Name that hose.... I broke
Old 03-27-14, 10:35 AM
Albatross
Albatross's Avatar
Default Name that hose.... I broke
Hey guys doing my spark plugs last night I went to remove those hose and broke it. Just wondering if I need to replace it or if plugging off the holes is fine (car idles and revs fine with holes plugged)
I looked at vacuum line diagrams but can't seem to find it on there. Halp?
Old 03-28-14, 12:09 PM
mecheng10
mecheng10's Avatar
it looks like it could be for pcv valve.
Old 03-28-14, 01:01 PM
Ali SC3
Ali SC3's Avatar
Its not for the pcv valve its a special hose for emissions on 96-97 motors that runs from the idle valve to the fuel rail to help deliver a better fuel spray at idle and burn cleaner or something like that, Its all a bit vague in the descriptions anyhow. All you need to know is that you can just replace that hose, take that hose to the auto shop and get generic heater hose in the same/similar diameter, that is what I would do its stronger and will last longer. the stock ones tend to get hard over time and then they crack, leaving you with a poor running car. a good maintanance item to check and replace if tis too hard or the edges where it slips onto the pipe the rubber is cracked.
lexuscfour
09-22-15 08:08 AM
aks92sc400
12-30-13 05:31 PM
keskipper
09-16-10 07:50 PM
GS4VIPbOSS
07-05-08 02:54 PM
Dx3
01-07-08 11:03 AM
Quick Reply: Name that hose.... I broke
