- 1997 sc400 no start. Please help.
- Need assistance with engine diagnosis
- Fan problem help !
- Car Won't Start :(
- O2 Sensor Extension Harness
- Help r154 shifter extension
- heat in the center console
- SC400 Transmission
- 4spd auto to 5 spd
- Please help with assessing damages.
- 1jz vvti sc400 no check engine light
- how to de-pin EB1 connector?
- So I've Got Some Sputtering.. I Need A Little Help.
- HELP 95 Sc300
- Oil Leak - Need Help
- Alt wiring Question
- Losing Alts.
- Stop starting ! Error 78
- Mvp headers
- Next step...replace ECU, advice?
- SC400 Update/Issues
- SC400 FPR specification
- Sunroof problems
- SC400 auto headlights
- need some wiring help for my fans
- 95 1uzfe in a 93
- Help!!!!
- Cooling fan problems
- Burning smell under the car?low idle on start-up
- whats the best way to
- a few performance questions, 1uzfe.
- thinking on doing a motor swap. cost ?
- ch of a beating can a auto trans in sc300 take
- Piggyback VS Standalone- Explained by Adaptronic
- NEED HELP ASAP!! 1JZ Transmission fluid
- Speed wire input to the ECM
- Anyone taken the plunge on the XTD flywheel?
- help with gasket
- NA-T manifold advice using oem intake mani.
- 2JZGTE swap harness options
- chain type of noise in the engine bay?
- ticking noise when ac blower is on
- Need help identifying artso tranny sensor
- help, broke a harness plug. cant identify it.
- SC400 code 25 O2 sensors?
- 1jz vvti alternator wire colors
- oil sending unit
- 1JZ R154 Bellhousing question
- 2jzgte swap not getting spark or fuel
- how do I get back seat out of my sc
- ST92 300 1jz STRANGE PROBLEM! Car stalling while driving please help!
- SC300 2JZGTE VVTI harness question. Help.
- Warm weather low idle problem still persists.
- rough ride at about 45mph
- Strange fuel odor coming from my 92 sc400 while driving
- Dieseling
- Too much coolant...
- turbo coolant lines
- NA-T oil filter mount
- Who can rebuild an SC400 power steering pump well and inexpensively?
- How to choose the right map sensor
- Turbo size?!
- replaced knock sensors, still throwing knock sensor code (SC400)
- Testimony of e-bay throttle body?
- loss of power running rough
- SC400 Driveshaft Guibo Flex Disc
- White smoke coming from middle of car??
- 98 SC400 Hydraulic Pump
- 92 sc300 code 22 and 14
- Need Help !
- sc400 diff on an sc300??
- Coolant temp sensor replaced NOW IT'S WORSE!!
- Coolant temp sensor different on Manual?93 SC300 5spd
- Name that hose.... I broke
- Battery Relocate Question
- 95 sc300 2jzge vvti swap
- sc400 manual swap clutch not working
- is300 vvti 2jz into sc
- dinging noise
- Do I need to use RTV wen putting intake manifold on (1uzfe)
- issues with 95 sc400
- will this downpipe work for nonturbo GE?
- Boost & Fuel Cut Defenders - Educate me?
- best reman p/s pump!?
- r12 vs 134a A/C
- Bowl full of spaghetti- I mean unknown vacuum lines.
- Flasher relay help!
- need help/advice.
- Best clutch for street SC300 NA-T 400 lb/ft torque?
- SC400 header options...
- car stalling
- HOW TO: Replace center support bearing and remove driveshaft.
- Sc 300/400 headlight de-line??
- 1jz replace or rebuild turbos?
- Poop. Dropped a nut into the intake manifold.
- need help
- Has anyone used this turbo kit?
- Any body know???
- 95 sc400 RPM drops and Engine Trouble
- Need help with power steering
- Tried to fix my Door Hinge Pop. Got Worse!
- Air Box Assembly/Blend Door Motor
- Looking at Flyweels
- squeeky engine noise when cold??
- Power Steering going?
- About the Radiator!
- Power Steering pump: Is there a reliable alternative to the Lexus part?
- CL turbo setup?
- Diff ??
- ABS and TRAC on, how to check codes
- 2jzgte hard start when warm
- sc400 neutraI safety switch wireing after sc300 w58 manual swap
- JDM Engine Corp
- Overheats a idle...chaning fan clutch?
- Change Fuel Filter...anyone notice a difference?
- 1JZ Refresher Build Help
- How to Change the major belts for 1992 Sc400?
- 95 sc300 not starting
- What part is this for injector
- 5000rpm cut off on WOT.
- Failed Smog after engine swap to 2JZGE
- 2jzge log style manifolds
- Seafoam experiences?
- ECU repair
- GM alternator swap (CS-144)?
- Looking for insight - broke down
- Getting a 200 Amp Alternator. What is the best safest cabling and fuse to get?
