- Jacking the SC
- How did you Florida guys survive the storm?
- New to me 2004 with some questions.
- stock wheels w. covers on velcro
- Our adventure continues!!
- 2004 wheel center caps
- Window switch
- Nav screen doesn't tilt
- Maybe I'm crazy!?
- Will any other Lexus seats fit in an SC430?
- HVAC and temperature oddities
- Demographic of the SC430 buyer + demand?
- Oil Filter Wrench
- 2006 Headlight Washer Covers
- Trunk needs slight downward pressure to open electronically
- AC only throwing through defrost vents
- Dead Battery, Trunk
- Exhaust
- Would like to sell my 2006 SC430
- 2010 radio
- Hardtop Roof Issues
- New front end parts, still getting heavy clunking with metal on metal sound
- Passenger headlight problem
- Lexus SC430 vs Porsche Boxster (Manual)
- Exhausted to dump the 2002 SC?
- Air conditioning
- What the heck is that squeaking noise?
- Anticipation Builds.....
- Battery causing stereo issue?
- rcjsidyrf=sounds bad!
- Horn mystery
- Techstream answers needed
- 2002 SC 430 sound system
- Fuel Injectors pulled and serviced
- New guy, new car questions.
- AC went out
- New Owner
- Car keeps dying while driving
- sc430 move 2006 to 2002
- 2002 SC430 What if I want it all?
- Backlighting
- SC430: What's the farthest/longest you have driven without any breaks/stops?
- Anyone have a recommendation for a Speaker Foam Kit?
- Black plastic bolt covers….
- Need some help. Broke a connector to a sensor while replacing my knock sensors.
- New but old to issue
- Need Mark Levinson wiring speaker pinout (aftermarket amp, stock wiring)
- Classic Car insurance for an '07 SC
- 2001 SC430 Air-Con Compressor
- please post for sale in marketplace classifieds
- Lift Points on an SC 430
- Lift points
- new rims for my 2005
- How to replace driver's side HVAC servo?
- ABS, VSC, Battery & brake lights on
- Quantum Auto ECU (6 Speed) - BUYER BEWARE
- ML Stereo - no sound BUT sat nav voice works??
- Dash cam
- Special timing belt job full service
- Velox wheels
- AFR bank1 sensor 1 running rich
- Happy July 4th
- Side Mirror Glass Discoloration
- 2002 SC430 latest tire replacement
- Water in the boot/trunk
- Tail light LED bar. What’s HOT when ON?
- parasitic drain after unfortunate stereo install
- Question about reprogramming ECU with ODB pins 4 and 13
- Nav Door Swap
- 2002 sc430 motor
- 430SC 2006 70,00 miles
- Wheel Spacers Yes or No?
- Convertible top noise rear drivers side
- Need a favor from someone with a service manual.
- Doors auto-locking
- 2003 Lexus SC430 stereo gurus...
- Bank 1 sensor 1 02 sensor
- I found my dream front splitter!
- 2003 Lexus SC430 climate control issue with different mode
- LED Sidemarkers (NEW!)
- Rear Bushings
- what type of AC compressor for the SC430
- Trunk latch locks but can partially lift trunk
- Danger
- Preferred OBD2 scanner
- LED bulbs?
- Is it possible to have a seasonal Power Steering Leak?
- Retractable roof - manual closing
- engine heat from drivers side floor
- 2004 SC430 1 click no start -new starter and battery
- Map/Navigation door stuck open
- 3 Core Aluminum Radiator
- Custom/Cool SC Builds/Unique Mods
- Bad Transponder Key Coil?
- Which Continental serpentine belt should I use for my 2005….
- temperature control
- Upper Arms
- Weird things you find on ebay
- Reinitialize tpms ???
- Procedure for programming keys to doors/Trunk
- Interior trunk release button and NAPA bank1 sensor1 02. Sensor
- Lexus IS Aluminum Sport Pedals
- Damaged thread on the ball joint
- Tweeter not working ML pinouts
- P0442 P0441 P0446 Codes not going away
- No less than Eleven SC430's on ebay with less than 40K Miles
- Costco won’t sell tires to me. Can you believe ?
- Coin Holder Cover Replacement
- Anyone see Car Care Nuts new build?
- Sear leather replacement
- Steering Rack and sway bar bushing replacement
- Lesser known JDM options
- Bank 1 sensor 2
- The New Digital License Plate
- Difficulty of finding parts for First Gen of SC 430
- Rear Knuckle bushing part numbers?
- At times turn ignition on everything dead
- Chassis Rigidity and Flex - Window Seal
- Headunit in NAV location (Finally!)
- Have any of you successfully restored AM and FM radio reception on your stock Radio?
- SC430 Seatbelt Cleaning
- LED replacement instrument cluster
- lexus sc430 convertible top rocker switch replacement
- Rear coolant bypass section
- Power window issues
- 2004 SC430 Hardtop is Intermittent
- 2004 SC430 Intermitten Hardtop
- Problem with my idler pulley... I think?
