- Maintenance Required
- timing belt changing
- Crazy car experience / alternator?
- Just Saw a nice 07
- subwoofer not working :(
- We're going to need a new forum
- Which way to go for BT streaming and reverse camera
- Windshield Tint Strip... Does it Help or Not
- Will this size wheel clear...?
- 2004 sc430 maintenance manual
- Front speakers
- swichbacks
- Steering Wheel Shake
- Shhh! Don't tell her but i think i'm doing it!
- Phone Contact Transfer (MERGED THREAD)
- Oh my gosh
- Adding HQ Bluetooth to 02-04
- Mass Airflow Sensor - Need a mechanic LA
- Rear Wheel Drive?
- Time for a new rack and pinion
- Intermittent paint smell in A/C
- Timing Belts
- Foggy Nav Screen
- 2008 sc makes odd noises
- Saw a Nice 07
- Conditioning the rubber seals
- Do stock Rc350 Fsport wheels fit 2004 Sc430?
- 2002 SC430 - Constant Tension Spring Clamp for Radiator Hose
- Differences between sc430 in different markets? (USDM, JDM, EUDM, etc)
- Transmission Rebuilt at 180K miles
- 2003 SC430 Need Part number for engine intake/vacuum hoses
- Trans slipping
- Oxygen Sensor
- Wrap
- Considering going to an express oil change.. Thoughts?
- Could it really be......
- Daughter and I stopped for a mini photoshoot
- Lexus Driver Webpage
- Thinking of buying a SC430, question about paint codes and facelift.
- Engine light bulb was ripped off
- Driver's Side Sun Visor has Slack
- Nav update
- Anyone installed ambient lighting in their SC?
- 05 diecast impulse buy
- Trunk Access
- After all these years ..
- Techstream help
- Ideas for backseat delete?
- 245/45/18 tires
- Cost of alternator replacement, parts and labor???
- used 2002 sc430
- Replace ML amplifier with aftermarket unit?
- Lubricating Roof
- Does this graph show acceleration accurately?
- Pristine '02 with 22K miles sold to dealer for peanuts
- ABS Wheel speed sensor
- Wheels
- Boosted initial acceleration?
- Air Conditioner not cooling
- 100 vs 130 amp Alternator
- Considering SC430 - How common is top issue?
- Interesting thought, converting top to manual
- Flat tires
- My favorite NAV screen mod
- Replaced Marker Light, now reset?
- Bluetooth cassette question
- Wheel Offset Help
- Replacement headlights 2003 SC430
- How long do TPS ( Tire Pressure Sensors ) last?
- outside temperature reading on climate control
- Suitable Aftermarket Subwoofer
- Battery Replacement: Today's AGM vs non-AGM
- Wheel noise
- Back with a vengeance...
- How many left?
- Retain top NAV Screen with iPhone integration
- Wiring Diagram
- Retain Factory Naviagtion with aftermarket Radio ??
- New Member 2002 SC430
- SRS Light On - Need Occupant Detection ECU
- For all the heroes who gave their all
- Need half car cover as pictured
- Memorial day sale Parts
- Creating a pebble beach
- SC430 Custom Project
- Front and rear suspension question...LCA front . Any rear suspension issues?
- Finally purchased a 2005
- New Purchase
- large curve/hole at bottom of windshield
- Drop top kinda day
- Bluetooth Question
- Buzz from dash
- 2003 sc430 top open will not close
- For Sale items go in the marketplace only
- Checking transmission fluid
- Control arm installation: source of clunking?
- Volume control
- Broken Windshield replacement needed + Injen Tech
- Wheel Color Changed... What do you guys think?
- Navigating threads on Club Lexus - TIP
- Do you own VIN ending in 4956?
- inexpensive sc430 passenger side headlight
- For those wanting power - 2JZ + M/T swapped sc430
- left rear wheel locked
- Another 'buying advice' post
- Techstream Help
- Battery Draining (2007 SC430)
- my upgrades
- Trunk panel removal
- sc430 mute turn off
- Should Upper Control arms be replaced in Pairs?
- Top down or up in garage?
- Slight knock noise when turning car off
- Rear wheel speed sensor connector
- SC430 Headlamp Bulb Replacement Video
- Rear Bumper Damage (pulled bumper off to take a look)
- How to remove fog lights
- Changing Headlight Bulbs Video
- Bumper removal
- Rear Bumper damage !
- 2002 bumper clip
- 2gs lowering springs?
- SC430 ground point
- What time is my nine o'clock appointment? (Service manual question)
- Another SC dead battery story
- Roof adjustment help
- Rear strut alternative maybe?
- Failed inspection - 2002 SC430!
