Burning smell under the car?low idle on start-up
I have a 93 5spd with 150k.I have been trying to diagnose and fix my low/rough idle at start up in warm/hot weather since last year but,can't figure it out.Now for the past week when I drive on the hwy and come off to a stop there is a strong burning smell coming from under the car.It's not a rubber or plastic smell but,almost like a metallic smell?Only thing I can think of is it might be the cat?
I have:
replaced coil,distributor,wires,plugs
replaced coolant sensor,02 sensors
fixed ecu leak
checked/cleaned hoses,pcv,maf,egr etc
I'm at a lost.
Any help or advice?
Thanks
I have:
fixed ecu leak
I'm at a lost.
Any help or advice?
Thanks
I think I have found the smell which was a burning/floral smell.When I got under the car there was some kind of plaster similar to liquid nails melted on before the Y pipe so I scrapped it off.We will see about that but,now that you mentioned the hissing noise I have noticed past few months with the window down when I get on it and shift there is a hiss sound very similar to a soft blow off valve coming from the engine bay.Any ideas where to start?I looked for leaks while I was under the car but,I didn't see any black exhaust residue where any leak would be ?
In Recovery Mode
Does liqiud nail smell like fuel...?
I have a crack in the weld on my "CA Emissions" resanator that is empty and not used. If the hissing is coming from the engine bay, I doubt it is an exhaust leak you're hearing, but you might as well check the exhaust manifold, then all the way down to the resenator.
OMAHA
18
10-30-17 05:02 PM
