so i changed my transmission oil and filter
so i just finished changing engine oil, oil filter, transmission oil and transmission filter. checked the air filter its clean ( was changed 1k ago)
changing all that was a waste of money -__- because trans oil was pure red, engine oilwas pure gold, dealer changed all that last week before i bought it and they didn't tell me. but its worth knowing that everything been changed by me and with good quality oil and its good to go,
one problem i went to Lexus dealer to buy ATF and they said drain the oil trans, and add 3.5 qrts, well noway its 3.5 because i put 4 and still i believe i need one more quart
do you think i need to put more because i changed the filter too? I've been reading and searching but it looks like you guys don't replace the filter?
im on my way to get one more quart i hope driving the car 17 miles to get it wont hurt the trans
Just a note of caution. You did use Toyota "World Standard Transmission Fluid" right? The RX330 (2006 & earlier) used a different fluid (Dextron II) that would be harmful to the RX350 (2007 - 2011) transmission.
Here is the states a CPO Lexus would have all maintenance done before delivery to the customer. It appears they do the same in Canada.
i did buy my ATF from toyota it is WS and its not mandatory for the dealer to do that, i did not buy it from Lexus dealership but i guess they changed everything, only couple problems that i have and they are sending it to Lexus on Wednesday is my sunroof is rattling i don't know if i can fix it my self because its gonna be a headache making them hear the rattle second my memory seat isn't working when i press 1 or 2 only the mirrors move and the steering wheel, and third is my tires are cracked all four and i believe safety they have to change four tires
Super Moderator
In the RX300 for instance, if you remove the filter, some additional fluid will come out. I've never measured it, but I plan to the next time I do the filter, but I would estimate it could be about 1/2 a quart
Super Moderator
Super Moderator
