Need Sc300 wiper motor diagram
I've searched CL with no luck...
I've been having an issue with my wipers... They don't work! I purchased a used set from a vendor on here and still the same issue. I know it can be possible I have two bad units but I want to make sure. I'm getting about 8.5V from 3 pins when the wipers are engaged. And 6V from one pin when disengaged. A diagram of the pinouts/schematic or just voltage output per pin would help.
I've also tried using a different set of column controls from a newer sc and still no dice. The voltage actually dropped to 6.5V... weird
http://home.comcast.net/~ishootstuff...hop_Manual.pdf
Link to the site I used to test wiper motor...
Page BE-84
I'll try checking continuity when it's not 23 degrees outside...
Page BE-84
