- Liftgate Latch won't release
- custom grill on ebay
- Anyone else ever get (and resolve) a P0446 code?
- Good bye RX300
- does 99 rx300 have an egr valve
- could it be the throttle body sensor
- Alarm and locking problems
- Catalytic Converter issues 99 RX300
- 2001 RX300 AWD Rear Differential Fluid
- Vsc
- Door Latch Failure
- All the relays were going off at once while the car was off
- Need advice re: knock sensors
- All the shocks & Struts boots are torn!
- camshaft position sensor location(bank 2)
- new owner of 2001 RX300
- Transmission Problem?
- weird left/right/left/right sway in rear (feels like stability control is turning on)
- Anyone have p/n for OCV?
- What's wrong with my spark plugs?
- 2010 RX350 rear bumper separation
- CEL light on after using Chevron Techron Concentrate
- 2000 RX300 Sunroof
- Door Lock Actuator Issue For Lock Only
- Remember that nice picture of the 1MZ-FE turbo
- RX300 Mega Thread. Start here if you have a problem
- RX300 Front Clicking and Grinding Sound When Braking
- RX300 Cabin Air Filter Covers
- Another transmission challenge :)
- 2001 RX300 Rear Differential Filler Plug
- really need help
- Proud New Owner Of An Rx300
- Help I have an sick car
- Thank you!!!!!!!!!
- Can I use Lucas Power Steering Stop Leak?
- need advice on removing bank 2, sensor 1
- No sound from the audio system
- No Dash "D" light when in Drive
- Low Cost RX300 Oil Fix that works
- HELP! Gas Mileage Suddenly Plummeted >>
- 2001 110k or 2003 140k?
- VSC issue
- Car Turns over but won't start...
- RX300 Lexus Repair Manuals '99-'00
- Rear main seal leak. Can I remove the engine from the top??
- vvt, misfires, smell gasoline, more codes...
- Some pre-purchase questions
- Brake light problem
- Retainers for Tailgate Trim Piece:Good Tip
- Knock sensor part numbers
- OBD Connector Plug Got Smashed. Where Can I Get a Replacement?
- 2002 fender replacement
- Transmission Drain/Fill good enough?
- Valve Cover Gasket Replacement - how hard?
- Seat belt slow to retract
- Rx300 - gs430 18x8 wheels fit on 2002 awd
- Super low oil--- another coil problem too?!
- Turn signal driving me crazy
- First Gen Rx 300 ......Overpriced Junk !
- 2001 with codes P0420 and P1150
- Burning oil...new thread
- HELP! no forward gears 99- RX300
- New CELs
- Navi ?
- RX would not start after parked 24 hours
- vibration and humming noise
- Scanner use for RX300,LS430,LX470?
- Another misfire thread
- Can't read info screen.....
- Need Help
- 2000 RX300 AWD will not start after long-term storage
- can seafoam cause problems on an old unmaintained car?
- Car Won't Start
- New headlights or aftermarket
- 2001 rx 300 possible abs problem
- Climate Contol Malfunction
- IACV cleaning attempt
- rx cranks over, won't start
- New CELs
- Cold starting -33, p0171 and more fun PLEASE HELP!
- New Shoes...
- Pointers?
- 1MZ-FE compatibility question
- help please
- harmonic balancer won't come off
- Alternator Belt Replacement
- Replacement of Rubber Muffler Hangers
- tranny problems 01 rx300
- Timing Belt Kits
- Parts for RX300
- using oil only on highway
- Faulty Toggle switch in a Lexus RX300
- Courtesy passenger door light won't go on when door is open
- Should I buy RX300?
- parts interchangeability
- RX 300 2001 / Mouse over image to zoom Timing Belt Water Pump and Sludge issue
- Rx300 secrets
- 99 rx300 Ring & Pinion gear need Part(s) Help !
- Opinions please
- 1999 rx300 how to get power wire from trunk to battery
- 99 AWD..Forward gears slipping...reverse ok
- Won't Start with AC on
- DIY Shifter Light
- Got a gas smell issue...
- Exhaust Leak
- Lexus rx300 P1354 and Misfires? HELP!
- Throttle Body Removal Help
- FIRST POST! RX300 no 4th gear a full year. Fixes?
- Had VVT replaced code P1349
- Location of Water Temp Switch?
- Get Rid of Smell
- Trailer lights wiring question
- key fob for 2003 RX300
- O2 Sensor help? Lexus rx300 (2001)
- Where's everyone sitting?
- Steering wheel vibrates and shakes high speed after replaced both lower control arms
- 2000 RX 300 headlight/fog light problem
- 1999 Radio Tuning
- Can an exhaust leak throw off these codes: P0171, P1135, P1155
- HELP engine failed
- Transmission Fluid Level Sensitivity
- 2001 rx300 Heater Blend Door Actuator
- AWD Rear Diff Vent/Breather Filter
- error codes
- Installed Backup Camera, Reverse Mirror Monitor Etc PHOTOS
- Door won't unlock manually or with piggybacked actuator?
