Aftermarket gauges
Aftermarket gauges
Has anybody switched over to aftermarket gauges, especially for fuel level? We had been using our stock gauges in our race car, but they got damaged, and now our fuel level doesn't read correctly. I think the needle got bumped (we removed the outer cover). If the sender uses a standard OHM range, it would be nice to just switch to an aftermarket gauge, not need to change the sender.
I replaced most of the stock cluster with a STACK display which included the fuel level display. I was able to use the stock sender.
BigWaveSC
Performance & Maintenance
05-28-10 02:57 PM
