I need Help on parts for my 1JZ VVTI
Well i went ahead and bought an SC300 that has a 1jz vvti with a w58 trany it has 161,*** miles on the body and a few thousand on the motor i got it dirt cheap "$3500" and it needs a power steering pump and power steering hoses the pumps pulley shacks realy bad and is hard to turn and the hoses for it leak also, plus i need coil packs and spark plugs with injectors because it miss fires in one cylinder and i did a compression test and it passed so i figured it was one of the above items... i also need help on knwing if there is any cross reference parts thatll match the vvti or if anyone knws were i can get the parts for it and also it has the stock turbo and manifold... im going to buy the turbo manifold for it with a bigger turbo and wanted to knw if i get a BOV if i need to recirculate it because of the maff sensor or can i just leave it open??? i knw some turbo set ups dont need to be recirculated and id rather it not be because it kinda cuts out the loud BOV sound thanks for your help here are some pictures of what i have to work with...
