My heater doesn't work except setting at high level? What give?
Old Apr 28, 2009 | 01:05 PM
bugeyes's Avatar
bugeyes
Default My heater doesn't work except setting at high level? What give?
this is for 04 rx330, coolant is new and full, how do I fix this?
Old Apr 28, 2009 | 01:27 PM
salimshah's Avatar
salimshah
25 Year Member
Did the problem occur after the coolant was replaced?
DO you hear bubbling sound when heater is on?
If so there may be air in the system.
Salim
Old Apr 28, 2009 | 02:01 PM
hesham1's Avatar
hesham1
are you talking about the fan only working at certain switch positions (lo, med, hi). If so, Its a blower motor/switch issue. This is common in many vehicles as they age. Usually about $75 to fix at your local mechanic
Old Apr 28, 2009 | 08:14 PM
bugeyes's Avatar
bugeyes
We had lexus dealership changing the coolant for us...also, there was no 'switch' to turn the fan, 04' rx330 had touch screen control for everything so the fan has nothing to do with it, it will work according to the speed, but what I am talking about is the 'heat' that come out from the vent, it will just come out cold air until I set the temperature to 'max hot' then the heat will come out...
Old Apr 28, 2009 | 10:27 PM
salimshah's Avatar
salimshah
25 Year Member
There can be different reasons for this problem
1. fan speed [controlled by screen or ****], or automatically when in auto mode. There is an indication on display how high the fan speed is.
2. failure of heated-up coolant [to get hot air, you need to wait till the engine temp warms up to "normal"] to get into the heat-exchanger.
3. air flow which is based on fan, dampers/diverters and also the cabin filter.
The hints you got here cover 1 [hesham1] & 2 [mine].
You can save the trip to the dealer by making sure that there is no air in the coolant circuit. We recently talked about it in the thread you started
https://www.clublexus.com/forums/rx-...not-works.html
It must have not worked for you.
I suggest take your RX to the dealer and let them fix it for you for free ... I assume your problem happened after the coolant replacement.
Salim
Old Apr 29, 2009 | 07:22 AM
tfischer's Avatar
tfischer
25 Year Member
I had a heater problem in my '04 RX which turned into an intermittent overheating problem. It seemed like a bad thermostat to me, but the dealer found that the radiator was leaking. My car was still under CPO warranty, but I was informed that there was a bad batch of radiators in some '04 cars, and Lexus would replace them for free, warranty or not (and Lexus probably gets reimbursed by the radiator supplier). It's pretty unusual for any radiator to go out, especially after only a few years, and especially in a luxury car like this, but they made it right with the free new radiator. Also: I had no signs of leaking in the driveway or parking areas, so the leak was not major, and probably only under pressure, but the heat needle would go up almost to the top of the hot end and then slowly go back down. After the second or third time this happened, I was off to the shop immediately with no appointment and a good result.
Or it could be your thermostat.
kelvin13
Aug 14, 2014 04:50 AM
damiendada
Jul 25, 2013 05:41 AM
chroniekon
Jun 26, 2012 10:37 PM
Lexozz
Maintenance
Dec 22, 2002 12:04 AM
