- Engine Oil Grade
- Alternator out?
- RX 300 lexus harrier 2001 cd player touch screen
- Honey, It's just a scratch!
- auto rx advice please
- Rear main seal leak- auto rx?
- 98 RX 300 Gearbox
- What the heck is this?
- Antenna Mast Replacement Help
- 02 awd tire reccomendation?
- Sell or fix?
- Considering used RX300...advice pls
- Oil change tips
- Transaxle Additives?
- Transaxle Drain Bolt Torque
- Timing idler was supposed to be all
- Mityvac 7201 Fluid Evacuator Trans & Oil Change
- Black smoke,no o/d shift , horrible gas mileage
- Dealer claims I need a new power steering pump, but...
- HID balast gets really hot? help??
- 2002 rx 300 rear end noise on acceleration
- RX 300 LED Tail Light Pic's
- Fuel Door Problem - need help
- Another oil sludge thread
- A/C Compressor Seal Leak
- mpg display
- What type of LSD in a 99 RX300?
- engine error codes: 0125,0300,0171,1130,1150, And 0768
- Anyone tried Pentofrost A1 antifreeze?
- How to repair leather seat seam damage on 2000 RX300 ?
- oil change question
- catalytic converter ugh!
- Knock Sensor questions
- warranty:)
- Window Vent Shades
- Airbag light started flashing
- Strange misfire issue
- HID lights
- Got an RX300
- Sorry! Another Servos question?
- Can I Neutralize knock sensor on 99 Rx 300
- Knocking noise in/around tire?
- Trac off indicator and CEL on, P0125!
- Help with RX 300 Check Engine codes
- NEW LED Taillights installed :)
- a/c issues
- What exactly does "Coach" add to 2002 rx300?
- Lexus RX300 2002 85k - Losing 1 quart every 750 miles
- How much have you towed in your RX300?
- RX300 & GS430 steering wheel swap
- 2002 RX300 Ball Bearings
- '99 RX300(AWD) Struts & Mounts Replacement
- Garage Door Opener--active even when car is switched off
- Front Passenger Window Motor Install
- I think I found touch up paint for gray RX bumpers
- Mayday, mayday spark plug help
- Broken antenna motor gear???
- abs brake pedal noise and pulsation
- Mode Servo 17 for heat
- 2001 rx 300 failed emissions
- Need Double Din for 2001 Rx300
- im so CONFUSED!
- rear lights
- Shelf life of "Toyota Red" antifreeze?
- TB/WP Life
- Reverse Gear Sometimes Hesitate
- Noise from rear end around highway curves
- Timing belt ?
- need a lil help
- Transmission Woes
- "rear lights" indicator
- Advice on tighter suspension for RX300
- Grom iPod DIY or recommend installer near S.F./S.J., CA?
- Engine turning over but won't start
- Help!!!
- DIY: Add Surface Mount LED to Center Console
- Replacing/repairing door weatherstripping
- Shift issues after new transmission
- Changed my plugs, got 2 codes
- Buy Acura MDX or Lexus RX300, after so many years of testing
- Starts but doesn't stall
- Rear bumper protector
- Dashboard Transmission Shift indicator Light
- Timing belt, crankshaft and cam replace!
- Valve cover gasket
- Re: Rx300 Antenna And/or Motor Replace/repair Complete Instructions
- what is correct part # please
- Quick Vote: Tires
- 99 RX 300 leaking coolant from front passenger side
- LED Light in Center Console (Cup Holder Area)
- Air intake box gaping open
- Air/Fuel sensor under car hardware
- AIRMIX and MODE Servo Arms
- Antenna Extend/Retract disable switch
- Convert Tape Deck to Aux input
- DIY Radio Antenna Mast
- Clunk Sound From Rear When Shift from D to R
- White LED in Orange/Red Side Marker
- Bought 1999 RX - Previous Owner Used 87 - I use 91 - MPG Plummet!
- How to get to or remove the washer reservoir?
- Subwoofer Infinity Basslink Installed
- DIY backup camera integrate with gps nav screen
- DIY DVD Headrest integrate with GPS screen
- 1999 RX 300, O2 / Fuel air sensors assistance required?
- Rear strut replacement
- How would you install a LED Theft Deterrent light
- 02' RX Longevity
- RX300 December 2004
- Replacing spark plugs posted on youtube?
- Filling your gas tank
- Faster? Off-Road?
- Gear Shift problem even after new transaxle
- i fixed my p1133 code
- Was warned NOT to change my Transmission Fluid
- LED Taillights
- What Brand Fuel Injector Cleaner If Any Do You Use?
- Brakes and rotors
- How an Air Filter SHOULDN'T look...
- GPS system looking for disc?
- good morning everybody
- What is this part that rusted off (fell off)?
- 1999 RX with transmission issues.
