- CEL Trouble codes
- 5-speed auto??
- brakes or exhaust?
- New SC300 project underway....
- The SC300 is coming along.....
- Should I NA-T for free?
- Problem starting my SC300
- blinking OD off light
- Need Help removing TB on the GE engine
- Lextreme supercharger
- Polished Turbo Pics
- SC300 S-AFC II Question
- LSD better in rain and snow?
- SC300 / 1JZ 5 Speed not running
- Should I Spray???
- NA-T cam timing Q
- Help! 1JZ Wiring ECU
- Full exhaust: 2.5" vs. 2.25" w/ X-Pipe
- Auto SC300 stock ECU chip?
- Fan Clutch
- Something interesting I thought about 2jz-ge, 1jz-ge??
- Acquiring interest in Boost Logic Turbo Kit
- 1992 SC400: Changing lower oil pan
- over drive problem!
- 4in Single Exhaust Pics
- Compatible? ecu's (AUTOMATIC)
- Is300 clutch
- gs300 clutch
- Very Vocal past 4000 rpms
- Car Suddenly Dies....Won't Restart
- lean air mixture
- 1JZ vacum line routing
- 1st to 2nd shift
- Clutch for a 93 SC300
- Does anyone have the GReddy oil filter relocation kit? Or even the HKS?
- powdercoating the 1jzgte
- 93 SC 300 P/S Fluid Dex III ok?
- clutch help
- Just quick dashboard light question
- Sc Stock Exhaust Question??
- JDM refrigerant type?
- TT 1UZ Rebuild
- ARP Head Studs
- Is the 97 SC400 PSteering pump prone to leaking?Is 97 pump better design?
- Clutch kit recommendations?
- How do you tune your car? Vote now.
- Vents for relieving under hood heat
- Is the 97SC400 prone to PSteering pump leaks ? My 93 did, is 97 a better design?
- 94 sc300 short shifter
- Downpipe advice please.
- Sc300 Xerd Header install-56k not so happy
- auto shift knobs....got one?
- evap canister removal
- These repair costs seem very high....
- 1996 Na-T engine management?
- 1JZ-GTE Swap
- 2zjgte quick question
- turbo manifold off older supra
- 1jz swap....slight vibration
- Removed Intake Snorkel
- oh snap!
- Follow up to Fireless Smoke Yesterday
- Front Mount IC Sizes
- mid-low 14s with SC3 Manual
- Will it ever stop?!?!?
- Tranny Thump
- 6 speed bolt up to the 1JZ???
- What's the cheapest NA-T conversion out there?
- rough throughout the rpm's- please help!!
- Help me with this clutch noise...
- Sc300 Motor Mounts
- Bad Injector?
- Transmission Failure?
- 2JZGTE JDM Wiring help for SC300
- Fireless Smoke!!
- cheap turbo kit?
- Electric Fan reccomendation? (cfm)
- Sc300 5-speed Vs. Is300 5-speed
- Exhaust tips?
- Spark plugs, post your experiences.
- How to Remove Crankshaft Bolt
- Turbo IQ Test
- Idling at 1250
- Heater control valve
- 1jz transmition ?'s
- PCV hose broke..
- What causes the engine to just die???
- California Smog Laws for Engines?
- SC400 sounds like electric sewing machine!
- Yet another transplanted 2JZ-GTE (so stock)
- Turbo guys only, pix of exhuast beneath the SC
- PWR button problem 93 SC4
- Just got a 93 SC4, and some questions.
- Quick question about clutch
- 1jz head swap ??
- Idle problem after flywheel install.
- Pics of Exhaust Tips?
- please iluminate me (1jz two question)
- 1.5 jz
- Exhaust piping
- New Intake!
- pre-requisites for vvt-i or non vvt-i gte swap
- 93 SC400 Transmission interchangeable?
- Help! Power Steering and Alt issues!
- 2jz-GE 2002 VVT-i shortblock mating on 92 2jz-GE non-VVT-i shortblock
- Is this true about the 2jz bottom end?
- Loose Valve Covers Causing Oil/Coolant Leaks?
- GTE owners, post your FMIC set-up
- Best sounding exhaust?
- spacer for timing belt cover
- intake manifold
- Made my decision.
- distributerless
- Question about SC tranny !!!!
- spark plugs
- maybe a problem!
- Power steering?
- Need some help on the w58 swap for sc300 1992
- 1jzgtte or 2jzgtte
- Thanks to Phil
- anyone????? ( crankshaft pully is left or right hand thread ?)
- Alternator question
- Interesting response from xerd dealer
- What the HELL are these fleabay auctions about?!
- 8920 tach adapter
- Rebuilt starter on '93 SC300???