- Tires
- Performance Mods
- plastic grate w/rubber flapper in rear bumber cover
- Hey Bob (or anyone else) What part do you think I need?
- Need help locating a part for my sc430 r/s rear package tray
- photos of spoiler-less 430s?
- Listing my car in classified
- Weird sound coming from next to Nav screen
- SC430 roof hardtop won’t close
- SC430 Interior Hydrodipping
- any Chicago owners?
- Wiper “Popping” Noise
- emblems / logos / badges
- Headlight Clip Help
- My Addictive Hobby
- skid control ecu
- After 17 years, is the SC 430 Dated or Classic looking?
- How Many Have Original Window Sticker
- Just bought an sc430.. Wanna answer some noob questions?
- SC430 Paint Colors and Brochures
- Sold our SC430
- 2004 SC430 Interior Leather Color
- 2004 SC430 Fuel Tank Problem?
- 2004 Lexus SC430 black third brake light
- new SC owner- timing belt?
- another SC430 owner
- Programming door locks on a 2002 SC430
- TPMS: Favorite Subject - Can't disable it
- Vibration at 60 mph ?
- 2002 front seatback parts
- When is the next SC430 car meet???
- Is it necessary to lube hardtop
- ceramic coating
- Interior lights
- steering wheel radio control
- What's up with the new IS350 Rims I put on my SC430?
- Transmission leak :(
- Power steering stiff
- SC430 Front tires with 10K excess outer wear
- DRL Light LED Help
- Nav-Screen
- Net
- Master key question
- G Spyder Color Question
- Headlight replacement for a 2004 SC430.
- Rats ate Engine Wire Harness, need help!
- Lexus sc430 180k question buy
- AFS Warning light
- Convert from gas engine to electric motor
- my rare 18 inch trd rims factory lexus rims
- speaker positive and negative
- Fitting ABS reluctor ring
- What Years of SC 430 had folding outside mirrors
- Anyone know a vendor that carries the Megan cat back exhaust today?
- How to build a Lexus video
- Does Anyone know ...
- Naviks: Sometimes you just have to close the trunk and start over another day...
- Sc430 ENTHUSIASTS: is this a good deal?! Please help a young female!
- Help installing beatsonic In SC430
- Bimetallic corrosion
- SC 430 amplifier load balance
- Replacing Mark Levinson amp in 2002 SC430
- taping into a vss
- You forgot to say 'why', re. synthetic?
- Searching for Allen bolt size - timing belt idler pulley
- How Hard Is It To Remove passenger side outside mirror?
- Jis screws
- What is a OEM Power-Point Storage Kit
- knob
- My 2004 SC430 on Autotrader
- Brake procedure
- Short term removal of one wheel
- Oil change - low clearance
- Big discount, 1/2” x 24” breaker bar, Pittsburgh PRO, Harbor Freight thru 11Mar19.
- seat belt guide
- Replace All Speakers - Will This Work?
- Replacement key for 2004 54 plate sc430.
- Take Exhaust Muffler Resonator out
- Exit assist. Power seats
- Help!?!?
- I found a Freeloader today...
- Limited edition SC430 Beverly Hills Special Edition/ Tiffany & Co.
- Led “Lexus” door lights?
- radio door does not shut
- Wheel Caps - Satin Bronze
- Not a fan of the pizza wheel, nor the twisted star, nor the 5 point...
- Looking to Replace Runflats with Non Runflats
- 2003 sc430 gearshift light
- RE:Need help - - check out the car in Columbus, OH 43235
- The 15 Vehicles Most Likely to Last You 15 Years
- Search Issues —— NOW FIXED
- Trunk Carpet Question
- Radio Headunit
- Horn not working
- 2006 SC430 TPMS Sensor Colors?
- Light Blue SC
- D2 Coilovers - ride and drop experience?
- Is Amazon Basic Synthetic Motor Oil as good as Mobil 1?
- Replaced run flats with straight pneumatics
- SC430 Nav System Replacement Options
- Re-covering Front Door Speaker Covers/Grills
- Long time lurker....checking in to say Hi!
- Did you see this new wheels video
- SC430 Roof Rack
- Anyone try these?
- Which one would you buy?
- Do our cars have grease fittings for a traditional lube job?
- matching wood stain
- SC 430 drink holder
- They Are Still Out There
- Infinity Scroll... not a fan.
- What Stops a Computer from Getting on Club Lexus Web Page
- Does the LC = the Supra = the Z4?
- Low Washer Fluid Light?
- Navigation Screen pinouts
- naviks suggestion
- Torque wrench for timing belt project?
- We made the list!
- limited sound output
- help with timing belt
- Seat swap?
