- Info Computer Question
- Update2 - Alenzas @25,000 mi.
- RX350 tranmission fluid: revisted
- Need some help buying a 2006 400h
- HID Headlamp out...how to replace?
- About to purchase '08 RX350
- Trailer Wiring - Switching the Junction Block
- ive lsot the car manual
- Car won't start-Error Shift to P when start
- Thundercloud RX330 Wheel Rim Trim Color
- Need part for roof racks
- RX330 door weatherstrip/molding
- Just purchased 2005 RX 330 AWD - How did we do?
- 18 inch alenzas (Bridgestone)
- RX350 Nav Disc Change
- '07 rx rattles from where?
- Roof rack noise
- Help Need to get my trailer lights working to go camping!
- Nav-please insert disk
- Chrome or Painted Door Handles?
- Alternate 18" Tire Sizes?
- flat tire day
- Where is the wheel lock key?
- DVD-A Disks
- Purchased a 06 RX 400h
- Considering 2004-2005 RX330 FWD for the wife, have questions..
- Cruising Range and Avg. mpg
- michelin tires
- Sunroof Problem-Bizarro
- 2007 RX350 - Nav access while moving
- Courtesy Step Light
- Electrical Question - Signal Mirrors
- 2009 RX350 HVAC Question
- RX330 Mod to open rear window?
- Fuel filter
- How does the 2004 RX330 monitor tire pressure?
- HID Fog Light Upgrade
- Need help from the RX guys...
- help with part number please
- RX service intervals
- Rx350 Double Din install Help..
- Rx 330 questions
- Accessing RX 400H Foglights?
- Which year is best?
- Battery Problem
- Instructions on replacing marker light
- how do I reset the maintenance light?
- Paint Match
- Paint flaking in the undercarriage
- No driver side air conditioner cooling
- Just bought 06 RX & have a few questions
- Water drip underneath RX
- window trim piece
- Remote Starter
- Creaking Dash
- RX330 Programming Options
- Extended CPO?
- CD player not working!! 2005 rx330
- master key
- Need advice on cleaning the engine bay(RX350
- performancechipsdirect.com
- window mystery
- Looking to buy Front Grille-US Market
- Need Help With Negotiating – 06 AWD 330
- Veering to Right
- Is there a way to tell AWD from FWD?
- error 4
- RX350 Transmission
- 2004 Radio Amplifier Failure BTDT?
- Power Streering
- HYelp!
- turning 100k
- RX 400h and Bluetooth problem
- Help! Thinking about buying Rx330 should I?
- Navigation system wrong setting, need help
- 2004 RX 330 Power Train Warranty Deductible
- When shifting from 'P' to 'D'...
- Hello- first Lexus
- roof top carrier
- Replacing brake pads. Do I need to bleed the brakes after?
- Seats Hurting My Back
- Chrome Grill??
- Other than RX330/350, what else would you consider?
- whistling when i turn on the windshied wippers
- Aftermarket navigation
- Chrome door handles: which route?
- My heater doesn't work except setting at high level? What give?
- Rx330 question regarding side view mirrors!
- rx330 rear trunk not opening automatic
- Disconnect Battery Sunroof trouble?
- Windows don't work.
- Help...
- Installing OEM XM kit in 2006 rx400h
- RX350 and Thule Bike Roof Rack
- my 22" wheels dont fit
- RX 350 best tire price
- Rattle/Squeak/Rubbing Noise on Center Console
- 04 RX 330 make bubling sound at front dash? also heater does not works...
- AFS Light Tired of watching it blink
- is this true?
- Tires
- RX400H Hybrid Emblem
- Just pulled the trigger on an 08 400h!
- Any experience with the Parada Spec-X Tires?
- navi problem!
- Installing basslink
- 2005 RX330 cargo Tarp & Net & Shifter Knob?
- Side Mirrors when in Reverse
- decision help!
- Moonroof wind diverter rattle
- Service Bulletin
- rx330 performance package
- Cargo nets
- aftermarket audio in 400h?
- My debut, at Hot Import Nights: Austin 4.11
- Reliability?
- Update: Alenzas @ 15,000
- Chrome Wheels For RX330??
- Cigarette Lighter Rx330 Stopped Working
- Engine "knocking" on 2009 RX When Cold
- Silver '06 RX330 --clear coat OR NOT?
- Motive brake power bleeder
- Anyone knows this
- 12v Battery dead on the hybrid...
- Correct Tire Pressure for RX400h
- Actual Gas Mileage vs Computer Read Out
- Accessory code help
- RX330 tail light bulb replacement
- Is there anybody check and adjust valve clearance?
- Consider an 04 RX330 with 93k Miles....how reliable?
