- Re Extended My Extended Warranty
- I did a knuckle head thing.
- Clock won't shut off after installed SLU
- light bulb size
- Newbie
- Why oil change at dealer?
- Disable headlight washer?
- CD player doesn't like burned CDs
- Camber correction kit?
- TPMS light came on
- Interior Cover?
- Cup holders
- OEM Exhaust Manifolds Back On For Good
- Where to get used parts?
- How to Delete Current Destination w/ Navigation?
- Replacing the driver door lock/cover
- Ticking Sound when cold
- Training the Nav Lady for better accuracy
- Can I add Blue Tooth (BT) to my 2003 SC 430?
- Lexus SC430 Drift Car
- favor request for the Brake DIY'ers!!!
- Factoid For 2002 First Year Model Owners
- need to check wheel fitment
- Water Water Update!
- Wheel swap
- 05 SC430 Bluetooth queston
- Guess That Mod.
- ecru to blk few pics
- Just some random pics
- SC430 a Rust-Bucket?
- trunk struts
- daizen anti sway bars
- A sc430 hopefull!
- SLOW outside temperature -- normal?
- VSC/VSC OFF/ABS Indicators
- Possible to Open/Close top at Very Slow Speeds?
- ecru, different colored mats?
- Location of VSS or Speed Pulse wire?
- Steering wheel button module
- Replace Yellow Wood With Dark Wood
- 120K mile service -- help needed
- Doors automatically lock when shifted to "D"
- Lux link Installer wanted
- Where can I buy the parts cheaper for repairing my sc430?
- SC430 needs a bra
- Plz, I need some Info T,T on non working convertable
- iPhone Interference?
- tire pressure sensor
- New SC430 (with pix)
- 265/30/19 tire on a 10.5" +29 wheel?
- My SC430...a gift that keeps on giving
- Gave car a good clean - Lots of pictures
- Need Opinions on the value of extended warranty
- Did the dealer use synthetic?
- XM Radio install
- Doors Lock Automatically When the trunk is open
- Looking to buy an SC430, Getting rid of RX300
- Broken ashtray door
- A 'Thank you' from a new owner.....
- Jack points
- where can I find a front driver seat ecru?????
- Used parts wanted
- Tom's Roof Spoiler Question
- nav reset?
- You Light Up My Life??
- Which rear bumper can accommodate quad exhaust?
- Pics of my SC430...finally with some mods
- Seat bracket?
- Gas Mileage on SC 430
- Warranty Service at Dealer or ?
- SC430 Common Problems, if any?!?
- brake pad spring pic please!
- Some Photos
- Roof bumpstops whats the trick
- Nav Touch Screen not working?
- Washer Fluid dripped in the trunk??
- What do you think of Drill Slot rotors?
- sc430 wheel bolts size
- Metal Shavings
- What springs do you recommend.
- LED Clear Corners & DRL's
- Water Water Everywhere!!
- What kind of lowering springs do you recommend for the SC430
- camber kit??
- Windshield Washer Fluid Tank.. Need some help
- finally got some pics
- Will rims off a Nissan 350Z fit Lexus SC430
- Donz 20 " rims offset ?? Is mt set up OK
- What is the offset for 02 Lexus SC430
- Thoughts on this wheel setup?
- 350Z or G35 exhaust installed on SC430
- Looking for clear bumper lights for SC430
- Trunk Lid Scratches Bumper on Top Down
- A/C Light Flashing... No Cold Air
- Lexus Roadside??
- Which model year of the SC430 do you deem best?
- Can too much air be a bad thing?
- TEIN Flex for the SC430
- Sc430 & Pioneer AVIC-Z3
- The IS Folding Hardtop Convertible is on its way
- Valve Stems for SC430 rims
- Problems w/Iforged wheels ??
- S&S Headers
- To buy or not to buy, . . .
- hit from behind, now roof won't open???
- Need Help! Radio-vol/bass/tre/mid/fad/-will not move.
- Oxygen Sensor Removal
- 2002 sc430 does it have the baby latch system?
- American Specs vs GCC specs
- Blacked-out grill
- Almost finished
- My Best Friend = UPS ! :)
- Houston we have a problem!
- sc430 radio/cd player defect
- For you SC guys...
- Broke the Climate Control Display Cover
- Lights stay on even if car is off
- stock electronics recap
- Painting rims
- Slow dead steering
- 20x9 Front & 20x10 rear Lowenhart BR5's
- Abandon My Lexus? Or Wait?
- Lexus SC430 Print Brochure Archive
- I'm in LA. I'm lowering my car. Can someone recommend a $$$reasonable$$$ place to go?
