Trailer Wiring - Switching the Junction Block
I have a RX330 without the towing option. I just bought a Lexus hitch, and I should have no problem mounting the hitch and installing the wiring (with the help of other posts). I keep reading that you need to install a new Junction Block (Part #82670-0E040) for the lights to work correctly. Is this true? Is there any other way around this? Has anyone done this that would be able to help?
Thanks!
Thanks!
Hey i just did the whole install on mine and that box is about 200 or so through lexus.I went to etrailer.com and they sell a plug and play harness for 60 or so shipped and it works great no issues and save some money!Hope this helps
Thanks for the reply. How does the plug and play harness work without the Tow Option package? Is there a place to plug the wiring in even without the package?
Yup just go on the website and thees a how to install very easy!No you do not have to buy the box it bypass all of that with the etrailer wiring harness.Well so far so good with me everything works great!
My 2006 RX400h didn't have a tow package. I pulled a Lexus hitch from a RX350, which came with the wiring harness. Installed it and plugged it up and everything works, at least I think so. I put on the hazard lights and the trailer lights blinked. Didn't test brake lights. What kind of lighting problems are you guys having?
No real issue just confused if Im adding the Lexus Brand Low package if the Lexus OEM Junction Block Assembly No.1 Part Number 82670-0E040 is required. And where does it go and what does it do?
http://www.sewellpartsonline.com/par...id=72896&all=Y
MRKilroyNot having any issues yet, went to order the tow package and found out that I "may" need some converter box to enable towing on my 05 rx330 other than the tow kit that comes witht eh 4 flat plug that connects under the cargo tray.
the part I dont know if i need is here:
I have the none towing pkg rx and when i hooked everything up it didn't work due to i was missing a module to convert the voltage for the trailer lights.Bretzky it's really easy not hard at all just a tip i ended up cutting a 1" maybe a little less in the storage compartment.The reason i did that was when im not towing anything i just pull it from there and no wires are hanging very neat TRUST ME it works!!
MRkilroy that is the module box to get the right voltage to the trailer lights i THINK it goes underneath behide the back seat I THINK!I just ended up buying a wiring harness from the site i mentioned above it works great.Save you about 130 or so and it worked well for me!
well, I decided to call LExus Corp and see what they had to say.
I gave the very nice guy on the phone my VIN number and he verified my information and stuff and asked what he could do for me.
I told him that i "lost" my origional window sticker and wanted to know the "options" that were on my vehicle from the factory.
He said no problem and started from the top. HH, Bla bla bla, then "TO" i asked what that was and he said its the upgraded altinator, trans cooler and high cap radiator. I said cool. can you email me or fax me that list of options so i can have a copy of it, and he was able to fax it to me. So it looks like I'm all set to install the tow package with no electrical issues !! Thanks for the help guys !!
I still need to know where the junction box assembly is installed. Anyone know? I called Lexus corp, gave them my VIN, and my 2005 RX 330 does not have the tow prep package.
I am having the same problem.... anybody? 200 bucks for the lights to work?? come on! Why install all the wiring harness if its not going to work! other than etrailer, any ideas of how to get this to work?
I ended up switching out the junction box. It's a pain but the lights wont work with the current box. its a much cleaner look than a generic wiring harness.
Directions to install came with it. It was annoying to do, you pretty much have to take apart your trunk, but if I can do it I think anyone can. Sewell Lexus has pretty good prices for a dealership, but still not cheap..
http://lexus.sewellparts.com/accessories-catalog/Towing/RX330-2004/5457.html
TheGoodGuy
12-08-16 03:58 AM
boatable
RX - 3rd Gen (2010-2015)
12-22-10 08:32 PM
turbosw20
07-02-09 09:58 PM
