Battery drain on a 2002
Old Dec 9, 2019 | 08:27 AM
NOsburn's Avatar
NOsburn
Default Battery drain on a 2002
I do not leave the lights on auto.
I turn off the radio.
Now I just pulled the fuse for the security system and noticed the security light is flashes! There should be no power with the fuse pulled in the driver's side kick panel, right?
Ozzie
Old Dec 9, 2019 | 10:22 AM
GmanSC's Avatar
GmanSC
Leave the light on Auto or leave the radio on will not drain your battery. Just make sure that you turn off the 30 seconds delay. Turn on the security system at night when park in the garage might have some effect. There are two fuses in the passenger kick panel that tie to the mobilization of the vehicle. Check your owner manual.
Why would you want to pull the fuses? Just don’t turn on the security system?
If your battery’s still draining, time to think replacing it.
Old Dec 9, 2019 | 11:18 AM
NOsburn's Avatar
NOsburn
I have a newer battery. This has always had a draining problem, that's why I have started to look at disconnecting things. When I pulled the security fuse the light on the dash strays blinking. I thought it should go out. Can not go more than a week before battery dies.
thanks
Ozzie
Old Dec 9, 2019 | 11:48 AM
GmanSC's Avatar
GmanSC
thanks
Ozzie
How old is your battery? When I had my drainage problem, I thought I had new battery too, then I checked the record, turnout the battery was two and half years old.
I took it back to Cisco and they gave me a brand new one. Yes, it’s sad, the SC will kill the battery in three years.
Old Dec 9, 2019 | 12:18 PM
MH6878's Avatar
MH6878
Cisco? That's life in retirement. 😛
Old Dec 9, 2019 | 01:12 PM
mandyfig's Avatar
mandyfig
Did you mean "Costco"?
Old Dec 9, 2019 | 02:56 PM
DshngDaryl's Avatar
DshngDaryl
Another quirky battery drain is the lights in the trunk. Many people have attributed dead batteries on their SC due to the light in the trunk
Old Dec 9, 2019 | 03:02 PM
DshngDaryl's Avatar
DshngDaryl
If you think you have an unusual battery drain, you can find it using this method
Old Dec 9, 2019 | 04:07 PM
MH6878's Avatar
MH6878
I once forgot to close the trunk all the way, and it drained the battery completely.
Old Dec 9, 2019 | 04:42 PM
GmanSC's Avatar
GmanSC
I too forgot to turn off the dome lights and drained my battery completely. After recharged, the battery only last two days and did not take the charge again. That when I took the battery back to Costco, yes Costco, and they gave me a new one because it only two and half years old.
Old Dec 10, 2019 | 03:31 AM
Hyper15125's Avatar
Hyper15125
I have the same problem, need to find the source of the parasitic draw.
I read somewhere a Lexus tech saying that some of the passenger seat computers were found to be the cause.🤷🏼‍♂️
Old Dec 10, 2019 | 04:21 AM
mandyfig's Avatar
mandyfig
Hence a battery maintainer will help. Every couple of days, I hook the SC. I have those easy connect prongs. All of my cars have them so they are plug and play.
Old Dec 10, 2019 | 05:17 AM
Hyper15125's Avatar
Hyper15125
I got a quick disconnect for the negative terminal, also have the tender. Would be nice to not need either
Old Dec 10, 2019 | 05:20 AM
mandyfig's Avatar
mandyfig
If your SC is not a daily driver, then you will need a battery tender to keep the battery refreshed-charged.
Old Dec 10, 2019 | 07:24 AM
DJWLDW's Avatar
DJWLDW
mandyfig
I have never had that experience. I go weeks without driving the SC and it never fails to start. I have a Duracell AGM battery that is over 2 years old and it is never a issue starting. I have always turned the lights off, shut down the AC and turned the radio off.
Dennis
