Heavier Gear Lube
Old Dec 23, 2012 | 08:37 AM
CharBaby's Avatar
CharBaby
Default Heavier Gear Lube
Hello All,
My current situation is: In my '01 RX-300, there is a slow drip in the rear(driver side diff seal) of the differential.
My question is:
Before fixing this leak/seal, can I use a heavier wgt of Diff Gear Lube? I am currently using Syn Mobil 1 75w90 LS which is now leaking. I have already been using the Syn M1 75w90 since my 1st D&F several yrs ago when I dumped the OE gear lube. But, after this D&F this past summer(using the M1 again) the differential decided it wants to leak... IDKY! It was only damp around the driverside shaft seal prior but, did not drip!
I also changed(D&F) the TC with the same M1...Now, the rear shaft seal on the TC was infact dripping but, the D&F has stopped it completly...Just the oposite of the rear diff.
Although the seal is in need of replacing, in the meantime I am wondering if I can use a suitable lube such as 80w110 or heavier(DINO Diff lube this time), without hurting the differential itself. Maybe too, it will slow/stop the leaking to an acceptable drip.
Thank you for any assistance
CB
Old Dec 23, 2012 | 12:17 PM
CharBaby's Avatar
CharBaby
I see that there are 28 views on this subjest but zero responces so, let me ask the question this way:
Is there anyone using a heavier weight lube in the rear differential with good results, other than what is recomended by Lexus?
Old Dec 23, 2012 | 12:35 PM
gazi001's Avatar
gazi001
I think nobody used heavier gear oil.
Old Dec 23, 2012 | 05:41 PM
carguy07's Avatar
carguy07
https://www.clublexus.com/forums/rx-...tial-leak.html
Old Dec 24, 2012 | 03:36 AM
CharBaby's Avatar
CharBaby
Carguy07,
Thanks for the link. This is just what I am looking for!
I just wanted to know that I can safely use a heavier wgt gear lube without hurting the differential, till I get the shaft seal repaired. And hopefully slow down the leak in the meantime!
Mrbolly
Performance
Apr 18, 2017 07:16 AM
mcat
Aug 16, 2013 08:00 PM
ILOVEGIRLS
IS - 1st Gen (2001-2005)
May 7, 2012 10:45 PM
sc250tt
Dec 28, 2008 06:46 AM
