- Front Brake Pads Replacement
- Front Sway Bar
- Has anyone successfully changed parts/components on the seat heater?
- 2002 SC430 Nav Screen won't tilt or door close
- Side Marker Light Upgrade for $2.00
- Gave in and bought MeisterR Coilovers
- New SC430 Owner Repair Thread
- Cabin Temp
- Lexus vs Infiniti
- Lexus vs infinity- The Debate Continues
- Stop The Top
- Moog end link advice
- reman brake calipers
- Heeey, check out the latest photos of my modified SC430
- Chair won't fold back
- HD Radio
- Ppe headers installed and third cat delete now p0420 code please help
- Just found Club Lexus 1/30/15 at 1:30p
- Bigger Oil Filter for SC430
- GA SC's
- Angel Eyes for Tail Lights - DIY Photos and Video
- selling my 2003 lexus sc430
- artisan steering wheel
- Factory exhaust tips
- New Battery
- Maximum horse-power without stress?
- Radiator recomendations
- water in the trunk sc 430 /04
- Door Sill Scuff Plate - DIY Upgrade and color change
- Is your steering effort . . .?
- How do you adjust the reversing sensors volume?
- Coasting in neutral...
- Cabin temperature control failed...
- Who has spent the most on performance mods?
- Matte Black Lug Nuts
- Need Help Inside wear on Rear tires, strut selection, other issues
- Pricing on a 2005 Lexus SC430
- Minnesota in January... And my SC430 is the PERFECT family car!
- DMV (D.C. / Maryland / VA) members
- New Member
- Seat wiring connections SC430 2002
- My wife's 07 Pebble Beach Edition
- Daizen control arm bushings?
- Ride Height Sensor Failing
- Reverse full lock wheels seem to slip
- 2003 Bluetooth options
- Greetings from New Zealand
- Moog End Links, Gs300 front sway bar, Daizen Steering Bushings, and isf rear sway bar
- Broken Fuel Vapor Feed Pipe
- Poll - how old are our SC430 drivers?
- SC430 Ferrari kitcar OMG!!
- had the car for two weeks and need some help
- Lexus 1C0 color and toyota 1C0 color code question
- My new SC
- Trading SC430 for IS350 Convertible
- Lexus SC430 2002 keys won't start ignition
- Glovebox and floor lighting
- ISF Rear Sway Bar Review
- Let's just hope she wasn't a Club Lexus member!!
- Is it worth it?
- Tom's Lower Brace
- Mod Binge- Cusco Bar too?
- updating my 2007 SC430 Pebble Beach Edition
- Do stiffer suspension upgrades improve track times?
- New member : please help vsc/vsc off light/ans lights r on
- New TPMS
- You Guy and Ladies
- Can't get factory jack out of trunk??
- Are Factory 84 month Warranty Lexus Batteries Sealed?
- Model Year that glove box changed ?
- Flushing power steering fluid through return line and installing inline filter
- havent been on a while. progress
- 2007 SC430 Pebble Beach Edition (trunk struts issue)
- Stupid Question- Harness below Cup Holder
- personalized tags
- Changing Brake Fluid
- New Member
- Seat belt light
- Engine Mount Replacement
- Electric seat
- Help with Front Sway Bar, end link, and bushing selection
- Happy new year
- t stat
- isf sway bar installed
- Q: installing the Cusco front strut bar...
- So Many New Owners
- picture sc430
- Methanol injection
- Another New Member
- new to forum
- SC430 New owner, intro and build thread.
- Shopping for 2002 SC430
- replaced ECU, but car won't start. Now what?
- Funny Where You Spot An SC430
- Rear sidemarker bulb change DIY
- newcomer
- Headlight Bulbs
- DIY Tail Light Removal
- On Headlight Upgrade Did Something Dumb
- NEW Member
- For those that have upgraded their SC430 head unit..
- Questions about Supra BBK on SC430
- Brake Job Completed
- New/Old Member
- New 2005 Lexus SC430 Pebble Beach Edition Owner -- Some Questions
- The Three Wisemen Cometh...
- New member. 2001 SC430
- Happy Holidays
- SC430 on my wish list!!
- Installing a accelerator pedal boost controller
- 2005 Fog light bulb replacement
- OBD II scanner
- P0308 because vacuum line disconnected?
- Rubberizing the undercarriage
- New Owner 2004 Lexus 430 SC
- Spiral Cable/Clockspring 2005 Lexus SC430
- SC430 Battery Drain
- Fender-Bender, your opinion....
- Anyone in the KC area?
- New sc430 owner
- How to disable red markers on the sides of rear bumper
- Car will not start. Any help appreciated!
- Rolling Marble Sound near windshield
- Can anyone recommend a good OBD code reader?
- DIY Bumper Drop
- Top End Speed
- CEL Code P1351 & P1354 SOLVED - Engine Variable Timing Solenoid
- Battery Charger / Maintainer Question
- Please help---struts for 2002 sc430
- Dome Lights LED Conversion - No Kit
- I bought an SC... one that this forum knows...
