my 22" wheels dont fit
Old Apr 23, 2009 | 11:31 AM
Frankr66's Avatar
Frankr66
Default my 22" wheels dont fit
i just ordered some MAAS MOD 22" wheels and 265/35/22 tires. lots of guys are running these so my question is how do i make them fit? they are hitting the strut tower and the plastic on each side of the fender corners
do i need spacers? new offset on the wheels? smaller wheels?
and to think i was going to get some 24'" wheels originally
Old Apr 23, 2009 | 01:43 PM
Grumpa72's Avatar
Grumpa72
Home Depot? Get a nice Sawz-all with the metal cutting blade?
Old Apr 23, 2009 | 02:38 PM
iKon_RX's Avatar
iKon_RX
"MAAS MOD 22" wheels and 265/35/22 tires"
whats the width and offset on the wheels?
then I can tell you how big of a spacer to use..
Old Apr 23, 2009 | 08:13 PM
Frankr66's Avatar
Frankr66
anybody here running 22's that can provide advice on what it takes to get them properly fitted?
Old Apr 23, 2009 | 08:21 PM
LexFather
Guest
Posts: n/a
I have never heard of that brand. What tire size are you running? Are the tires too thick? That or your offsets are way off.
Old Apr 23, 2009 | 08:59 PM
Frankr66's Avatar
Frankr66
265/35/22 which is the size i see everyone riding 22s on 330/350s.
the wheels are 2 piece
Old Apr 24, 2009 | 12:01 AM
mowmow's Avatar
mowmow
Wow nice wheel
Is this a 22x8.5 or 9.5 ?
maybe your offset is too much ??
Old Apr 24, 2009 | 01:17 AM
iKon_RX's Avatar
iKon_RX
Once again what is the witdh and offset on your wheels????
the diameter of your set up is the same as mine so I wouldnt be giving wrong info...
Old Apr 24, 2009 | 06:06 AM
mikez's Avatar
mikez
If he is hitting the strut towers AND the fender lining then the wheel is too wide man lol
Old Apr 24, 2009 | 08:39 AM
Frankr66's Avatar
Frankr66
the thing is that i only have issues in the rear
my rx is awd, im guessing there is a big difference in the clearance of the rear with awd vs fwd
Old Apr 24, 2009 | 09:53 AM
LEXveryG8's Avatar
LEXveryG8
Hey Frankr66, I'm only basing this off of your story since you didn't provide any offsets and such. But, if your hitting the strut tower and the sides. The only possible explanations is the tire profile and your offset. If you have something that is greater than +30 on a 8.5+ width you most definitely hit the sides. And hitting the struts would be your tire profile. For a wider rim you will need a lesser amount of number on your offsets. Correct me if I'm wrong.
Good luck on fitting them,
LEXveryG8
Old Apr 24, 2009 | 10:30 AM
tod071's Avatar
tod071
Wow, lot of people want to help, but you're not providing the information needed to help you. Do you know what the offsets are? Can you provide the widths of the rims?
If not, just get new rims because we can't help you without that information.
Old Apr 27, 2009 | 01:28 AM
CK6Speed's Avatar
CK6Speed
Knowing the width and offset is the key. Without that we can't be much help. While I ran 20" rims only, my 20x8.5" rims had an offset of +20 front and rear. I had zero rubbing, was lowered with Eibach springs, but I was very close to the rear strut. With my same rims, if I had an offset of maybe +35- +40 I may have hit the strut as well. Front had lots of room to spare.
Anyway, the fact that you are rubbing the strut meas your offset is either too high, the rims are too wide, or both.
Old Apr 29, 2009 | 11:57 AM
Frankr66's Avatar
Frankr66
thanks for the responses guys im sorry but i dont know the width or offset since i ordered them from a company who said they knew what to order for my application.
the manufacturer has shipped me a spacer with different lugs i am going to try tomorrow; it does look like if the wheel was a bit more out from the back it would clear both the strut and inner fender linings since they get closer in the rear. My only concern is having the wheel now sticking our from the fender and not lookign right or tracking correctly.
I will see what happens tommorrow and report back
Old Apr 29, 2009 | 01:46 PM
iKon_RX's Avatar
iKon_RX
In the inner barrel of the wheel it should have stickers indicating withd/offsets/date made.
Also you can check behind the spoke and near the hub area to check for #s.
look for et xx, which means offset #.
