- Navigator seat rimote contorol system
- Suspension upgrade completed
- About to get new wheels and tires
- Supra Brakes Added
- IS-F or SC430
- Welcome
- I've been thinking...
- tire suggestions - couple of variables
- Retracting Streering Wheel Creates Noise
- Is Dealer service a complete waste of money?
- help me identify this clicking noise
- 2004 SC430 VaisTech SLU Issue
- 12mm offset?
- can toyota check my car for recalls?
- Closing Door By Pushing on Glass Window - Causing Damage?
- Replacing carpet grommets, and water under the carpet?
- gps calibration after nav tool install
- Is it wrong to horde 05 PB's? I just got another one.
- Toyota Dealer.......Really?!?
- Battery Problems - Again
- Newby Affair
- Video and photos of summer setup that I promised.
- 2002 SC430 2JZ-GTE Twin Turbo 6 Speed Build Thread
- Opinions Needed - 2006 Model
- ECU/ECM interchangeable
- Do Sage RCAs lower your car?
- Trunk/strut ??
- Is there a menu of choices when it comes to suspension fixes?
- Sc430 Seat Memory Initialization Again 6 replies to this topic
- Four very annoying rattles.
- Left front side lower than right side?
- My sc is dead please help
- I decided to switch it up a bit..
- Daizen Steering Rack Bushings and Bleeding the brakes
- Bought a set of 07 SC "5" star wheels for my 05 PB...now what? ideas? photoshoppers?
- Coming Soon
- Good Tire Deal Or Not ???
- Bilstein update
- SC430 vs. IS350 - A novice comparison
- Should I buy?
- SC with 18-in 5-Spoke, Chrome
- Can i use aftermarket speakers on a 2002 lexus sc430
- Needing New Rims
- My SC430 Feels Less Stable, Bouncy, When Roof is Down
- Open navigation surgery
- PPE Header Group Buy Petition! Who's Down?
- turn3 sc430
- Need Help on Passenger Seat Belt Install sc430
- Impossible Choice!!!
- Navigation Destinations Are Off by a Block
- SC430 Drifting with Top Open
- Need Hood 4 My 03 Lex sc430...plz help
- 250K Mile SC430 Gives Me Confidence
- swift springs
- Sticky This: How To: Build and Hardwire an Auxillary Input to OEM Stereo
- nav tool dvd/ipod?
- [Video] SC 430 High-Riser Does Burnout in Japan
- Sadly one less 04 PB on the road...
- Thinking about a 2002 Lexus SC 430
- H&R springs
- Recommended installer for LuxLink and VAIS in RI or Southeastern MASS?
- Improve my 0-60 2002 SC430
- Need help finding this rear bumper piece!
- Weird tyre noise
- LED tail lights?
- Buying new rims help!
- How to get to Bucketseat speakers?
- Hit Unpainted Speed Bump @ 45 MPH, Car Now Idles Strangly
- prepainted lip kits
- Center console part number / replacement
- What is this plug for?
- sc 430 spare tire
- Quarter Mile Results for my 2002
- Front lower control arms replacement quote
- Need One Used Rear Shock
- sc430 rear seat belt removal assistance
- Looking for a SC430 nose
- Service Cost and Timing Belt
- Cracking Sound Behind Vents when Accelerating Cold Engine
- 06 SC430 Silver Paint Code?
- Lexus SC 430 Cold Air Intake - 2005 +
- Warming Up Engine Prior to Driving SC430?
- Battery drainage cutoff
- Rear Strut ballpark price for 03 SC430
- Daytime Running Lights Flickering Very Slightly
- Pebble Beach
- To buy or not to buy? One or the other or neither?
- Misfire issue 3UZ
- VSC Lights Turn On Only When I Drive
- Check Engine - Evap Emission Control P0440 & P0446
- Lower Control Arms
- Upgrade car horn
- driver's window acting funky
- Lift supports, speakers, and antenna repair
- Control Arm Bushings Lower
- Floor Mat *****? :o)
- Headlights
- Wiring Tailights
- Transmission filter... to change or not.
- Gasoline Smell in Cabin
- Thanks for the great info!!!!
- Temp Needle
- Does Seth McFarlane drive an SC430?
- Phone and Nav Override = Done (teaser)
- Radio cutting from left to right
- I'm back.....
- Foglight Bulb Burning Out Often
- Glade To See So Many New Guys & Women
- Navigation Screen tilt mechanism
- Megan racing coil over install
- I joined to solve this mystery
- Will rear side markers fit up front?
- Ticking Metallic Noise from Under Hood
- Replace ML Radio option
- Anyone know where the Bluetooth / Phone "box" is located?
- Tire Pressure
- Exhaust system
- New antenna making grinding noise
- Techinfo manuals
- Rear spoiler
- Need Assistance: Interior Carpet & Speaker Covers
- ECRU color touchup paint
- 2006 sc430 sway bars are they made by anyone?
- Please place all FS and WTB threads in the classifieds.
