Antenna mast replacement
Old Aug 17, 2019 | 10:19 AM
tagsclan's Avatar
tagsclan
10th Gear
Default Antenna mast replacement
Went through the car wash with antenna up! Found instructions on replacing:
What you have to do is, with the key in the ignition switch "LOCK" position, press the "AM"and "DISC"buttons on the radio simultaneously with turning the ignition switch to "ACC." Then the radio"LCD"display will read "ANT"and the antenna mast will hyper-extend, disengaging the cable. With the ignition switch still in "ACC," the new cable is inserted to a full stop into the motor antenna assembly through the mast pipe hole in the body panel, with the teeth on the antenna cable toward the rear of the vehicle. Then, as the person in the driver's seat switches the key to "LOCK," feed the cable and mast pipe in. After it retracts completely, replace the retaining nut.
The only issue is "ANT" will not show on the LCD display and retraction is not fully extended. Any advice?
Old Aug 17, 2019 | 12:34 PM
VVTiBob's Avatar
VVTiBob
Here is a copy of the actual TSB in case you don’t have it. https://www.clublexus.com/forums/att...eplacement.pdf
only advice try again following the TSB
Old Aug 18, 2019 | 02:00 PM
tagsclan's Avatar
tagsclan
10th Gear
Default Antrmna
Thank you. That is the document I was following, still unable to see ANT when it extracts. It does go in and out of the track without difficulty.
Old Aug 18, 2019 | 03:28 PM
VVTiBob's Avatar
VVTiBob
I would check the length of the track on the new one versus what came out of the broken one. If they are substantially different some of the track may still be in the housing.
Old Aug 18, 2019 | 03:36 PM
sippy2's Avatar
sippy2
Read my post in the other thread below..works like a charm.
iolmaster
Feb 2, 2024 03:48 AM
vicSC400
Oct 8, 2021 09:52 AM
friarush
Apr 23, 2015 10:28 AM
jmjatlanta
Apr 25, 2011 05:53 AM
CPerez100
Dec 2, 2001 11:33 AM
