- SC430 ever to be a Collector's car?
- 11 inch wide on fronts?!
- A problem that stumps my mechanic.
- Audio Upgrade Assistance Please
- Torn Beetween SC430 or C5 Corvette :)
- Suspension - which coilovers to go for?
- Price for an used SC430?
- Cover in trunk needs to be replaced on 06 sc430
- fitment question please help!!
- Any 2-tone (black/red) custom interiors?
- Replacing an aging SC300... Will an SC430 satisfy?
- Supercharged 2003 SC430 on Local craigslist
- New owner of a 2002, SC430
- No audio on right channel when playing CD
- Lowest miles by year
- Extended Warranty
- Are The LeatherSeats.com Seat Cover Good for our SC430?
- Dead AC @70k miles?
- GS300 calipers/rotors on an SC430
- 2007 SC430 Differential Fluid Change
- Mods Mods Mods
- SC430 on ebay - $3,500,000.00
- SC430 Review from 2003
- Possibly blown Amp
- Need help, With VVT actuator
- Tried to mod the sc430 headlights like someone on here.
- VSC/ABS Lights in cold weather?
- climate control stuck
- 2007 SC430 Rear Brake Pads (DIY)
- 2007 SC430 Engine Air Filter (DIY)
- Stainless Steel Lip Bite and Few Curb Rashes on my 20" Wheels
- Wheel Spec Misinformation by shop
- Happy New Years 2014
- Water Pump Squeal
- How bad is this?
- Is it possible to link seat memory to key fob?
- what is the part # for the passenger side leather console panel?
- Electronics features provided by model year
- Replacement gold exhaust tips?
- look what santa dropped off
- What's it worth?
- Tranmission Cooler and Cooling Plate
- 10 Cree 50W Backup light mod
- Plastic wood trim piece on door
- Happy Holidays
- Viper Smart Start on SC430
- Car sound system upgrade
- Idler Pulley whining
- Good lord, both rear tires blew out from camber wear
- Still waiting for car in repair shop
- Door hinge 'stopper' has cracked metal
- TPMS Not Working 2002 SC430 with 2010 Wheels
- lowering seats
- SC430 stereo head unit direct fit replacement info needed
- Another Mod to Consider - Gear Shift
- iPad Air Mount on a Budget
- Looking for Lexus mechanic near Santa Clarita, CA
- Heater A/C Control Panel LCD broken!!
- HELP! 03 SC won't unlock. Can't open door
- Is the Ignition Switch causing this issue?
- Silver SC 430 in Mean Girls
- New Shock not same height as Strut, defective? (pics)
- BlueTrip Bluetooth Adapter-Alternator Problems
- What are the best speakers? JBL, Bose, Harmon Kardon, et..
- Security Alarm
- Megan Racing coilover problem
- donut for sc430
- Wonderful BBS Wheels Peeling
- Replacing gold trim with chrome
- SC430 Shown in duPont Registry Exotic Car Magazine
- Small Updates On My Oynx Black Sc430
- Water pump, timing belt, head gasket, engine & transmission mounts
- Independent Repair Shop in Houston
- Broken EVAP hose need help for P/N
- Tein s tech springs
- Exhaust question
- Rear Quarter Window Mod??
- tpms
- my new sc430
- Need help with speedometer
- Some Genius Rear Ended Me on my way to work this morning....
- New Member Seeking Aid
- seat heater plug
- 2002 SC 430 won't start has a strange sound
- Trunk release button on left under dash does work/top won't go down
- Timing Belt and Water Pump Replaced
- Help removing steering shaft
- Price Quote for hubs, bearings and studs, what do you guys think?
- new sc430 owner
- evap emissions CEL's
- Manual shift mode sucks...
- Spare Tire Kit
- SC430 WALD IS or BMW CSL Style Trunk?
- Wholesale Auction Pricing for SC430 (Nov 2013)
- Just bought 2002 SC 430 Black over Saddle
- Whos got an Optima Battery?
- Trickle Charger
- Looking at an '07 sc430 with 65k miles
- After accident, dash light won't turn off
- Rear bearing replacement question
- My New 03 Egyptian Pearl SC :)
- Experience with Ceramic Brakes
- Hello! I'm new to the forum! Allow me to introduce myself….and a couple of questions
- Wheel Locking Lugs
- Timing Belt Replacement at Toyota
- considering buying a SC 430
- Riding loose on bumps
- Got my speakers repaired with an easy re-foam kit
- sc430 Spare
- disc/radio player removal
- Winter Advice
- How do I remove the instrument cluster 2002 SC430 ?
- Spark plug gap?
- Don't use DETAIL DOCTOR!
- It's been fun...
- Caliper resetting
- 2008 SC430 Factory service manual
- Tire wear questions
- New Battery
- new OBD2 scanner
- Upper Bucket Seat Replacement SC430 2002
- Big Ouch
- Lowering 2006 sc430
- NAV System Is Not Showing Correct Location
- LOL Has anyone seen this video?
