catalytic converter ugh!
I just had my knock sensors changed and my check engine light came on so i took it to autozone they said po402 code so i went to muffler shops and had my cats checked they said they were fine.The gas i put in is bad gas so i went and put in 93 octane reset ecu and the lights been off for about 100 miles and now its back on. Any suggestions what it could be
If the code comes back replace the 02 sensor behind the catalytic converter. I had the same code P0420 and after I replaced that sensor the light hasn't come back, it's been at least 20k miles.
Here's the DIY for that sensor, which Lexmex made: https://www.clublexus.com/forums/rx-...sor-2-diy.html
This is the sensor you need: Denso 234-4215 Oxygen Sensor,
I don't know if you can test the sensor first, I know you can test an air/fuel sensor but not sure about this 02 sensor. You would need to know the acceptable ohms.
ThumperPup
ES - 5th Gen (2007-2012)
11-11-16 08:32 AM
