- Wheels Spacers/Adapters
- Roof rack
- Is it easy to change the amber interior lights?
- 2008 RX 400h vs 2009 RX 350 vs RX 330
- Debadge the rear
- Struts - Coolant Leak - Styrofoam in Bumper
- RX 330 Recall - Headlight Moisture Issue
- 3 Q about 2005 rx
- FWD vs. AWD for Rx 350 - 2008/2009
- Will it fit? 18x9.5 5x114.5 255/18/40
- Shelf life of oil
- Push Pin Part Number
- Airbox - captive nuts - where can I find?
- Blacked out headlights
- Cost of having a new key cut
- Question: 06' Rx ML Wiring
- How much for 60,000 mile service
- Rattling noise 2004 RX330
- RX400h Cabin Air Filter Replacement
- Eh? No Visor Extender?
- What to use to clean/polish roof rack
- Rx350 Tilt/Telescoping steering column doesn't always retract when key is removed
- 2007 Rusty Calipers
- The floor mat clip recall
- Mouse in my glove box!
- Voltmeter to battery shows 30V ac, 14V dc
- Bobling sound over right front tire
- how to initialize after battery replacement
- price for power steering change
- White dust problem on dash
- Help 2005 RX 330
- USA SPEC PA15-TOY iPod Interface '07 RX350
- LS460 Style Rear Bumper for RX
- 08 RX 350 Battery Change issue
- Moonroof Weatherstripping
- Condensation dripping from under glovebox
- Help! Squeaking park brake
- Tire sensor light keeps coming on
- I'm a spammer and can't read
- What is done with dealer air condition service ?
- Sideview Mirror dead.. pls help !
- Average mpg you are getting now?
- Broke Driver's Side Mirror
- 08 rx350
- Transmission Lag
- Is '30K basic service include brake fluid change'?
- Need some help from the RX forum experts on catalytic converters (dealership screw)
- No Sound, HELP!!!!!
- True Delta Results for the RX
- Someone tried stealing my Lexus
- Blown Head Gasket?
- How long between synthetic oil changes?
- Mudguards are 2009 Rx 350
- 2006 RX400h Bluetooth/iPhone
- Spring/Summer/Fall Tires???
- Spring/Summer/Fall tires
- New Here
- 2006 rx400h driving light to led change
- 60,000 service cost
- Power Mirror Problem
- Backseat Door Problem
- Future RX350 Owner
- Navi Override ?s
- Personalization options
- Remote keys linked to seat memory
- Power steering fluid
- Reversing Camera - Switching back to it
- Doors unlock
- 2009 RX Wheels
- Mark Levinson System
- Is this an oil leak?
- 08 RX350: How many quarts at change?
- Poor radio reception
- DOT 5 Brake Fluid?
- 110,000 mile service. How important is some of this?
- My Proud Daughter & Her RX 330
- Lexus Rx330, 05, Recall..How many time so far?
- 5w20 or 5w30 on 2009 RX 350, Any Lexus NA Official Statement?
- Driving without the Heat Shield
- Leather Maintenance
- Does Anyone Use 0W Synthetic Oil in Their Lexus?
- Moving from GA to NJ : performance of 2WD in the snow ?
- 2009 Rx 350 Rims
- How do you turn auto-recirculation on?
- buy a used certified RX
- RX330 Panel Button Corruption
- Door rattle
- Free Car Washes - really?
- Rattling
- Just Bought My 17 y/o Daughter Her First Car: 2004 RX w/nav
- Dash Squeaking
- Noise at low speed
- fixed many issues today - AFS off light, TPMS light, brake job
- 2005 RX330 - I'm on my 3rd battery!
- New 2009 Rx 350 Owner Here
- Roof cargo/box for rent
- Buying our first SUV!
- My lexus RX330 2005 "Air Circulating" light is always on when the engine is on???
- Find Chrome Door Handles..any idea?
- Different Mileage during a 5K miles trip
- HUD Idea for the RX
- What Were Factory-Installed Plugs and Heat Ratings for 2004 RX 330? Info Appreciated
- Opening Rear Hatch with Kayak on Roof
- Whistling window
- Removing Water Spots Behind Screen on Radio
- RX330 check engine light/VSC/Tracking off light on..HELP!
- Negotiating on a CPO RX350
- Did you read this forum before purchase?
- My first Lexus any good advice for a newbie?
- 2004 Navigation
- Damn AFS light
- Timing belt change nightmare
- leaking Rack&P...Now right cv boot split
- Have a major issue
- Rx330 Awd Fluid Replacement Question
- Ever done freon fill on a/c ?
- Mileage Has Dropped After Dealer Installed New Plugs, Etc...Any Thoughts?
- Seat Wobbles while driving 05' Rx330
- cracked rims on a 2007 RX350
- 2008 RX w/ 100K miles, worth purchasing?
- New knob!
- Engine: Rebuild vs Swap
- E15 Ethanol Blend Coming
- New Lexus RX400h recall
- How to Replace Brake Lights
- Replaced My Current Key Case With Aftermarket Flip Type Key Case
- Need help!
