Starter never stops cranking
Old Jan 27, 2020 | 04:41 PM
fastek's Avatar
fastek
Default Starter never stops cranking
Tried starting up my 2000 RX300 .... the starter cranked normally but the vehicle would not start and the starter continued to crank even when I turned the ignition switch to off and removed the key. Had to jam into the garage, grab some tools and disconnect the battery to get it to stop. When I reconnect the battery it sparks like a SOB and the starter starts cranking again. Never seen anything like that. Ignition switch perhaps stuck ?
Old Jan 27, 2020 | 04:49 PM
maxSteel's Avatar
maxSteel
I would think more likely it's the starter solenoid.
Old Jan 27, 2020 | 04:54 PM
fastek's Avatar
fastek
I pulled the starter relay and that did nothing to stop the starter cranking.
Old Jan 27, 2020 | 05:07 PM
fastek's Avatar
fastek
I would imagine it's simply best to replace the entire start motor as opposed to only the solenoid correct?
Old Jan 27, 2020 | 05:32 PM
ricco750's Avatar
ricco750
NO! Just rebuild the solenoid...easy job, the rest of the starter is bulletproof.
Old Jan 27, 2020 | 05:56 PM
maxSteel's Avatar
maxSteel
Very easy and cheap to rebuild the solenoid. There's probably a DIY in the stickies.
Old Jan 27, 2020 | 06:34 PM
fastek's Avatar
fastek
Ok thanks guys !
Old Jan 28, 2020 | 03:05 AM
ricco750's Avatar
ricco750
Ok thanks guys !
Go here...http://www.nationsautoelectric.com/d...rts.html...and watch the video. This is where I got my parts from several times. Be sure to get a new plunger, as well as the contacts.
Old Jan 28, 2020 | 07:21 PM
You need to replace the solenoid contacts as stated above.
swan55
16
Jan 13, 2018 01:01 PM
fishguy55
Oct 17, 2011 02:19 PM
jcastaneda
Feb 2, 2011 09:46 AM
meanboy
Apr 22, 2008 02:22 PM
airahcaz
Performance
Apr 25, 2003 01:19 PM
