- Trans Service
- SC430 Hood Chrome Repair
- Timing Belt Maintenance and Error Codes
- HELP! a/c unit, head unit, and cigarette lighter stays on even when car is off!
- Best Chrome Wheels
- Alignment Issues...20's On Stock Height
- SC430: BackLight message Failure "Error
- what do you think about this lexus 2006 sc430
- Lug Nuts for 2004 SC 430 TRD Wheels
- NAV Screen Acting Up - New Owner
- 09 Pebble Beach listed on Ebay
- 0-60 mph
- Gas Pedal before & after
- EG light on after Resonator delete ?
- Speakers---Thank You Forum
- radio cuts off randomly when cranked up high
- 20 inch Wheel with stock Height
- Lowered and Aligned perfectly??
- Keyless Entry System Problems
- Just bought a 2006 430
- Roof Spoiler
- Twisted Seat Belt
- Problems running bigger wheels?
- aux sc430
- Upgraded sway bars
- What is this? Headlamp chipping
- Upgrading the Mark Levinson sound system
- Need Help in Identifying Right Part #'s
- Moving the front seats back?
- Dead Battery
- Just Another SC430 From Texas
- noise
- Should I paint or replace my wheels?
- [VIDEO!] Sound with no resonator, intake and exhaust
- Garage door opener
- buttons don't work
- anyone running straight pipe or exhaust cutout? CEL on HELP!
- SC430 Custom Exhaust
- i Think Am Losing It
- Top andtrunk
- SC430 turns over but won't start, heater fan acting up too.
- A few questions. Hopefully some answers
- Thompson Park N.J.
- Holiday
- front rim spacers for rohana RL06
- Interim Sound Solution
- Front sway bar - vsc/abs lights
- Infant seat
- Intermittent engine soft fault
- Coilovers intalled, adjustable control arms needed
- Front pillars, A-Pillars removal and assembly problem
- air pump behind radio?
- Paint Correction
- Need Help please! SC430 owners feed me some advice!
- fair price on 2002-2004 sc430
- CD Player
- Lower control arm replacement cost ?
- remote key flakey
- PPE Headers
- Please help me figure out this bizarre major issue!
- Newer SC head unit in older model?
- What are the two wires in the windshield?
- Navigation Door won't open/No sound from speakers - fuse
- Drilled & Slotted Rotors- Suggestions
- How to remove SC430 dash dimmer switch
- From Texas to California--DONE!
- VAIS SLU + Kinivo BTC450 Bluetooth = Perfection
- Newbie SC430 Owner - A/C faceplate question
- OEM shift knob
- Has anyone had car repainted?
- Shift knob
- Happy mother's day
- 2004 sc front seat rear covers
- Parting Ways with SC430 but is this downgrading?
- Poll: how many flat tires
- Passion Vip Guam SC430 build.. Work work..
- Assistance on Changing Springs
- 2002 ML "Surround" Sound
- Compatible steering wheel
- Wallpaper Wednesday: Slammed SC430 at Sunset
- Aftermarket shift knob
- Sway Bar
- Cleaning question
- Oil Change - filter removal?
- lexus sc430 hood latch cable
- Michelin A/S+ Run Flats (again)
- Stock radio issue....help
- Had our SC one year!
- BC Coilovers arrived but missing something i think
- itrade
- i want an sc430
- Cracking/clicking noise from front when stirring wheel turned all the way
- 2002 Lexus SC 430 Getting codes P1351 po302 and c1201
- Q re Nav System
- on again off again
- Ready for Double Din Upgrade--Question
- Pioneer "Nex" lineup with apple carplay in SC?
- Sound Problem
- Thinking about trading it in - talk me out of it
- Farewell..
- Transmission fluid black as night with only 25K miles.
- Too much fluid in trans on 2007?
- Jacking at the rear diff really ok?
- broken door latch cable
- radiator leak help
- Serpentine/Pulley squealing
- Hello
- Newbie Sub-woofer Question
- The good and the bad all on the same day
- Beatsonic - work with power antenna?
- Lowering
- Rotors - Cryogenic treated vs Regular ?
- Starting Car No Sound No Action - What to look for
- Top is stuck partially opened/closed
- Looking for shop to do suspension work in Washington, DC area
- Check your Radiators - Summer is Coming
- Cell Phone Advice
- Ecru Seat covers
- Electronic service manual
- continue worry about my 03 sc430
- Cam sensor wire damaged after timing belt service
- LuxLink Questions
- PIC REQUEST: sc430 with oem wheels on 45 series tires
- Sc430 led taillamp computer/ecu part number? 06-10
- Need Help!!
