VSC issue
I have been driving my rx300 for awhile with both the VSC and CEL on....car has been running great.....(130K miles) ...I recently replaced the battery.....and the warning lights went out.....i was told I need to record some 75 to 150 miles to allow the computer to reset......with the warning lights out I noticed a slipping sound when I first accelerate and the little anti slid light would blink.....just for a second or two... sounded like the front drivers side...now that I have 100 miles recorded and the VSC and CEL back on I no longer have the slipping feeling and the anti slip light does not come on....car seems fine.
What would cause this problem?....at first I was afraid it was a transmission issue.....I have read that many owners somehow disconnect the VSC system.....Is that a option that makes sense.....or do I need to spend Big bucks at Lexus
Thanks in advance to all that respond
https://www.clublexus.com/forums/rx-...ode-p0500.html
Baetke
Disconnect/reconnect the battery and it might take a few drive cycles for the engine ECU to "discover" an engine operational anomally...Oxygen sensor, etc. Have the code read.
The hose is between the firewall and the air filter box. The hose connects to the little sensor that is in the top of the air filter box. If you cant find it I will take a pic when my wife gets home. I had this problem on 02/12/13