- Help Please
- Has this timing belt been changed?
- Need Advice: Should i disconnect battery when going out for 4 weeks?
- VSC/CEL lights after long trips
- Tips from DIY'ers who have replaced timing belt
- Help help please
- fuse location for reverse light
- RX300: Location of left OCV
- seatbelt advice please
- Merry Christmas
- First time trying to fix my antenna
- SUNROOF, Budges but wont OPEN or CLOSE....STUCK
- Heavier Gear Lube
- Random window movement
- 99 wiring backup camera
- Replacing rear brake light bulb...socket appears melted.
- 00 rx300 check engine light !!! needs a little TLC
- Surging Idle - Need some help
- Green circle light around ignition
- 7.5 fuse panel lights not blown
- Engine Knocking Randomly
- Increase Mileage w/use of Additive and Higher Octane fuel
- 2002 RX300 Fuel Gauge Problem
- Brake Fluid Flush/Change
- 2000 RX300 Temperature Control Not Working
- sound system tweaks on 01 RX
- O2 sensor question 2002 rx 300
- Headlights Dim When Braking RX 300 2000
- fuse
- Seat Belt, Rear, RX 300
- Towing Hitch
- Interior storage compartment bulb change
- 1999 rx 300 glove box removal
- Used RX300 red flags?
- DIY-Grom USB Adapter + Bluetooth Dongle Installation
- Alternator Belt Adjustment
- Thinking about a RX300 for the SO
- 2001 RX 300 grille
- Shift solenoid problem
- New to the forum with new found problems!
- Diagnostic help needed
- Valve Cover Seeping question
- Spoiler Question...
- Exhaust Leak
- RX300 Door Lock
- RX 300 parking brake
- Gas mileage on my RX
- 02 RX300 w/67K miles for $12,000
- Bling Bling...
- Aux In 2001 RX300
- P0302 - Replaced plugs and coil and did IACV
- Plugs and coils
- Transmission problem RX300 2000
- Finally having the seats redone
- Trying to decide betwen the Volo XC90 or an RX 300
- Replace Blower Motor RX 300
- Should I sue the mechanic for bad work?
- Steering wheel compatibility question
- Spring clips for interior trim
- Timing Belt and Water Pump replacement
- RX300 Rear Door Speaker sizes
- Oil leak
- Ignition Coils
- Black paint fading around windows (oxidation)
- Farewell and Thanks to many!
- Shifter solenoid problem?
- Is this a newer re-engineered valve cover?
- For all of the RX lovers...
- New owner with maint questions
- Check Engine Light On
- Which fuse runs the Rear Cigerette sockets 12v?
- A/C Dryer
- Replacing the RX300 Transmission
- RX 300 cold start problem
- Automatic transmission cable plug
- 2 bad keys
- And BANG! went the engine...
- A few questions
- No power over fuse 3
- Began the holidays with a bang
- 99 RX300 Oil consumption, good comprression
- Car suddenly slows
- OEM Strut Mounting - what all parts?
- FWD CV boot
- Minor problems on new rig
- Do you think my Lexus dealer charged for work not done?
- Back Door Struts
- AWD and FWD Differences
- Front license plate bracket
- Valve Stem Seals
- Rough Idling, CEL and brakes become hard and don't work right
- First mpg return in my "new" 2000 RX300
- Vacuum switching valve?
- Old Car with New Look MY 2000 RX300
- RX300 Problems Cat and brakes
- New Head Bolts
- Auto headlamp setting (also posted over on 2nd gen)
- Old guy, new RX300 owner
- Mobile 1 Synthetic oil change interval?
- Two Questions 01 RX300 AWD
- EVAP-P0440/0446: loose hose
- CEL with p1349
- Rear Main replaced (2x) - still leaking Help !
- Variety of Error Codes--Need Advice on How to Proceed
- Lexus rx300 transmission
- Timing Belt Service - Need Advice
- rattle
- Coolant questions
- No heat in the Cabin (Air Mix Servo?)
- 01 Rx300 Accident
- WTB Air Mix Serv
- Strange electrical problem
- Drive belt condition after 82,000 miles
- Rear Differential Question
- Trouble code: vvt system malfunction help
- Wife and I buying a 1st gen RX!
- '03 RX300 Hatch rattling noises - gas cylinder mount suspected
- Replacing Body Parts (fender, etc.)
- sticking parking brake
- Thinking about Goil for your RX? Think again
- Rotating Tires
- Rotor HELP!!!!!
- Do I need to change my power steering fluid?
