Seized front offside brake caliper
Old Apr 9, 2012 | 12:03 PM
thejanitor's Avatar
thejanitor
Default Seized front offside brake caliper
MPG has been slightly lower, performance seemed to be less and few noises when pulling away. Added to this seemed to be more brake dust that usual on alloys. Jacked the car up and the wheel will barely moved - been advised this is most likely a seized caliper.
Looking for some help! How can i confirm the problem? any easier fix other than new discs pads rotors calipers etc etc
any help would be appreciated.
thanks
Old Apr 9, 2012 | 01:12 PM
salimshah's Avatar
salimshah
25 Year Member
You should be able to push the brake pad back with very little effort using a screwdriver as a lever. Just watch out that the brake-fluid reservoir does not overflow.
If you cant budge the pads back, then you have a stuck caliper problem. With FWD and AWD the front wheels have a drag.
Salim
Old Apr 10, 2012 | 03:01 PM
thejanitor's Avatar
thejanitor
cant move the pad - looks like a stuck caliper. any ideas?
Old Apr 10, 2012 | 05:22 PM
salimshah's Avatar
salimshah
25 Year Member
The problem can be in the slide pins or stuck piston. Time to take the caliper off. Slide pins can be cleaned and the slave cylinder can be rebuilt with a kit. The other option would be to buy the caliper.
Remember to flush out the old brake fluid in the lines and the slave cylinder.
Salim
Old Apr 14, 2012 | 04:58 PM
JohnLX300's Avatar
JohnLX300
I had a stuck caliper once, I took both brake pads and place them in the caliper (off the rotor) then stepped on the brakes in the car, caliper piston poped out all the way and was easily pushed back in without any issues. Drove 20,000 miles till I sold the car without any problems.
Old Apr 14, 2012 | 06:28 PM
salimshah's Avatar
salimshah
25 Year Member
If the piston movement is stuck, one can remove the caliper and use the hydraulic force, BUT, you need to make sure that the piston dose not travel too far and come out of the cylinder, If it does, then service the piston.
Salim
Pzindy
Jul 28, 2017 10:01 PM
lexus-is2
Suspension and Brakes
Apr 30, 2013 08:02 PM
Pnoy619
CL of Southern California
May 25, 2012 03:04 PM
gridlock13
Jun 18, 2011 02:25 PM
sung35
Feb 18, 2006 05:59 PM