- Water Leak on A Pillar
- AC / Engine Cooling issue - please read if applicable
- Back triangle window's frame fell off!
- CPO and scheduled maintenance
- RX330 headlight replacement recommendation/cost
- 2004 Removing Radiator
- RX350 Cramped passenger seat
- New Dubs for the RX
- Help needed
- AC works intermittently
- Replace rubber stem tire valves with metal stem tire valves?
- AC Servo Clicking
- Matte Black RX
- Put in a Transport Canada complaint form
- Identify this part
- Master Brake Cylinder
- Changing the exhaust will affect CPO??
- Are internet prices negotiable?
- switching out lugs(bolts) to stock in the rear. Do I have to remove the rotor???
- Would you bring your RX330 to Midas?
- Transmission Issue?
- Navigation DVD RX 330
- Happy Father's Day
- 07 Oil filter cap assembly
- Different Type of Projectors for the RX
- Toyota Harrier / Modulare Forged 24" - Airrunner - Vertex - Exclusive Zeus
- Rear mat getting a little dingy?
- Engine wont start
- Stock 330 - Best Wheel Design
- Sprintbooster to RX330/350s?
- windows molding scratches
- Latest Nav software upgrade for Gen 2/3?
- OEM Brake Pad/Shim Question
- Iphone Compatibility on RX330 w/NAVI
- need some rim advice?
- Bunch of lights on the dash, again
- Power Acoustik Head Rest DVD Installation
- Rx330 a/c air recirculate button default ?
- Will Gen3 RX350 19" wheels fit the Gen2 RX350?
- DIY (Video): Rear Door Handle Removal on RX330/RX350/RX400h
- VSC & brake light - intermittent
- 2004 RX330 AWD air suspension conversion work
- What are these wheels? Chrome/Aluminum/Other?
- RX350 08 or 09 differences ?
- Modded
- Single beep as the door opens
- Unknown beep
- Rattle near drivers side door / footwell...!!
- Driver side window control no longer works
- A/C noise - from clicking and grinding to chirping... AAARGH!
- Evil smell at 90?
- Vais SL2i-UP issues
- Whining sound at low gear, low rpm
- Another purchase help 04 rx
- DIY (Video) : replacing remote fob battery
- 2004 RX330 Insurance Rate Increase
- DIY (video): replacing boot illumination lights
- 2004 rx 330
- Help needed in potential purchase
- Has anyone had a timing belt break?
- O2 sensors
- Free gas!
- XM Install questions on '09 RX350 w Nav
- New to Lexus and the forum
- Cannot eject dvd from RSES/DVD rx330
- Remove and replace dashboard and pillar speakers?
- New owner.
- 04 Rx330, all service records...$17,977. Should I bite?
- Lexus RX Chrome Rim Issue
- Have you had to replace battery under warranty?
- Timing belt/Camshaft and crankshaft seals
- Alignment is so important - look at my tires
- Are you using a K&N air filter?
- RX330 Front Wheel Bearings - DIY Step by Step
- Independent Lexus Service in Orange County, CA
- 2006 RX 330 rear mirror
- so i changed my transmission oil and filter
- Inverter Assy with Converter Question
- Navigation system and menu gone with short
- I need a roof spoiler/wing
- RX330 white fog when air conditioner is on
- RX330 gets a DNX6960
- Traded the RX330
- Mud flaps?
- Newbie!
- Check Air Conditioning Warning
- 2004 RX330 Oxygen Sensor Replacement
- The Official "What have you done to your RX today thread" :)
- '08 rx400h hatch jammed
- Front license plate and the carwash...
- replacement windshield
- DIY (Video): Door Handle Removal on RX330/RX350/RX400h
- DIY: Toyota Highlander Tow Trailer Hitch Part# PT228-69045
- TomTom iphone app with bluetooth???
- Car Cover for my 2007 Lexus RX 350
- Aftermarket Weak Antenna
- ipod kit
- factory wheel specs
- 2008 RX belt noise
- Coastal Tech Nav bypass issues
- WTB Inverter/Converter RX400h - 2008
- CV Joint Boot
- HELP!! Today my wife caused $17,000 worth of damage
- 2007 rx350 knock noise
- A new owner :)
- TD3000 Lip (or whatever it's called) measurements
- 2006 RX 400h transmission leak
- Fuel mileage loss?
- P0705 Transmission Range Censor
- Rx330 weird noises and gear problems.
- Alpine Aftermarket DVD player 2009 RX350
- New (to me) RX350 - dull dash pad issue
- unlock all 4 doors on one press?
- Is my RX AWD or FWD?
- Tire Profile Change
- Power windows wont work
- 08 RX350 - Service Manuals?
- whats wrong with my 2007 lexus rx350
- 40,000 mile Service
- RX350 tuneup by dealer or independent shop?
- 2004 RX 330 Struts
- Looking to buy 08 or 09
