Driftmotion.com sc400 power steering hose
Old Jan 15, 2011 | 10:58 AM
WDoherty's Avatar
WDoherty
Default Driftmotion.com sc400 power steering hose
Anyone installed on an sc400? I read on here that the line is long, crush washer are too big for the sc300 and if it is the same type of fittings on the sc400 hose, I don't see how pump connection (90 degree vs. oem banjo bolt) would clear the firewall on a 400.
I live in remote Southwest Texas and the closest hydraulic shop is 2 hours away and my car is already down for maintenance. They said I could mail it, but I'm not sure they would get it all correct. Tried to reach a hydraulic shop referenced on Cl near Ft. Worth, but it seems they have closed.
http://store.driftmotion.com/static/i-sc400psline.php
Old Jan 15, 2011 | 05:51 PM
RawkusX187's Avatar
RawkusX187
Got it myself...nothing really has to be change just swap lines and good to go. I havent had a leak since and I believe it's been about 8 months.
Old Jan 15, 2011 | 07:54 PM
WDoherty's Avatar
WDoherty
Great, and your car is a 400?
Old Jan 16, 2011 | 11:18 AM
RawkusX187's Avatar
RawkusX187
Yes 400 and 300 are the same. I dont know why they state it like they're any different.
Old Jan 16, 2011 | 12:32 PM
Str8sikk's Avatar
Str8sikk
I might have to get these....driftmotion rocks
Old Jan 16, 2011 | 01:11 PM
WDoherty's Avatar
WDoherty
Weird, they are priced different on the same page. I don't think that long 90 degree fitting will work on the pump on sc400 then, the stock banjo barely clears firewall.
Old Jan 17, 2011 | 07:11 PM
RawkusX187's Avatar
RawkusX187
Maybe the 90 degree is different. I bought it for a 400 when I had it and I ended up swapping to a 2j and not issues,
Old Jan 17, 2011 | 10:22 PM
93MSB's Avatar
93MSB
the washers are a little big, you can use them but you have to make sure they are centered up nearly perfect. You can also cut the stock washer and use it.
I have an sc300 and it is a little long, i have a friend who works at a nitrous company and I had him cut it down and put a new fitting on one side
Old Jan 18, 2011 | 01:19 PM
WDoherty's Avatar
WDoherty
Oh, I didn't realize you had it in an sc400 with a 2jz. Anyhow, i talked to Mary there yesterday and she said it was made for the 400 and fit so i ordered. I will update.
kodaav
Oct 16, 2013 10:05 AM
Murco
Dec 2, 2011 09:51 PM
stevearrari
SC400 / 300 Classifieds
Nov 4, 2010 12:54 PM
grindin8o8
Jul 11, 2009 01:27 PM
lexucnyc
Maintenance
Mar 7, 2006 02:36 PM