- Suspension and Performance Suggestions Please
- A little help with prices, please
- Loose driver's seat?
- 2004 sc430 engine and trans
- wheel fitment - need help
- SC430 seat dis-assembly help needed.
- Gun vault and/or mount
- How to diagnose my dim dash lights 2002 SC430
- New Owner ---- Don't do what I did.....
- Transmission Clank
- Double Shot of Lexus
- Wheel Experts, 19" wheel help
- Help please, what to look for on 2003 SC430?
- Passenger door light not working....
- Adjustable Camber Kit Available?..
- BatteryDead in Ten Days
- Upgrade nav disk?
- Navigation screen replacement
- help, dealer cant figure it out!!
- CEL After Motor Swap? P0300, 0302, 0304, 0306, 0308
- Rear Upper Control Arm a DIY?
- Aftermarket or performance Brakes
- SC430 - Headlight leveling
- Tired of Having Your Trunk Lights Kill Your Battery?
- SC430 vs. SLK280
- Nav door stopped closing Seat memory dead
- How to tell bushings need replacement?
- Problem starting
- Need one tire or 4
- newbie here!
- Finally found the perfect SC430..BUT 1 Major Problem
- rear clicking when car is hot
- Front windshield antenna 2002 SC430
- Nice weather.....made a couple changes....
- Broken Passenger Seat - Stuck in Recline
- SC430 Passenger Airbag Recall
- Wrong tires????
- Attaching Front Logo in Grill
- Help! Driver Front / Passenger Rear Side Markers
- SC430 Cupholder Disassembly
- Convenient Battery-Charging System Tester
- Rear View Mirrors
- Oxygen Sensors
- The Beauty of OEM (versus Aftermarket)
- Amp repair
- 2002 SC430 interior rear view mirror not working
- Top Opening Issue Fixed... Details Inside
- *SIGH* Stuck on what tires size to buy for my wheels
- Qustionner
- SC430 hard to reach parking light bulb
- Key programming screwed up my door buttons 02 SC430
- 2002 SC430 Dream Changes
- SC430 Key remote housing broken
- Trim piece help - LH bumper / fender well
- SC430 original Nav DVD upgrade or not?
- Trunk Release
- New Car...
- 18" LFA Replicas
- SC430 Door Lock Actuator Removal
- FS SC430 Turbo Kit
- Help with rebuilt 2002 SC430
- Mark Levinson speaker replacement
- New antenna making a grinding noise.
- Clicking or rattle sound in roof driver side rear
- Installing trunk weather strip gasket for sc430
- fender vents?
- Please Assist: Does the VSC OFF button have a BACKLIGHT?
- Unwanted Attention
- My Antenna Mod- Opinions Please?
- 02 SC430 Navigation broke ?
- Resurface rotors?
- 2003 SC GPS issues
- Michelin Pilot Sport A/S3
- Trying to replace battery in ILCO IH3 ignition key
- Need help please!!!!!
- SC430 Antenna Motor access and removal
- D2 racing coilovers really transform the car
- 2002 SC430 Amplifier Removed
- Your Lexus Dealer's Hourly Rate?
- Missed a great deal? :( what do you think?
- Removed front license plate; how to fill holes in bumper?
- SC430 Rear View Mirror Motor Removal
- SC430 Fuse Diagram 2002
- Alarm intermittently sounding
- Side Mirror Questions
- loud buzzer noise behind
- Keep or Sell
- Headlight Bounce
- 2002 AC Climate Control Unit
- Who rides with Toyo Proxes 1?
- 2008 SC 430 - new battery doesn't hold charge
- LHD headlights
- Stoptech brake noise/squeal during initial deceleration. Pads are good. Cause?
- Timing Belt change
- How to diagnose between starter or solenoid as problem?
- Sc430 Lexus dealership service experience (Pending Resolution w/ service manager)
- Really annoyed of the wobbling and shaking.. pls help ?
- Speaker blown - can I just disconnect?
- Window problem
- OBX Headers for SC430
- Center Console Upper Latch
- h&r spacers
- Wiper Arm Removal
- Labor only maintenance
- It's my Cargo Coop
- SC 430 being a future classic ?
- Weapon R Secret Weapon Intake
- Engine, VSC light came on.. any ideas?
- Call Me Crazy .. Restoring Headlamp Washers
- Should I Trade Up?
- Maintenance
- Adding a New Navigation in 06
- Dilemma on Leather Seat Back
- New SC430 Vid on Youtube!
- Steering column
- License plate lights
- Ready for Labor Day meet in Southern California??
- 2002 SC 430 with 53K miles
- revers lights and lcense plate lights
- TPMS and VSC questions on new SC purchase
- The Perfect Car For Me Lexus SC 430 2002
- This is what I got for $2207.38. Your $.02
- Repair Surge?
- Headlight bulbs change need help/suggestions