- Back up camera installed
- Production numbers worldwide
- shocks recommendations (2004 SC430)
- Push button cover over radio on SC430 not working
- Tpms
- Heavy steering
- Sigh, I should know better.
- Kissing Cousins
- How to replace weatherstrip on the roof: 62382-24090)
- Package tray stuck in the upright position!
- Another e. coast SC430 biting dust/rust=competent service LEX/TOY referral req?
- Gut Check on a 2005 SC430 Purchase
- Oil sucking / burning through PCV valve
- Valve Covers Gasket Replacement Cost
- Car Care Nut Transmission Information
- Name this part :)
- Techstream cable for 2002 SC430
- New Member and Owner
- Pictures of black floor mats with a Ecru interior.
- You can't fix stupid....
- Will these fit?
- timing belt
- air bag recall
- Looking to add CarPlay stereo and new speakers
- Servicing the Side View Mirror "Tilt" assembly
- 2002 sc430 transmission
- SC 430 EV Conversion "study group" start-up?
- Buzz from map/dome light…
- Selling 2003 low mileage
- Drivability/Suspension wisdom needed
- Authorized or reliable Mechanic
- Question to anyone who has replaced OEM brake hoses with OEM replacements….
- Quarter Window Seal Replacement
- Top down in summer
- Dumb question (or not)
- plastic seat back loose
- 7mth of hibernation
- New owner, new member
- Anyone tried Bass Rockers BRM69v2 speakers ?
- convertible top malfuntion
- Another tough call...
- Spare, manuals, cover, etc
- Complete head unit replacement for '06 SC430
- Speaker Replacement
- DIFFERENTIAL LUBRICANT - right choice
- Front bumper conversion
- 2002 Sc 430 180k Oil in Spark plug well
- New 2004 sc430 owner, what to do with 20inch wheels?
- Steering wheel is not straight
- An old thread for the new SC owners
- Turn off the Check Engine Light after oil change.
- Valve Cover Bolts Re-torque
- New 2004 SC430 owner
- Also new owner
- 2004 SC430 Steering Column Sound and part ID request
- R35 Skyline wheels on a SC430 recommended tire size...
- 2004 SC430 Steering Wheel Cover Removal to Remove Airbag
- 2004 SC430 Random/Erratic Steering Squeal in cabin
- New SC430 owner- 1 of 1 color
- **Help** Installing axel back how do you remove the O Ring exhaust hangers?
- Danger Brake Failure with no warning.
- Spring cleaning
- Guess and WIN!
- Trouble after trickle charge
- Aftermarket wheels
- 2002 SC430 skid control ABS Speed control
- Question for Mechanics
- Metal "Twists"?
- Purchasing help - timing belt
- Passenger side rear brake squeal…
- 2002 sc430 tpms
- Headlights Intermittently Cut Out
- Antenna Block off Replacement Cover
- speakers - or stereo upgrade
- SC430 roof hardtop won’t close ALL THE WAY
- Exhaust opinions
- Blank screen and no sound from stereo
- Special Low Mile Example
- 2003 sc430
- ABS TRC VSC Traction Control Skid Module location?
- Cold Start Coolant Leak... What Does This Bolt Do?
- SC430 at 50k miles - new owner questions
- Cel, vsc lights off in dash
- Spring is coming!
- New Owner '04 - speaker distorsion
- Roof won't go down - battery problem?
- Inside photos of a 2003 wing mirror
- Best MA or NE mechanic-INDEPENDENT SHOP for 2002sc430
- Groaning Noise when Turning...
- Happy New Year- Year Of The Cat
- High Interval Oil Changes
- Snake oil or Snake Plisken?
- SC430 faint rumble noise behind the backseat?
- 2006-10 License plate lights
- '06 SC, 190,000 miles Change Trany fluid???
- Passenger side floor on SC wet after rain
- What have I done for my SC430 lately?
- Just a test
- Need to disable roof chime
- Find vacuum leak with WD40
- Bumper side marker
- Find the battery drainage
- You can buy Lexus Oil Filter's at Walmart now
- Aluminum Dent Removal?
- VCS reset and returns when car moves
- P0125 dtc
- VSC on/off lights on all the time after bodywork
- 2023 Market for Used sc430
- Need correct "replica" trunk lift struts for a spoiler ?
- Wife wants terry cloth type seat covers for her Lexus... what has worked for you ?
- Rear Windows
- SC430 Repair navigation cover and now working again.
- 2004 sc430 low beam hid color temp
- Starting issues
- Overnight discharge!!!
- rear differential
- Block heater installation
- Popping noise in steering ?
- Got The Knock Sensor Code For Christmas 🎅
- Ride quality difference between 1st and 2nd gen SC430
- Fav sc430 video
- SC 430 Firmware update