- Speaker check
- Do V8 Engines Last Longer than V4 or V6 Engines?
- Squeaks from Roof During Turns
- Any sucess on importing Iphone 3g into 05 Bluetooth?
- Toyota Forums
- evap vapor canister problems...
- SC 430 vs. 2004 TL
- Navigation Unit 2002 Black Black on Black
- beatsonic nvk-01 nav overide kit
- Seat Heater: seat only or back also?
- Getting new wheels, looking for opinions
- Another version Side Marker Installation
- ? regarding credit card keys.. ?
- Rear wheel bearing replacement
- My SC got KEYED!
- need advce--getting ready to sell and not sure what to fix
- fsport intake from a 2IS
- passenger door locks dont work with remote
- Beat Sonic NAV Bypass kit Review and DIY PDF
- Do 2GS sway bar fit on SC430?
- Bilstein Dampers
- Car drives 10 min/7 miles daily each way. How often should I change my oil ?
- Newbie - Just about to pull the trigger on a 05 PB
- Audio shop in Houston
- Replacing radio antenna
- Warm air on driver's side from console
- What is the difference between your analog speed (speedometer) and digital speed?
- Rear Axle Seal Replacement
- Ordered my air suspension!
- Independent Lexus shop in the Bay Area?
- Radio replacement
- 2002-2005 and 2006+ body variances
- How can I get Bluetooth to re-scan after connection failure without re-starting?
- ?Special Edition Models and Number
- TPM lights and whistles
- Happy Lexus SC Owner
- First snow fall in new jersey
- I wouldn't recommend this
- Hello All.. newbie to this forum
- Time to move to another vehicle
- Little bulb in headlight housing?? (2006)
- 20 inch wheel question
- How do you clean the inside of the rear window in your sc430?
- Steering wheel shakes when I step on the brakes at 50mph
- 430sc
- stereo cuts in and out in SC430
- Front door speakers replacement SC430
- Wheel Touch UP Paint for 2008 Pebble Beach
- Entering data while in motion
- Air intakes
- I am Liberty Vip
- valet switch location
- Oil Change Procedure for SC430
- you know those wheels on ebay?
- Help with wheels
- new owner 08 430 service manual
- Radio antenna problem on 02 SC430
- luxlink starter
- 2002 SC430 TRD wheels
- Vossen cv2
- NHTSA TSB Advisories for SC430
- TPM Yellow Light 2007 SC
- Blown Fuse
- Got the first ding today....Damn !!
- LuxLink install - Need Help!
- Top Down in January... IN NEBRASKA!
- P0446 0441 and 0440 CELs
- How long did your battery last?
- Has anyone ever replaced driver-side downstream O2 sensor?
- New owner 2006 sc430
- Name that body kit!
- New 2006 SC430 owner
- Bluetooth question
- Rear tailights
- Tire Rotation - 2 brands/types....?
- KEY LOCK in ignition
- New SC430 Owner and New to this forum. O2 issue
- NEW Owner 2002 SC430
- Loud Sound from Rear on Bumpy Roads
- Help with the rear window mod and remote retractable top?
- Reflash ECU?
- Custom Bags for SC430 Trunk
- Got Nitrous?
- Closing Audio System Door with Casette Input Adapter
- ECRU Floor Mats Cleanup
- Look at the mileage on this one
- O2 sensor replacement (top)
- Headlight removal
- Your opinion please. Thanks
- Happy new year
- Installing headers and Mods
- Front Seat Covers
- Considering a high mileage purchase...
- Anyone receive their "Hottest Lexus Calendar" yet?
- New SC430 Member with questions
- Replaced Speakers - Old Speakers Looked Fine, but Sounded Aweful
- Dealer Service Versus Private Garage Service
- Joe Vick's DEALERCAST Lexus SC430 with TRD SUPERCHARGED Toyota Tundra 5.7 3URFE V8 Bu
- big brakes upgrade for the SC430
- New Member
- Daizen Polyurethane Bushings on a 2010..
- 2006 sc430 lug nuts
- Happy holidays
- Bilstein Struts
- New member
- Replacing bulb in rear side light
- 2010 SC stereo/nav in an 02?
- Finally Got a Spare Tire
- Update Bluetooth software
- Vaistech SL2i-UP vs VML comparison chart , why not VML
- Help: Mechanic can't find O2 connector inside car
- Which Maintenance to Perform on 130K+ SC430
- Amsoil ATF instead of Toyota Type IV
- rear seat cover
- Brake Fluid - When To Change?
- heated seats
- Question: Any way to rev the engine from the engine side?
- Looking for advice on buying my first SC430
- Changed Battery, Radio and Seat memory Presets????
- Daizen Steering Rack Bushings Installed
- Inexpesive Ways to Make SC430 Look Unique
- Setting to Turn Off Headlights Immediately After Ignition Turned Off
- My horrible story
- OBD-II / DLC3 pinouts (headlight leveling system problem)
- Need to replace ONE tire
- Alternator Replacement SC430
