke out of exhaust, not what you think
- eledtrical ?
- Trans swap
- Prof Catback installed
- A/C is down:(
- opened up fuel pump ecu
- 5-speed swap driveshaft W58??
- 1997 SC300 Air Intake
- What to do about the 1 jz fule cut?
- After-Market Performance Parts
- Transmission question
- setting the tps
- Head bolt thread / pitch
- how to aftermarket tach ?with 1j
- looking for stock 1jz-gtte 'manifolds'
- 1jz auto tranny on a 2jzge?
- RMM exhaust on SC300
- New Magnaflow mufflers
- Greddy boost cut controller?