- Heater sensor 2 band 2
- Levinson CD Changer
- Which wheels do you prefer
- Getting Thirsty??
- Aftermarket Reverse Backup sensor install
- Do you have wear marks on your nav screen?
- Lowering Car need Advice
- Front Suspension Graphic?
- What's the best battery replacement?
- Plugging run-flat tires
- Clear Corners
- 2009 SC Pebble Beach Edition
- Removing the allen bolt from the pie plate wheel cap?
- Synthetic Oil
- P0155 Oxygen Sensor
- ECT- Power or normal
- Drilled/slotted rotors question
- brake clunk specific question.
- Visor Plastic shaft Broken
- Navigation Hood
- Window Problem
- Off Set for Rims SC400 Rim Fit on a SC430
- will these wheels fit?
- stock runflats, any value or just toss them?
- Aftermarket rim suggestions?!
- NorCal SC430 "Drop Da Top" Mini-Meet Poll
- Telescopic steering wheel squeals
- wheel offset 40 vs. 45....any big difference?
- Anyone Want To Swap Their Wood Trim?
- autocouture kit
- pie wheel cover alternatives
- Are there any wrecked SC 430's out there?
- passenger seat won't recline
- Lexus Serivice Day- Post Warranty
- Help with spoiler?
- Long Term Purchase...Good Idea
- stock to drop???
- Digital Gauge Cluster
- Only in Las Vegas (I hope)
- Ride Quality with 20" Wheels
- What shocks for Tein S-Tech springs?
- Rattling or Sloshing?
- Hubcentric Rings
- Extended Warranty Query
- NorCal SC430 Mini-Meet?
- iPod in an '06
- Quad Exhaust Pictures
- New guy has a question.
- New Model
- Rim Rash Fixing - Note to PB Owners!!
- Quarter window mod part deux
- are coilovers an easy install?
- Non runflat tire opinions
- Wood Navigation Cover.
- Job Design Rear Bumper
- Auto Retracto Antenae
- How is the market for sc430 these days?
- Staggered Tires Sizes For The Sc 430
- Automatic Windows
- candy red 05 sc430 with 20" staggered
- Dents in Roof
- Cables/Connectors above front wheels??
- Rim Scuffs-Fixing & Color Matching for PB??
- '02 with Loud Popping Noises and Volume High on Radio
- Ls & Sc Tranny
- Audi or SC? Pls help
- Differential fluid replacement?
- Transmission Shifting Prematurely
- Ebay chrome grille kit
- Little known tips/tricks for the SC430
- big problem help
- Run Flats And Its Options Query
- 2008 Golden Almond SC Rookie Question
- Run Flats Out/Sumitomo In!
- Windshield fog
- Speech Command System & Lexus Link System
- navtool issue big time.
- Sc 430 Driver Seat Problems
- Emergency Tire Inflators/Sealant - Damage TPS sensors?
- Will this spare tire fit my car
- how much should paint protection cost?
- Brake Pads/Serpentine belt DIY
- Visors shake during top down driving
- almost finished
- Roof opening closing problem SC430
- How bright is your Nav & Instrument Display?
- Bluetooth Handsfree Car Kit for 2002 SC430
- interesting scenario
- Miles and Metric in the Maintenance Schedule
- Replaced 2 rear Tires and VSC is Activating!!!
- Door Panel Removal
- 06-08 Wheels
- AC condensation Drain Plugged?
- Eletrical problems?
- Got my Rotora BBK 6/4 pot
- coilcovers
- Conversion from U.S. to Metric (Canada) Options
- ran flat without runflats for two months!
- White car. Black wheels. Thoughts?
- Vertex Digna Kit
- Rusted Rotors
- Trunk Hard to Open - is it the Struts?
- Door windows rub against roof
- Replacing break pads in 04' SC430
- finally
- Where does this go?
- Traded in 05 SC 430 for 08 Corvette
- 20"
- srt
- radio problem (weak signal)
- Need a little help from SC430 owners
- Changing the antenna
- ODB-II connector and protocol
- Update on Replacing SC430 Trunk Lid Closers - Struts
- Are headlights covered under CPO?
- Whats the best deal, 2002 with 65000 or ?
- 30K Fluid flushes on a 05
- 12000k
- NAVTOOL- Did a little searching around.
- 02 SC430 wood kit (CHANGE)
- 4.2 ver navi
- Nav system upgrade.
- Cpo Question
- How Wet is Too Wet?
- Streaks & Squeaks: Window Streaks & Steering Wheel Squeak
- Finally some pics of my SC430 & some other cars.
