- Is the Market Place really used?
- Where do you guys find vehicles for sale?
- Navigation CD
- SC430 Subwoofer repair
- Question about Mark Levinson EQ
- 1/4 windows mod Russian edition)))
- Sound system upgrade?
- 02 sc430 smelling like gas
- Radio Replacement Question
- Antenna Mast Replacement
- Battery drain on a 2002
- Slow to engage starter
- Steering wheel audio control w/o Beatsonic
- Bent wheels repair - 2006 SC430
- Top issues. Need opinions.
- Shifter issues
- 2005 SC430 Navigation not working
- Lug Lock Key
- AFS Light Flashing After Bulb Change
- Am I overpricing my SC430 in a private sale?
- SC430 Normal Operating Temperature from Cold Start
- The Pirlle P7 Plus Going Away
- Opinions Please on "Gabriel" Shocks and Struts
- Happy Thanksgiving to all at the Club
- After fifty years....
- Tpms reset 02 SC430
- And so it begins...
- Test driving a 2006 SC430
- Feedback welcome
- Winter tire fitment issue
- Alternatively to key replacement
- This was interesting
- VSC/Check Engine Light On
- Last stupid question for today...maybe
- Driver door won’t lock/unlock with the remote
- New first time owner!
- Need an assist - looking for Front Engine Undercover
- lexus sc 430 roof b2523
- Need help identifying red light that beeps off/on
- What can display on Nav screen?
- 06 SC430 125K for $7,500 ( Good deal?)
- climate control face
- Lexus noob looking to buy a SC430 think this is worth it?
- Speedo?
- Sc430 spare wheel space saver
- Let's talk about Big Brakes
- Happy Veterans' Day
- color opinions (again)
- Timing Belt and Water Pump
- What to look for when Buying an SC 430
- This is what happens when you drive your car after your raditor blows
- Winter storage UK
- New Tires for 2002 SC 430?
- SC Air Bag Recall Experience
- # of owners on purchase decision
- Naviks Problem
- 2002 SC 430 Replacing Timiming belt, components and H2O Pump
- Just Joined The Top Issue Club
- Luggage rack
- 2004 sc430 starter replacement video/instructions
- Navigation Screen - Permanently Remove
- Odd Noise -- audio file attached
- Is this normal?
- No quick struts available for a 2006 SC430?
- Anyone want to guess what happened to this SC?
- Another air bag recall!!
- Price range advice
- Creaks and pops
- What's Your MPG?
- Pics of the SC “ Taking a Drink “
- Black Exhaust tip options
- Choices
- HELP! How to disassemble the VVTI camshaft to replace cam seals??
- TRD Door Stabilizer Brace
- Rear Shock/Strut replacement
- 2UZFE (05-06 Tundra/GX470) intake manifold
- Owners site service events will not save
- Why don't you drive your SC?
- I'm trying to find replacement key for 2004 430 with 17,700 orig key broke?
- Curious re 430 depreciation
- custom 2007 sc430
- SC Advice
- REAR Strut tower brace* (PICS INSIDE!)
- Engine light, VSC, VSC off lights. P1354 code
- OEM or Equivalent Suspension Bushings
- Posting a detailed instruction of installing WET NITROUS kit on my 04 sc430
- 20" staggered set up advice
- Let's talk about catalytic converters
- Idle RPM high in gear
- Seat memory buttons inactive after airbag change
- Attn GROM BT3 owners with iPhones
- Unusual oder
- 2004 SC430 Camshaft sensor error
- P1330, vsc off, vsc lights after knock sensors and harness replaced
- SC430 #95 NM Edition, Custom Stereo, one of a kind
- Help with P0420 Catalytic Converter and Y-Pipe Leak
- drivers a/c register
- Replace instrument panel lights
- Water Pump/Timing Belt Change Question
- sputtering low frequency sound
- Clips for HVAC panel
- Rodent ate knock sensor wire at base of the plug 02 SC 430
- space saver spare, how much is too much
- SC prospective buyer choice - preference?
- Rotor won’t go back on wheel bearing
- Advice needed on new wheels/tires
- Part number for seat tilt button cover
- In-cabin trunk button stopped working
- Storing indoor with a car cover on?
- sc430 LED backlighting fails on climate/nav
- Slight vibration at highway speed
- Oversized Oil Filter
- Tire Pressure warning
- Buying a SC 430
- What are the wheel specs on a 2002 Lexus SC430?
- 2009 SC 430 107K miles for $16K
- Lighting Modernization
- Updating the beloved Mark Levinson Sound System on my 06
- Storage
- Really dumb cd player question
- Lets talk Cord
- Quiet your car down quick and at a low cost
- Lets talk Dash Cameras
- Long nonstop beep noise
- Another Nav Screen thread...
