- just wanted to share this video
- Custom Exhaust Front Pipe?
- P1121 code, tried a few things but nothing! Help!
- Brass radiator SC400: Prestone or Toyota Red?
- P0171- help
- SUUUPER frustrating Code 14(Ignition Signal) OBD1 issue.
- Overheating
- sc300 manual front driveshaft length
- HELP! Problem with Car..
- Best auto trans for sc300?
- 2000 SC300 with 2jzge vvti Timing belt and water pump?
- Diff Swap
- Alright guys why is it so hard to get a manual swap?
- GTE Head swap on GE Bottom or Just go 2jzge NA-T
- S2000 AP1 6-speed conversion?
- AC unit NEED HELP
- Help!!!! Grounds 2jzge
- Sc400 w58 Swap
- Urgent
- SC400 Air Suspension Creaks?
- Fuel Rail Question
- Wastegate question...tial or precision?
- fuel guage does not work
- Major mistake during the swap , don't make the same mistake I did !
- Vacuum Hose Placement
- 92 SC400 200k CEL Code 052
- leaking tranny fluid
- Slow cranking
- SC300 Burning to much gas
- Fujitsubo Exhaust Clip
- is300 valve covers on sc300?
- Fender exit downpipe
- Injen intake on a 97 SC300
- Bleeding new clutch mc? Special procedure?
- This is all I really need to do the gte wiring merge correct?
- Widow question!!!
- Coolant loss
- Exhaust resonator questions
- Going rich but only at 2K? SC4
- Alternator..rebuild, replace, upgrade?
- harmonic balancer help
- Fuel pump not working
- SC 12V fuel pump mod- 1JZ
- Throttle Body Issues?
- Where to buy Motor Mounts
- Lots of oil from pcv
- Where do i find a 1/8th BSPT to -3 AN fitting?
- 1JZ Alternator will not carge battery
- HKS FCD explination?
- Ac light flashes on sc400 with 2jzgte swap
- bad starter... how to get car started
- 92 sc400 transmission type A340 or A341?
- SC400 problems HELP!!!!!PLEASE!!!!!
- 1UZFE with manual swap, Vvti or not
- 5spd swap shifter/trans problem need help
- SC400 Neurosurgery - wiring harness repairs
- Clutch swap help
- Actual NA-T intercooler plumbing kit foud? legit?
- 1jz gte vvti
- Starter issues...ignition/electrical cutoff?
- SC400 wont start. :|
- what's wrong with this picture/video
- 680cc top feed Siemens injectors fit on stock 1jzgte fuel rail?
- Can old o2 sensors cause bad mpg?
- Running Rich
- 1JZGTE or a 2JZGTE Swap?
- so my 92 sc failed smog
- ***92 SC400 only firing on half its cylinders***
- Random Steering wheel shakes
- Help me instal HID headlights
- HKS FCD .VS. Greddy BCC
- Different Differential make a Difference?say it x10
- SC300 MAF's
- Oil Pressure
- Manual transmission oil and diff oil?!
- High Output Alternator?
- motor mounts.
- cruse control wont work
- Radiator
- Gasket Brands for our sc400. Good or bad?
- Hks fcd opinions
- Need a Creative window fix!!!
- Help car wont start :(
- Odd Window Problem!!!
- Something we all need to READ!
- hey just a few tps questions
- aftermarket electric fan questions
- na-t GTE ecu project wont boost past 4k
- 2jzge intake question.
- need help with overheating on a 92 sc400
- Starter burned up?
- ecu
- Sc300 idle issue. not iacv
- turbo and fuel questions
- Gauge 10 wire - E85 friendly
- sc300 dual feed fuel rail on a budget
- GTE Swap info.
- Loud noise when changing into 3rd gear
- How to tell if you have Ps Problem or Rack and Pinion
- Intake pipes
- A/C Unit not powering up.
- Thermostat housing Gasket
- Automatic tranny from IS300 into SC300???
- 1uz swap into sc300
- dont know what to do about this
- 1uz/r154 with sc300/r154 DS confirmation
- Pulling 2JZGE minor problem.
- 1995 lexus sc300 02 sensor problem.
- Need a little help - my SC won't respond at all :(
- 1992 Sc300 ecu rebuild
- SC300 w/ Torched Springs
- no heat?
- egr - Code 71....HELP
- Need urgent help
- Blitz boost controller questions/ problems
- Fuel pump computers all tested bad SC400
- Bubbling noise??
- Engine Damper?
- so now the car runs, i have cel code 25, low idle when warmed up.
- Throttle Position Sensor
- Best turbo route simplified
- Head work
- Underdrive pulleys?
- Where does this part go?
- Grinding/rubbing sound when starting 1992 SC400
- Loss of Compression?