- A few transmission problems
- 1UZ-FE to 2JZ-GTTE
- Nos
- Greddy Emanage Ultimate Wire Diagram
- 1JZ TRD Turbo Upgrade?
- Heres a new problem
- NX wet nitrous kit install TPS wire
- What are my options for a 98 SC300 AT without internal mod?
- performance enhancing chips
- help! everything electrical is dead (1jz swap)
- Thermostat question...
- Alternator/Steering pump issue/s
- Stock turbos on 1jzgte
- Exhaust Manifold Gasket
- Question about the Oil Light
- better MPG sc300 or sc400?
- Coming Soon?
- Skyrocketing price of xerd headers.
- 6 blown clutches in 6 months!!!!! help me god
- SC4 Tranny questions
- twin K26 v's GT35?
- mohdparts egr removal kit.
- 2jz-ge engine..........
- 1jzgte with 2jzgte intake?
- Universal Oval Style Canister mufflers
- Anyone ever heard of XSS mufflers?
- 1jzgte
- Airbox cover?
- difference in stock LSD's
- Which stock LSD to get?
- Inno Moto Turbo kit.
- Please help! Power door keep turning on
- TRD LSD SC300 noise & other stuff
- A 97+ US spec 2jz in to a 92-94 body?
- Exhaust + intake mods for 1999 SC400 **HELP**
- What mod should I do?
- AEM standalone with 1JZ
- New SC300 owner - psp pump seal ?
- Shifter Thread Pitch
- clutch recomendations ?
- stock 1jz pipes
- 7m and 1/2j
- lexus sc400 headlights
- Anyone tried/know about the new SSautochrome parts?
- Video of my RMM exhaust on SC400
- AEM/Haltech and others Tuning Session with Justin Nenni in so cal
- 5 speed swap info???
- Drifting
- Please HELP!! 1998-up SC400 Power Steering Pump Question
- One Messed Up Day (Plz Help)
- Rebuilding the 1UZ-FE to 5.0L
- Battery symbol light
- Hey Everyone
- Cheap turbo setup...so i was thinking.
- Exhaust shops?
- nothing to do with SC's, but nice still...
- Darn timing belt looks worn
- VersaTrans ATF?
- intake....
- A little help with exhaust
- Cat is toast...
- help with cold start
- Chirping sound. Pulley question
- I've got lots of issues with my 1JZ I can't solve - ECU, fuel, a/f, etc
- Does anybody have this setup? It's similar to the1.5jz setup
- Super Charging Sc400!!!!!
- How well do stock mufflers flow?
- New plan on 2jzge and 5spd swap!
- SC300 / SC400 Radiator
- How do I make the 92~97 SC model's Shift to the 99~00 style.
- ? will tt supra cat. conv. fit on sc300??
- Anyone know where to buy resonators?
- A/C died?
- Help! Suddenly have no power (miss?) and smoke from under back of SC400 engine!
- New Dyno numbers for the SC300!
- VPC Dip Switches Ques.
- intake on 98?
- KOYO radiator?
- wiring diagrams
- electrical nightmare
- soarer 2.5 tt auto on sc400?
- stupid problem? VOLTAGE WOES
- How many miles on your alternator?
- Quick questions b4 I buy a 1jz
- knocking
- Say I do a W58 5spd swap..
- fuel pump woes
- Power Steering Pump Brand
- My SC is Buggin' me ....Hard!!
- What part is this???
- Problem with throttle body
- got my RMM exhaust! *PICS*
- Engine Miss, come and go 1992 SC300
- SC300 w/manual????!!!!!
- Timing belt advice
- Vehicle Speed Sensor
- I think I need a new oil pan
- Distributor Cap Removal?
- ATTN: Boosted SCs. Firewall and running wires through.
- Finally got my exhaust installed.
- Looks like we may have lost another SC400...
- Finally secured my turbo Lexus...
- OK...so changin the alternator on SC300
- All you AEM Guys
- Shifting into Drive (quick question)
- OBDI tuning questions
- which tach adaptor to use??
- Some pics from my swap.
- RANT ..... No more customer service :(
- heather servo
- New Exhaust Single Exit **pics**
- nice exhaust on ebay
- So how do you know if your A/C Compressor took a crap??
- Just bought a SC300 to na-t or not?
- underpowered?
- vacuum line to boost gauge in glove box
- Help! Help! turbo does not fit. pics
- JIC exhaust
- Torque Converter Upgrade
- 1JZ Spooling Problem
- Distributor O-ring Replacement Write Up
- cobbled together exhaust
- street dynamics NA-T
- Question for the SC400 Owners. Car only running on 4 cylinders