- Awesome Page... hope you can read Russian!
- Paint code
- Timing belt replaced in 2002 Yes or No
- Joining the SC club this week!
- Vinc's 03' SC430
- Interior Teardown Question
- 2002 SC430 Won't Read OEM Upgrade Disc
- please help, parking brake
- Earthquake country
- Goodbye Navi. Hello Windows 8 os MacOS?
- Time for New Tires
- Please Help Identify Tire Noises
- Aggressive offsets--
- Cargo cover bolt sheared off
- Dying leather seats
- Exterior color chart
- A/C Problems
- 2003 tail lamp upgrade
- 6x9 speaker replacement alternative
- Snapped bolt in block during timing belt install
- Can someone tell me what rims these are?
- vsc light after installing parking light
- Key for 430
- Top wont open
- MPGs - 875 miles
- 03' 430 over heating
- SC430 navigation door problem
- 07 Steering Noise, Suspension Repairs
- climate control green lights 2002
- Fuel injector questions
- Floor Liners for SC430?
- Navagation Voice
- 06 tail light upgrade
- Greddy Supercharged SC430 in progress
- Sell my 2002 SC 430 or fix it?
- '05 SC430 rear spring rate
- Dash Wood trim
- Car battery dead, keys won't unlock driver side door?
- Traded in LS430 for SC430
- Replacing front seats with a more comfortable seat...
- TRD Rear Sway Bar mod
- Stop Tech Front BBK
- 20x10.5 front and 20x13 rear?
- Cost of brake job
- Wind noise
- LED DRL's for Gene
- New SC430 OWNER!
- 05 sc430 wiring help
- paint color question
- new headlights and foglights need opinion
- Supra TT brakes on SC430, few questions..
- Headlight Self Levelling Error
- Clicking Sound from Engine
- Will I phone 5S work with gen 4 2005sc430
- wheel spacer advice
- Driver side door cannot close when window is up
- Oil change & rotation cost
- Gurgling/Percolating Water sound behind dash
- Finally got a good SC430 key
- Sc 430
- SC430 mirror issue
- Carpet fixations
- Best upgrade shocks for 2008 SC430?
- Trunk won't open & top won't drop
- will these wheels fit my 2002 sc430
- Key and immobilizer matching to multiple vehicles
- Difference between 2003 and 2005 SC430?
- Problem with roof - need mechanic in DFW area
- Adding Puddle Lights and Turn Signals
- g35 rear rim fitment up front
- TRD VIP edition chrome wheels
- How do you replace the trunk light?
- Brembo Big Brake Kit SC430 Rear
- Weird Radio Abnormality
- A SC 430 Purchase gone terribly awry!
- VSC Off, VSC, Engine Light: ALL ON!~@!!!
- Rear Ended Today
- New Wheels & Moar Low
- Rear seat trim repair
- What spec of sound deadening material to get?
- Right side front brake works better then left side ?
- Where is the subwoofer?
- Slow response during 1st gear...
- New look to the SC430
- 2din Facia 2004 Sc430
- $35 LuxLink on Ebay -- seems like a new model
- FM intermittent silence one frequency only
- Storms from Atlanta to Albany, from Anaheim to Austin and Beyond
- UK & Ireland & Europe: Looking for a rear bumper.
- heater / fan noise / vibration
- TPM confusion
- Update on the 2010 SC 430
- SC430 Mechanic in West Palm area for Timing Belt Change
- Coolant flush
- seat covers to preserve the ECU leather ?
- Wood panel crack....
- New neighbor... Just moved in!
- 02 Upgrades Air Intake & Cusco Tower
- new brake pads?
- Navi Screen
- foggy windows
- New '03 SC430 Owner!
- SC430 2002 GPS replacement
- Anything can go wrong does....
- Differance between 2002 and 2006
- Amp location
- 19" Tire size
- Avoid Metal Valve Caps!!
- Waterless Coolant
- Antenna replacment Imposible
- Considering Purchasing an sc430 need advice
- 60 Day Review of Lexus SC430
- 2010 Roll Call
- Anyone have a 2010 SC 430 with backup camera?
- Need help from those that shipped cars
- Adios electric antenna!
- Loose battery terminal now cant reconnect!
- Viper + SC430 = TVR
- Vais SL3sat Interface + Tuner Kit
- Snow Tires - Free to Good Home
- I need help from Houston!
- Bulb location on rocker ect switch?
- Switch/Button of Radio Door illuminated?
- LuxLink Question
- Creaking/cracking noise in sc 430 roof