- Rx 330 or 350?
- Hybrid Badge
- engine temperature gauge
- Looking for a complete ATF change DIY photo instruction
- RX330 prt# Toyota equivalent Air filter?
- 07-08 LEXUS RX LED DOME LIGHTS - Vehicle Specific!
- DIY Power Steering Flush
- Side Signal Marker for the RX
- PCV Valve Replace help
- wheels for RX 330
- My 2004 RX330 Hood Strut is not supportive any more
- Extended Warranty Cost
- Didnt even put my new plates on and someone broke in and
- Rx 330 06 repair manual
- been searching high and low for these...
- driver side mirror hit and run
- Do you know someone who can read Japanese
- Internal Light Bulbs 06 RX330
- Color Code?
- mp3 dvd in '04
- Power Windows stuck!
- lost a tool in the engine compartment
- RX 330 trailer hitch info needed
- Side Mirror Cann't Be Adjusted. Help!
- Comments on the new RX design?
- How to identify AWD RX400h
- DTE distance to empty
- Just found a hidden service menu in my 09 Pebble Beach Edition
- 1/2" Drive Torque bar 80 ft-lbs where?
- My PB edition 2009 RX350.. AWD or FWD?
- Service at a Toyota Dealer?
- RX350 Oil Change Help
- Oem Front Bumper Vs non-Oem
- Help a lady out with service needs
- Deciding color combinations - anyone have chrome?
- better wheels and tires for better handling?
- 2008 RX400h... Already rusting?
- Removing the cross bars, simple DIY
- Seeking 2008 RX 350 AWD with NAV
- may purchase RX330/350
- 25+ mpg
- Bloodbath for someone at end of my lease...
- RX330 - Planning To buy
- RX330 Fuse Box
- Strange alarm, no indicator
- Transmission Fluid
- Anyone experiences this?
- Vais SLI I Agree Bypass & Phone bypass wire cut
- My findings Vais vs dice in NON nav RX
- All weather OEM floor mat
- 2004 RX330 - Options for playing iPOD
- New tires that WON'T Squeel!
- What Ipod integration unit to use for my 06 with no nav?
- Transmission Release "thunk"
- Proud new owner of an '05 RX 330 with a question
- pics of my fully upgraded rx330 stereo; now with more nav
- Any One Seafoam Your Rx330?
- 2008 RX350 not driven in 4 months
- Kuda mount
- I regret buying this rx350
- Lexus RX330/350/400h LED Turn Signal Mirror
- 06 Trans 02 Trans Difference
- Novice has question?
- drivers window works; other 3 do not
- HID Retrofit
- Bluetooth A2DP wtih RX350
- New motor, gears, etc for sunroof.
- which year hybrid got blue emblem grille in the front?
- Nav overide
- RX330 TRansmission Cooler Lines
- DIY: Remove condensation from headlamp (temporary)
- Parking Brake Switch for 2005 RX
- 2008 RX350 Air Filter/Cabin Filter
- Stupid phone book entry
- Door came open
- 08 RX400h -- bluetooth interference / buzzing
- Repair Manual for 08 RX350
- OBD II Code 2195
- Multiple warning lights
- Transmission pan: How to get it off to get filter out?
- Radio Head? After Market in dash nav?
- FM Transmitter and FM Radio? or MP3 ?
- Vsc trac off-engine check light came on
- A fly stuck in the taillight
- Rattles
- Length of Cargo area with seats folded down?
- Can this be done?
- 2004 RX 330 0-20 oil?
- 2004 RX 330 Idles too fast cold
- 2005 RX330 Transmission Question
- Who engineered this car?
- 2007 RX350 SAT radio in a 2006
- Explain
- RX330 Vanity Mirror Replacement Bulb
- RX350 Uneven tire wear at 11,000 miles? rattles in dash?
- BIG Problem
- Problem with Navigation system as well as Bluetooth
- Keeping it in the family: 09 Pebble Beach
- used oil disposal
- opinion:New tires
- iPod Adaptor - Does anyone know how to use it??
- Engine start button kit
- Easy aftermarket radio replacement option!
- Programming duplicate keys
- Power Steering Fluid Leak with my 04 RX 330
- Lexus logo scuff plate removal
- RX330 powerless
- Lower seat back cover
- what kind of transmission service I should do?
- Front end noise caused by tires?
- New Owner Nav Question
- headrest doesn't adjust forward
- Wheel alignment?
- the rims are on the rx!
- has anyone else had this problem.
- Is the maintenance expensive???
- RX headlight condensation / moisture fix - DIY
- 2009 RX Sound System - Cheap Sounding :(?
- Struts questions