- Planning my custom exhaust
- Tinted windscreens
- VSCOn/Off lights anc check engine light
- hello all! will 20x10 +35 squared work for our sc430 ?
- Antenna
- Type of wheels?
- Sunvisor
- Timing belt change
- 2004 lexus sc430 caliper rebuild kit
- Upgrading our old tech
- Carbing Strut Tower Brace
- Aftermarket head & speakers
- Door Speaker Grill Material
- Just curious... Why did they do that?
- Navigation door inop
- JDM Wind Deflector Antenna?
- The Lexus LC500 Is Rolling Art That Drives Like It, Too
- DRL/Highbeams not working, not fuse
- After market wireless back up camera
- New owner, any quick advice
- Clear Corners... 12 years later.
- Bluetooth for 2002 SC430
- 2002 SC430 Taillight Out Indicator
- 245/45/18 are on! Pictures
- Lights on: VSC-VSC Off-ABS
- OEM Airbox Mod
- GS or IS wheels on your SC?
- Do any of you have the 07+ uniblade wipers?
- Techstream Opportunity???
- Wait or the old "while you're in there"...
- Seat Belts - I bet this is a new one
- Cooling fan/blower/motor issue/feedback please
- Mark Levinson audio system problem
- PCV Valve - Cheap. But very important!
- Driver Side Control Arm Question
- how to fix VSC and VSC off lights on dash board?
- pre-facelift grill on 06+?
- Three Steps Forward...
- Headlight washer backwards
- Blue tooth
- Zero Point Calibration after a Wheel Alignment
- Passenger door metal crack.
- SC430 RCA (Roll Center Adjusters)
- Quick question about LSD swap
- Run flats replaced
- Paint Buffing?]
- Thank You from Australia
- Interior lights don’t come on.
- Update/Upgrade Navigation Screen
- Occupancy detection sensor
- SC430 engine temperature
- Wheel spacer help with 245/45/18
- Help With Slow Moving "Up" Window
- RESOURCE MATERIALS: 2002-2010 SC430 Technical Service Bulletins (TSBs)
- Same airbox as GS430?
- Free Legitimate TSB's and more
- Service cost and discipline
- Where do you buy your parts from now?
- Top squealing when closing
- Air noise by mirrors
- advice wanted. Sell whole or part out key things first
- TPMS - The opposite question?
- Trying to connect android phone to car audio via a cable connection
- Engine Label
- Bolts for OEM Wheels - OEM or Non-OEM?
- Interior: what is plastic and what is leather?
- I bought a used Laptop w WIN 7
- Headlight adjustment
- Need help with dome lights
- Audio door. Can it be repaired?
- P0430 Code
- Package Tray Bubble
- CarFax has free app in Google Play Store!
- A/C blowing hot air, running out of ideas
- Spoiler template
- Dealers want low mileage SC430’s ?
- What do you think this means ?- Dealer report
- Help with window switch
- Engine Undercovers
- Antenna mast replacement
- New Owner
- Why you should own a personal DTC Code Reader/Scanner
- need advice/views
- Spark plug electrode broke off INSIDE engine
- Side Mirrors
- No Sound - Speakers Dead
- A/C Screen
- What is the fastest you have ever driven in your SC430?
- 2010 SC Not So Much
- Some SC430s are closing in on becoming an antique
- Old SC 430 SEMA car for sale
- Trunk/roof module replacement 2002 SC430?
- VSV (vacuum switching valve) Cleaning
- Advise for Purchasing SC430
- Anyone considering headers / cat-back system
- NJ pothole got me good
- 430 SC trunk lock difficultly
- Sc430 p1125
- Radiator Blow Up
- Need help !! Abs lights on, vsc, vsc off, brake..
- As Promised (Any recommendations will be greatly appreciated)
- What do you know about Vredestein tires?
- 235/45/18 vs. 245/45/18
- Does the 2002 Lexus sc430 have a low brake warning light in.
- Bang !!!
- Master Bushing Kit Upgrade from Figs?
- Sway bars
- No Techstream Tire Size Adjustment
- Tire pressure warning light is on.. but tires are filled?
- Backup cam with dash recording
- Could You Take A Nav Unit out of a 2010
- Showoff time
- Skid control module. 2002 sc430
- First time at Lexus dealer question - today
- Pairing two phones via bluetooth
- Accelerator Position Sensor Issue (Throttle lag)
- CD unit not working
- Can radio be disabled by pulling a fuse?
- traffic light
- Compressor rpm sensor bad; increase idle to avoid a/c outage?
- Jump starting vs. trickle charging question
- 12 volts in trunk?
- Would You or Would You Not Drive Home?
- Thermostate Gasket Part Number
- Basically an SC430 Shape
