2000 RX300 Temperature Control Not Working
Old Dec 17, 2012 | 09:37 AM
guyhaz's Avatar
guyhaz
Default 2000 RX300 Temperature Control Not Working
Just bought my wife this SUV and now the temperature control **** will not adjust the temperature. It stays stuck on 75 degrees. Worked fine when we test drove it, but now you can rotate it either way and it does not adjust the on screen temp. This is the first Lexus I have owned and bought if for her and our new baby because I wanted something safe and reliable????
Has anyone ever run into this issue and what was done to fix it. Temps are getting colder and would like to get it fixed myself if I can without taking to the shop/dealer.
Appreciate any ideas!
Thanks...
Old Dec 17, 2012 | 12:29 PM
salimshah's Avatar
salimshah
25 Year Member
try disconnecting the battery for about 10+ minutes.
You will loose all settings.
So how much out warranty are you miles/years ... I have a '99 and over 180k miles ,,, well beyond what Lexus warrantied it for. Keep in mind it is a machine and things wear out and maintenance makes a huge difference.
Salim
Old Dec 17, 2012 | 12:35 PM
guyhaz's Avatar
guyhaz
Default Temp control
thanks for the reply.
Had the neg. battery cable off for about 2hrs yesterday. Still same problem. Temp stuck at 75 and unable to adjust with control ****.
I have looked all over the internet trying to find a fix. It appears this is not a very common issue. Hoping someone on here has seen this issue and can point me in the right direction.
Old Dec 17, 2012 | 12:38 PM
guyhaz's Avatar
guyhaz
Mileage is 155k. Vehicle has been well maintained, kinda why I bought it. I know its 12 yrs old, but my wife really likes it, just thought I might be able to fix myself and avoid the dealer/shop for now.
Old Dec 25, 2012 | 05:50 AM
toyo's Avatar
toyo
Temp blend door actuator is usually the cause for this.
Old Dec 25, 2012 | 09:33 AM
guyhaz's Avatar
guyhaz
Took to dealer and they said the temperature control head is bad. Mechanic says buy a used one, dealer wants $850 bucks. Has anyone ever replaced these. Radio works and don't want to replace it, plus don't want to deal with theft deterrent system. I would like to buy one from the wrecking yard and try to just replace the temp. control head. Any thoughts.
Old Dec 25, 2012 | 10:20 AM
salimshah's Avatar
salimshah
25 Year Member
"temperature control head"? what is that.
stereo head unit would be the radio ... note the RX display is a separate attachment.
I think the radio units can be swapped. Please confirm before you run with my statement.
Salim
Old Dec 25, 2012 | 08:09 PM
maxSteel's Avatar
maxSteel
The air conditioning section on control assembly removal says:
1) remove center lower finish panel
2) remove integration control panel (4 bolts, pull out the panel, disconnect connector)
3) remove multi display (3 screws and the display)
4) remove radio (4 screws and the radio)
5) remove panel ECU (6 screws and the ECU)
6) Heater control (remove the 15 screws and the heater control)
7) Remove *****
8) Remove plate
I've never seen it and It's hard to picture. I think once you complete 1+2 it may become more apparent
Old Jan 2, 2018 | 02:14 PM
rx300basic's Avatar
rx300basic
Sorry for reviving a super old thread, but I am experiencing the same issue with my 2001 RX300. How did you end up fixing it??
Old Jan 15, 2018 | 07:26 PM
rx300basic's Avatar
rx300basic
Figured it out! Bought a used temperature controller (basically the faceplate surrounding the monitor and radio/climate controls) for $65 on eBay and swapped over the control board to my original part. Now I have full control of the temperature once again!
Old May 14, 2020 | 11:46 AM
jamsk8s's Avatar
jamsk8s
Default Just a thought try the
climate. Try the climate controo module under the passanger dash. Thia controls the blend doors. They go bad yours might be stuck
gadiodati
May 1, 2023 07:03 AM
afpj
RX - 3rd Gen (2010-2015)
Jul 26, 2013 09:17 PM
ParaVoodoo
Oct 6, 2010 01:37 PM
bam
Sep 9, 2009 05:51 AM
LexusRx300_dude
Aug 1, 2002 03:20 PM
