RX330 Front Wheel Bearings
I'm about to do my front wheel bearings on my RX330. I'm curious if anyone would want a step by step photo directional post afterwards. If so I will make sure and take pics as I go and post.
More DIY's the better!
Yes, it is a pain, I did it on my RX300....I would highly suggest getting the hub/bearing together, it will make life a lot easier...Also if you dont you will have to have the bearing pressed out of the hub, locally the machine shops wanted $45 per hub...good luck ....I take it back, cant seem to find them together, so remove the hub, take it down to a machine shop and have them press the bearing out, and new one in....again good luck
Just remember the bearing is pressed into the hub, YOu would need a 12ton press to remove it. That is what I did, but boy it is a scarey thing when it moves and make a bang noise...The Harbor Freight press almost didnt make it. Yea saved some money, and got a press in the deal...Good luck. by the way google it and you will find write ups on press the bearing out of toyota hubs....
Am a bit uneasy about a future need for such.
ArmyofOne
04-16-19 05:31 AM
M K S
02-11-16 06:43 AM
