- Single Exhaust Bumper or Filling Stock
- sc300 transmission filter question
- Difference between 98 and 00 1UZFE?
- torque specs ?
- stalling issue...
- Pulled the NA-T for some pics..
- Exhaust Shopping
- Please Read!! Help On Timing 1uzfe
- anyone here running the New Apex-i Safc3 Neo with 1jz?
- camshaft ?
- Auto Tranny
- NA-T Won't Rev over 3700RPM
- final gear ratio ?
- how much hp can a high milage 2jzge hold
- The upgrades start, Pics!
- Finally found out how much iam boosting with my 1jz setup.
- Question About TRAC OFF
- Trd Lsd
- how to turn traction control off
- bov noise level
- 1UZFE cam and crank question
- sc400 pumping oil
- removing steering rack solenoid.....need help
- where does the sub-oxygen sensor connect?
- NEW Apexi NEO SAFC-3 ...anyone tried?
- apexi megaphone dual exhaust
- ThermoTec
- Another LSD question.... Supra diff carrier
- 92 SC400 Trans Filter Change
- loss of low-end after tranny rebuilt...
- Just want to make sure - failed A/C compressor?
- Radiator help.
- Passing emissions with Headers..
- Boost Controllers? What boost controller is people running?
- Auto to Manual SCs
- manual trans
- HTR 10A Fuse keeps blowing out
- Can someone get me a good deal on a 1jz?
- HELP! 97 SC400 EGR removal?
- NA-T guys, what'd you do with the O2 sensors?
- Help! Timing Belt Tensioner
- AEM problems
- SC300 Drive Shaft Question
- Which throw out bearing to use for r154 tranny swap
- Need Urgent help guys...engine/security system
- Lexus Transformation!
- is300 lsd in sc400
- 1JZ Owners.... Reliabilty
- Tcs
- heater and AC problem
- Okay... Raise your hands if you have the TRD LSD [SC400]
- R12,r13a ???
- opinions on new exhaust..
- Will a TT Intake fit on SC300 head
- 93 SC300 hesitation on accel.
- Lag After Tune Up ?
- 1jz neutral bypass
- 1uz-fe over 2jz-gte???
- AC problems
- People with parts manuals, see if you have this pdf file.
- a/c and heater not working
- My car is crapping out on me now Question about A/C
- Turbo vs ecu question
- Manual 400...nah
- Flat black engine bay...looking for your opinion
- M/T Swap with 300/400?
- and you thought your exhaust was too big....hehe
- BFI Intake?!
- automatic to 5 speed
- 1jz power issues
- OMG. please read. Axle?
- Engine Fan
- Timing belt or chain
- HELP!!, NA-T done, got the stalling problem!!
- 93+ manual supra transmission
- Another overheating thread...
- 1j "breaking up/possibly detonating"
- Altering the MAF?
- New member with question re: JDM 2jz-gte swap
- check out my new valve cover
- S-AFC settings on 1JZ swapped SC's
- help on horsepower gains
- what kind of exhaust should i get?
- is the garrett m24 turbo (for the 7mgte) compatible w/ 2jzge?
- I'm Chris, I'm new here, and I've had lots of problems with my SC300..
- Need help!! Differential gasket...
- cruise control not working
- 2JZ Soarer Wiring Diagrams
- How to change distributor cap & rotor on a 92 SC400?
- How can you tell if an engine is obd1 or obd2?
- anyone running turbo's on there 98-00 SC300
- Magnaflows 14829's Vs. Blitz Nurspec F1's
- Turboing 93 sc 400
- 2JZ swap into SC
- no egr valve
- Bfi Quick Question
- help: engine stumbles when coming to a stop
- Hp Capacity 1uz-fe?
- Harmonic balancer
- Confused about Torsen
- Car puts out ridiculous amount of heat.
- Engine codes
- Intermitant blown motor?
- 1jz is up, exhaust quest
- Anyone in Connecticut know of mechanic for engine swap?!
- to 1jz experts
- 1jz exhaust question
- Q for turbo gurus...
- What else is needed for the r154 swap?
- Tranny problem
- SC400 - TT Swap
- what temperatures in degrees are u 1jz's running
- Clunking noise when starting the car!! Need help!
- SC400 rearend oil change?
- auto sc to TT motor
- Overheating Issues... and i've tried everything.
- SC300 5-spd and Supra NA 5 Spd drivetrain parts sharing
- 1jzgte wont run right....... help please
- performance chip
- car shutting off...please help
- Carbing Radiator Coolant Plate
- 98-00 SC400 Compatible Engines?
- Turboing an sc300
- Sc400 aftermarket radiator????
- Trd Lsd
- Please Help Car Wont Start!!!