- When to drive with the Top Down
- Perhaps the most ugly cold air intake ever made?
- Quietest tires for sc430 on the PLANET ?
- Need info on ribbon pin count on levinson unit
- Stainless Lexus scuff plate on door sills
- Need Advice: PPE Header Install and Possible Flowmaster Cat and/or 3rd Cat Delete
- Cheapest way to get air suspension?
- Gasket for Fuel Cap?
- noise when turning key to put electric on before starting engine
- Shifter/Power Switch/VSC Switch/LED Mod
- Thanks to you all, just bought my first SC430!
- 2002 with 53K miles .. what would you do ???
- 02 bad
- Changes to SC430 after 2006
- How to degrease/clean engine bay
- Service/repairs near Frederick MD?
- Seeking new bumper for SC430 (2005 - blue)
- DVD music in the stock system?
- Replacing Low beam headlight bulbs w/LED
- Aimgain lowballers_sc430
- Concept Roadster
- Have a good Thanksgiving!
- 1st Snow Ride!
- Lbintab intro and build thread.
- Thinking about buying an sc430 but it has issues need advice
- Spare Tire mod
- Key Code where to find...
- Tire won't come off
- Car Play
- Where to find/order Blitz exhaust?
- My JL Audio Upgrade
- Solar Powered Battery Tender
- Group buy beat sonic mva-12l 02-05 sc430
- AC Problem only one side blows cold
- Trick to seeing speed odometer numbers better.
- Winter Tires for the SC430
- Volume 3 of Service Manual set
- Techstream TIS with SC430 - Key and TPMS Programming
- What's the resale value of my SC430?
- Keyless entry & pushbutton start addition
- Looking for shift surround replacement part
- Swapping 2006+ headlights into a 2002?
- Amazon roof spoiler
- SC430 Wind Noise
- Transmission, How do I get a harder quicker shift ?
- Is SC430 or Lexus IS model better sports car ???
- Worst car of all time?
- Opinion- Best Wiper Blades
- Front Seat Backs and Upper Trim
- Moldy interior Leather?!?!
- Seafoam Into PCV Valve DIY
- Looking for this TRD wheel
- :d
- High Flow Fuel Injectors
- Patience, patience, patience
- Hesitation, throttle down-blip, lurching, cut-out - need diagnosis help please!
- Is there an engine management system for the sc430?
- Brake light flashing in my cluster
- First Roof issue in 4 years, can't find in search
- Advise to buy 2008 SC430
- Front tire slow leak due to corroded wheel??
- Blanking upper part of rear taillights
- Can you say Two Tone Interior???
- codes
- BASS w/o install of speakers. Use Tactile Transducers AKA "BASS SHAKERS"
- SC 430 BIG Bass Install with existing levinson system
- Technique for removing interior A pillar trim?
- 02-05 and 06-10 headlights...same lens?
- Gone after 14 years
- Tech Refresh - Double DIN Beatsonic vs VAISTech, NavTools, Grom
- What is the most popular SC 430
- Jacking up car for just one wheel...question
- Front seat warmer switch
- Anyone with 50 series tires on 18" rims ?
- Brake pad question
- Castor/lca #2/trailing arm/radius arm questions
- More on Sway Bars..
- What kind wheels are these?
- TPMS SC430 reset tool
- Lexus sc430 Rear Brake Pad Replacement with Pics
- How to use CL discount at Sewell?
- Help Identifying Part and Purchase
- Transmission question
- Too much Lexus?
- 50K miles, 12 yr old=when to change timing belt?
- "Clock Spring" Replacement
- Switch Plate
- Lexus LS430 vs SC430
- Side rear windows
- Bitten by the NSX bug... Help me price my PC SC430
- Need help codes p0101 p0102 on 03 sc430
- Tire Pressure on All-Seasons?
- Help with Compact Spare Tire
- sc430 Coolant Temperature Sensor Location
- Looking to buy SC430
- Making my car battery charger friendly
- Pin Diagram for Roof ECU?
- Followup " your valued opinion"
- Help finding rear shocks for 2002 SC430
- Finally replacing the SC430
- your valued opinion
- Anyone upgrading the power on their SC430?
- Radio upgrade
- TRD chrome VIP wheels....hard to find
- Pirrelli Sottozero Winter Tires- Review and Initial Impressions
- Describing difference a front strut bar makes...
- Takata Air Bags
- How are your cars (especially the tops) holding up?
- Gold Lexus Ebmlem Vanity Plate
- Top Failed When Opening
- Lexus Meet up
- Converting my '03 SC430 to an '06-'10 Pebble Beach Ed. **PICS!
- Loose Rear View Mirror
- Good NEWS guys! Paddle shift / E-Shift for the SC430 ........... almost
- Should I get this fixed?
- Replacing the back seat bottom with deck
- Is there a Difference in Non OEM Pads & Rotors 03 SC
- Timing Belt Changed...
- Open/Close Roof Switch will not even blink