- knocking sound below 2K RPM
- Throwing EVAP need some help please
- First issue with the RX: Starting Issue
- RX300 Fluids
- Time for New Springs with Struts?
- How far down should E-brake go?
- In need of rx300 rear passenger window
- My goodbye, sold my RX300.
- RX300 randomly dies on me... fuel pump? injectors? plugs?
- Volume up (8 number out of 10)and sound get distorted
- Where is the DLC1 connector on a 2003 RX?
- SRS Flashing Light and Dtc 72 Diagnostic Port? 2003 RX
- How to remove stock stereo and hook up subwoofers
- What's the most I should pay to repair my RX?
- should I do tire rotation?
- Help: where to find inner door trim??
- high rpm on the highway
- RX 300 Will Not Start _ Alarm Problem?
- Cold Air Intake for RX300?
- 1000 watt amp
- Another ATF besides Dexron for the P/S?
- Spark plug tube seals in the valve covers. How do you replace 'em?
- P1153 Code after fixing P0171 and P0330
- Driver window stuck down
- Rusting paint
- Help changing headlight
- Can not pull out my antenna
- 2001 Rx300 Fault Code
- intermittent fan blower
- Navigation Update Issue
- 02 RX300 popping noise driver's front tire
- Loud Buzzing Noise
- Radio Static
- 99 $1200 RX300 FWD unkown trans issues. buy or pass
- Well.....
- rpm at warmup question
- RX300 ABS Issue - When starting from a stop
- Oil Deal
- interchangeable sun visor for 1999 RX300
- Fluid change intervals: Transmission, transfer case, limited slip differential
- LS460 / RX350 Remote Key Fob
- How do I fix a vertical tear on side of driver seat?
- P0171, p0100, p0110
- Random Window Movements
- DIY Vehicle Speed Sensor code P0500
- Door Courtesy Switch part #?
- P0450
- what are the pros and cons of a k&n air filter?
- New 2012 18" RX350 Take off's.
- 2002 RX idle issue
- Anyone try a paint pen for bumper paint chips?
- P0303 knock sensor.
- navigation system reboots
- Brake problems Left front pads wearing premature
- Increased Vibration
- rx300 amp installation problem
- Tires, tires, and tires.
- Transmission Fluid level question....again
- Failed Emissions, CEL on now Please Help
- Timing Belt / Water Pump Replacement
- Unlock sound
- P0171 questions
- Do we need to do Chassis Lube
- What is your tire pressure PSI?
- Is it even safe to buy a pre-owned 1st RX now?
- A/F sensor? Search brought up too many opinions.
- How to remove my PCV valve
- Lubrication of Ignition Lock
- Arm rest
- Tailgate help.
- Side view mirrors shake?
- Helpful Video's For RX300 Troubleshooting
- Stock Alarm
- Coolant leak please help
- passenger mirror fails horizontally OK vertically
- Anyone replace expansion valve
- Whats the Next Step.
- To Change or Not after 6 months
- Bluetooth Interface feedback: BT35-TOY
- IACV Cleaning Fast Idle Too High
- I want to get to the bottom of this ... why is my gas mileage BAD?!
- Does the CD player required a code?
- Transmission Fluid Replacement Question
- RX300 shaking problem
- Is there an emergency fuel shutoff switch on RX300?
- Transmission might fail soon
- Quick transmission question
- Tranny Fluid Leak?...Need help
- Advice needed: rear gate interior trim panel clips - how to actually replace
- Is it necessary to add a paper based filter to the transmission
- About to buy this '99 with 110,000 miles
- Seized front offside brake caliper
- Coolant By-pass Hose
- 5w-30 ---> 0w-30
- Front Differential Drain Plug Picture
- RX300 Performance chip???
- Can you easily disable the VSC?
- Transfer Case Drain & Fill Bolts (2001 RX300 AWD)
- Questions on Maintenance
- DIY: AC Servo
- Driver side drive shaft replacement how to?
- t tech vs. drain and fill
- 99 RX300 missfire
- I need advise on (gelled) motors
- The RX 2 fuel tanks!??
- KLUNK!!!... Coming from R/rear side....?
- Csv?
- Help! Key not working...
- heater blows cold
- fuel pump issue
- Scraping sound after rear pad & rotor change
- transmission
- Cabin Air Filter is $$$
- Alternator Cost?
- Anyone Towing a Boat?
- Ignition coil - life expectancy?
- P0420 code, cat problem....no!
- help please!
- fuse box location Help!
- rx 300 transmission replaced but no oil pressure...
- transmission scam
- 3 lights simultaneously!
- Key fob screw missing
- Dealer broke my antenna mast AGAIN!
- tire size
- Where is the brake booster line?
- Is Lexus still assisting with transmission failures?
- Investigation: Best brands of gas for your car
