im so CONFUSED!
Old Jul 4, 2012 | 03:45 PM
orlonda's Avatar
orlonda
Default im so CONFUSED!
Ok ive had a cel and i had it coded po330 ks bank 2 . Ive driven the car for the past 4 days and has shifted into od fine. The man and the shop also said one of my cats are clogged. Anyway any suggestions to why if it was a bad knock sensor would it just do it once in awhile.....ugh
Old Jul 4, 2012 | 08:05 PM
carguy07's Avatar
carguy07
Darn near anything electronic can have intermittent issues. Most guys replace the sub wiring harness while they are in there, could even be that harness. How did the shop diagnose the clogged cat?
Old Jul 4, 2012 | 10:57 PM
salimshah's Avatar
salimshah
25 Year Member
Please read the DIY on knock sensor. My experience was that in the beginning the error would come and go and then it became persistent. I attribute that to the knock sensor(s) are on the verge of total failure.
Salim
Old Dec 28, 2012 | 12:02 AM
Dburton's Avatar
Dburton
Got the same code 330 and have same experience with overdrive working fine on 2000, rx300. College kid drives it and said engine light goes off, on intermittently ...repair shop diagnostics came out with results that the knock sensors were fine. They tested through the wiring harness, splicing into it. Has anyone had experience to say if that is a reliable way to test knock sensors?. They wanted to test timing mechanisms next and put in new timing belt. I just picked it up to gather more thoughts and ideas.
Old Dec 28, 2012 | 07:39 AM
salimshah's Avatar
salimshah
25 Year Member
I would keep an eye and make a fix when the error is persistent or it is verified by some other thing. Otherwise, you are shooting in the dark.
Salim
gu3rr13r
May 18, 2017 12:04 PM
PhilipMSPT
Nov 6, 2016 05:49 PM
fdmt
17
May 25, 2016 12:37 PM
frednaz
Oct 13, 2010 07:53 AM
99jewel
Jul 13, 2008 04:46 AM