- 1jz purchase
- UZ - Small lines on top
- sc400 issues need some help please!!!
- sc400 Transmission swap
- EGR Pipe removal
- '97 sc400 power steering problem
- Help with 1jz timing belt
- GTE cams on GE head?
- sc300 not charging?
- passenger side mirror freely moving
- Brand New Turbo Oil In Packaging
- lc-1 wideband install help
- Differences in aem v2 6100 vs 6101
- Sc 400 ITBs
- 92 sc400 awkward stalling problem
- if only!!! IF ONLY I HAD THE MONEY!!!!
- throttle body/intake manifold issue
- can some 1 tell a place that I can get soarer logos
- help pulling my dash to paint it black
- Tranny fluid and lucas tranny fix
- i need a braided line fuel kit .
- Serpentine belt tension pulley(part number)?
- Where should a 1uz idle (sc400)
- Oil filter, buying one at Lexus vs Toyota dealer . . . .
- Sc300 Work
- Sc300 Mods?
- is vvti 2jzge motor vs sc 2jzge non-vvti motor (bottom end)
- Are turbo timers really that necessary
- steering wheel swaps??
- 98 sc 400 ECU
- Sc400 won't reverse
- ati pulley honing question
- help with turbo timer
- turbo!!!!!
- HELP SC400 Starting issue
- High or low impendance injectors?
- More questions pertaining to possible bad ecu?
- DIY: SC300/400 Seafoam Guide! With Pictures
- Need help with steering issues.
- Help please
- Should i get PUMPED, or just keep it the way it is!
- help
- Aftermarket cam gear thread
- Water by-pass gasket
- How to sump/plumb fuel system (tank) for sc300?
- Throttle cable install
- 98 lexus sc 400 won't start!
- Did I just pull my IACV, or something else?
- broken parts on 2.5TT - need PN
- speaker grille cleaning?
- SC400 randomly cutting out
- Climate Control Fail
- How do I reverse this mod ??
- SC300 cold start idle
- 98 VVTi 1UZ EMS Question
- What do I need to get this kind of speed?
- I know I know but has any one found the fix?
- Boostlogic intercooler piping vs universal
- Anyone convert a -GE BLOCK TO -GTE?
- Need some help installing either MKIV SMIC or Soarer SMIC (have both)
- 92 sc400 codes 14 and 15
- Sc400 Bogs under full throttle after oil change
- Sc300 97 AC does not blow anything
- Will 94 SC4 tranny fit my 92 SC4?...
- Sc300 rear axle width
- sc300 1j running lean at idle
- help picking what to do
- BFI thread
- Sc400 drops to 11v under high load when stopped, stalls unless I raise idle.
- Buying 1jz...warning signs?
- Performance chips ?
- 92 sc300 gas cuts off at 3500rpm???
- Neutral Safety Switch problem with R154 swap in my OBDII SC400
- MPG, Not a Question
- weird clicking/scratching/squeaking noise
- headers & downpipe
- Vibration in 1st gear after engine change
- Trac light and cel help
- Oil pump trick??
- Which ECU is best
- 92 SC400 Loss of Power, Rough Idle, Not ECU, Any help please
- Misfire, failed cam position sensor
- DIY-SC400 Serpentine Tensioner replacement
- BOdy Work baby
- ??? CODE #25 Cleared: Safe to drive?
- Which compressor housing on BWS366
- Custom Cone Air intake (1UZ)
- The Main Foglight Thread
- i need opinons on transmission swap
- Need a big favor from somebody with a long block laying around
- How much is a valve adjustment for sc400
- turbo ecu help (ive been searching)
- 1UZ-FE Cylinder head water passages?
- Borg warner s360 on 1jz
- Will an auto out of a 95 sc400 plug and play in a 92 sc400?
- na-t questions regarding stock parts
- Need help with supercharger kit
- TonyN SC400
- 1992 SC300 N20 NOS wet fogger setup!
- Center Cat Delete
- Injector impedance question
- Check Engine/trac control lights on
- DIY: Replacement of ECU SC400 - With pictures
- Throttle body differences between 1992-1997
- After Tune-Up Issues
- Trans problems, need help.
- Name these ports - VWR intake
- Squeal in engine bay AFTER new tensioner and belt
- SC300 Auto to Manual - Questions
- Unknown wire/sensor on new block
- wont restart after warmed up HELP
- manual transmission question
- Any dual exit catback exhausts?
- Whats my problem, tensioner, alternator, something else?
- wastegate spring question
- 97 SC400 Engine and Timing Belt
- Noise when steering 1999 sc300
- FS Fujitsubo Legallis R Dual Catback
- Wanting cams
- What causes the Ignition Coil to fail?
- Factory harness plug near starter
- Engine/electrical problems with a 93 SC400
- 1.5JZ ecu issue