- hey whats up ClubLexus
- 2jzgte swap...wont crank
- lacking power
- A/c compressor problems
- My own sc4 BFI version, not done though.
- BC valve springs
- wheres the fuse for the eletrice fan 99 sc300?
- exhaust drone, rumble.
- exhaust drone..
- 2JZ-GE Port & Polish
- Head gasket
- overheating issues, quite intresting...
- 2nd gear grind/bind
- a/c problems
- Sc300 Na-t TT ecu
- Does anyone know
- 350z g35 trans on 2jz motor
- Bad idle on start up when it sits for a few days.
- HELP r154 speedo
- 1jzgte swap
- Going Na-t Questions!!
- Help with part Number:
- 1jzgte supra swap wiring harness to a sc300
- Sounds from the engine (vid inside)
- GTE complete? buy?
- Help gated shifter swap on 97 sc300
- SC300 w/ 1JZ-GTE swap, need trans and other ideas?
- Help! Head Gasket? Radiator? 1992SC300 5 speed
- No Vacuum?
- 97 SC300 Revving on its own at Start UP.
- Higher Gear
- SST's Alternatives?
- parts/rebuild
- R154 Slave bleeding problems
- how do i know if i have a sc400 diff? helps please
- SC400 no start - please help
- SC400 almost total system failure - please advise.
- This is what 5000 hp 2J's look like. LOL
- Super frustrating issue. Code 47 Sub TP Sensor?
- Ethanol blended fuel
- 99 sc400 charcoal canister location
- Anbody made cat back exhaust system w/the Tanabe mufflers?
- Close range key fob?
- Where is the low side AC hook up on 94 SC300
- Weird Starting problem, anyone help?
- MSD Digital-7 Ignition
- HELP 97 sc300 idle air control valve
- sc400 ecu pinout
- v8 conversion on sc300
- Help - Throttle Position Sensor TPS screw-up
- 440cc Injectors in a SC300
- Power steering, Oil, or ???? leak
- R12 to R134 AC Retrofit SC400/300
- car starts but cel comes on
- Is this a good deal?
- Transmission won't go all the way in
- 95 sc400 Alternator
- ?'s on 1jz (bpu mods, 2jz turbos on 1jz, & single turbo on stock ecu?)
- ac problem need help!
- 95 sc300 auto tranny
- Doing the 2jzgte swap
- Cold engine, revs jumping, car almost stalling, check engine light coming on.
- Using usdm 2jzgte harness on a jdm motor questions .
- Post your oil cooler/filter relocation set ups!
- left and right front catalytic converters
- Common Q
- cranking but not running sc300
- Any 1jzgte guys here using an aristo trans or ecu?
- SC400 Weird Stall
- exhaust question
- Fluid in my spark plug valley
- 1UZ vs 1UZ Vvti block strength?
- need help! going lean
- How to wire clutch pedal switch auto to manual?
- What size tap to use to tap ge oil pan for turbo drain?
- SC400 Stock Fuel Pressure
- Idle Problem, but no Vaccum Leak.
- SC 400 Excessive Cranking at Start
- W58 rebuild ?
- Sc300 Rear driveshaft length? Seller sold me wrong part?
- Small question
- SC300 Chirping Noises
- kaaz 2 way diff in 92 sc300?
- 92' SC400 | Coolant Sensor, Leaking Coolant
- sc400 random major oil leak wtf!!!!!!!!
- can a 1jz sound like this?
- Tempature coolant problem
- SC400 Cooling Hoses
- SC300 down...NEED HELP !!
- Worst 2jz problem discovered!!!
- SC300 Clunk Noise
- different starter sounds
- 300 stick, O2 sensor, idle issues?
- My New Sc300 Exhaust Video!!
- 94 SC400 idle problems and accelerating by itself, throttlebody butterfly valve?
- Suggestions on 440 cc injectors
- Temp gauge stopped working - cold -1jz swap
- question about upgrading twins
- Help. Checking engine light after 96 sc3 manual swap
- sc400 1jz no start - ACC work - weird warning lights
- T3 Heat Shield?
- upgrade starting points
- sc400 Engine Stall I'm Stumped
- Highest Horsepower Numbers from W58 NA-T Guys? Post up!
- overdrive cel
- 1uz dipstick o ring pn and ring gear bolt pn please
- cranks but no start... need help asap
- bad o2???
- Carrier bearings
- engine swap vvti gte vs non vvti gte?
- Facts about oil and what grade to choose
- Alternator harness hacked off of your 1JZ Swap? Click here!
- cams and valve springs
- Power steering issue..searched
- Hmm... 2JZ Boxer-style?
- ABS and Trac lights
- Ac help
- 1jz vvti swap no power whatsoever
- question CEL light
- Please Help!!!! More problems
- New Problems
- quick question about my swap w/pics
- 2jzge head gasket
- False advertisement! No A/c for me!
