Climate Control Fail
Alright,as the title says my climate control has failed. Was heading to work & turned on the heat & about 2 minutes later it shuts off. Tried turning it back on,nothing. Tried A/C & defrost but no luck. Checked the fuse,not blown. Anyone know what went wrong & how do fix it?
did the control stop working or did the motor just stop blowing air? cz mine doesn't blow air either and i've been trying to fix it for 3 weeks now. replaced the resistor for the motor and that didn't work. so when it gets warmer hopefully next week i'm gonna take apart the dash and get to checking every single wire and behind the control unit. the blower motor is on the passenger side underneath the glove box. if you need a DIY on how to take it out i can word it out for you. it's pretty simple. i just figured it out myself and unscrewed anything that was getting in the way. but first step would be to check if your cig lighter still works cz the air and cig lighter are controlled by the same relay, then take the motor out and test it with a 9 volt and some wires. and from there on if you still haven't figured it out, then we're air fixing buddies.
booja
Performance & Maintenance
12-23-08 08:32 AM