- Wth Is Wrong With My Car
- 95 sc300 and 94 gs300 engines compatible?
- Installing my Walbro fuel pump -(I have a problem)
- Transmission help!
- Muffler for Exhaust?
- not idiling as well as she should
- Kazama SPL Mounts
- Auto-auto tranny swap questions
- All NA-T parts collected...see my price list-->
- Supra TT headgasket install ?
- S-afc
- SC400 Custom exhaust
- 14829 magnaflow for an SC300
- What other supra parts can work on a 93 sc400?
- Idle Speed Control (ISC)
- 2JZ Soarer Problems
- Turbo set up for s300
- blinking abs airbag and cruise control lights
- 1993 sc400 knocking noise when shifting from park to drive.
- Turbo Noob Needs Help With Na-T
- Cost of a 6-speed Getrag conversion?
- I'm having issues w/1JZ spooling up.
- the best torque converter for a SC400???
- '92 Sc300 Auto, Key Stopped Working
- extending shielded wires faq (knock sensors)
- i got a SC .... turbo questions
- What does it take to beat an American Muscle Car
- SRT intake work for SC300
- 2JZGTE WIRING HELP (sc300)
- 1jz performance data?
- How come 2JZ VVti...
- Oil Change!
- Front Mount Intercooler choice help?
- 1jz wiring help
- Newbie, need some help !
- Chevy swap in LEXUS?
- GS400 K&N FIPK intake on our 98+ SC400's?
- Question on 1UZFE cams
- After Headgasket replacement: Engine burning coolant
- Boost Logic Turbo kit
- 1/4mile time
- Mustang Sound for SC400?
- MAP ECU on SC400
- Ebay Treadstone intercoolers?
- Need help deciding whether to go straight for a turbo or an engine swap
- Exhaust Back Pressure test ?
- CEL P0420 - Bank 1, Before or After Cat O2?
- Exhaust making cracking noises after turning off?
- HELP! Car having problems on boost - petrol???
- Are the SC300 and Supra NA auto differential internals the same?
- s&s headers on pre 98?
- weird starting problem
- Ebay Shift light
- Greddy SCC problems???
- engine Harness
- radiator replacement ?
- BFI Question
- Engine Coolant Leak HELP
- throttle cable problem,Please help
- 1jz UP AND RUNNING WELL=) ...PICS!!!!PICS!!!!
- Dynomax vs. Magnaflow muffler opinions
- 2jzge engine cover
- 1jz timing questions
- Best DRIVESHAFT?
- LSDs
- Coolant warning light.
- Performance Q's
- Pics of VW intake on GE
- Rear end
- Random Motor Turn Offs
- MAF relocated?
- rpm not reving after JDM 2jzgte conversion
- hey does any one know if SR20det could
- Engine Rebuild
- Need 2 1/4" mandrel sc400 exhaust piping?
- engine swap labor
- belt tensioner pulley
- Pretty Parts for my TT SC400
- sc400 2jz
- Yet another power steering pump problem...please help!
- 1jzgte headgasket same as 2jzgte?
- alternator problems?
- will a Supra 2JZ-GTE in SC300 pass smog???
- cheap FMIC piping na-t idea
- need quick answer about 1JZ harness
- 1jz wont rev
- 5 speed Tranny Problem?HELP PLZ
- 1jz compression? spark plug gap? vacuum routing?
- DYNO Results for my SC400
- For those with Gauges(boost) i have a question regarding Vacuem Line Running
- Help!! Bad gass maybe??My car stalls everytime I stop
- 1UZ-FE V8 Air Forced Induction?
- 3sgte swap
- 1uz-fe swap?
- Gas Leak Mystery
- ct12a internals
- engine response
- Name that part
- What does the orange light means
- Hallman Boost Controller opinions?
- Tuning a 1j??
- budget fuel management
- Update Update On 1jz Swap...
- 1JZ Engine vs 2Jz Tranny
- fastech motorsport sc 1.5jz build
- Where do these parts go?? Electrical Connector & Vacuum Line (PICS INSIDE)
- 1jz Map sensor location
- Central Fla. help
- Should I get the INJEN SHORT RAM INTAKE?
- Need EXPERT advice!!! (pics)
- MASS air sensor
- Will LMS CA Intake fit on SC3?
- does anyone know of any dyno in the las vegas area
- Custom FMIC piping pics?
- 1JZGTE / 2JZGTE motors
- SC400 Air Conditioning Removal
- 4 row FMIC on SC300?
- obd1 1jz swap in 96+ sc300??
- Turbo in a SC400 Auto? Possible?
- ic hole
- Fastest SC?
- valve cover gaskets
- Timing belt/tensioner.
- What is the best aftermarket intake for SC400's
