Engine wont start
Old Jun 16, 2011 | 12:52 PM
shikbas's Avatar
shikbas
Default Engine wont start
Hi ,I need your help please,i replased the battery on my 04 330,engine will start but will die immediately unless i push the gas,autozone checked the battery/alternator fine,checked the computer no saved codes...
Your suggestions please
Old Jun 16, 2011 | 12:59 PM
HtownBlue's Avatar
HtownBlue
Originally Posted by shikbas
Hi ,I need your help please,I replaced the battery on my 04 330,engine will start but will die immediately unless i push the gas,autozone checked the battery/alternator fine,checked the computer no saved codes...
Sounds to me like your throttle body is dirty and stuck up a little. Not sure if you are familiar with what that is, but you can Youtube "Cleaning Throttle Body" and find several videos on how to clean it cheaply. You will need an 8 or 10mm socket and ratchet with extension, some rags, throttle body cleaner.
Its fairly easy to get to. On the older RX300 models, this was a common problem. My initial guess is you have a throttle body issue. You could have a problem with the Idle Control Valve, or idle adjustment, but I would clean throttle body first.
Old Jun 16, 2011 | 01:49 PM
salimshah's Avatar
salimshah
25 Year Member
Do a search on IACV, idle air controller valve. RX300 forum has plenty of discussion on this .. and you may among the early few of RX330.
Salim
Old Jun 16, 2011 | 02:16 PM
shikbas's Avatar
shikbas
but the car was running like smooth like butter before battery change
Old Jun 16, 2011 | 04:06 PM
salimshah's Avatar
salimshah
25 Year Member
It will be still smooth, if it only hold idle.
Salim
Old Jun 16, 2011 | 04:54 PM
HtownBlue's Avatar
HtownBlue
Check all your fuses in your fuse box. If you did not do the battery change, someone could have caused a short in the system by mistake. Check your fuses first, then your IACV, and throttle body.
Old Jun 17, 2011 | 06:19 AM
lexus114's Avatar
lexus114
Maybe you spiked the ecm. Try disconnecting the neg. terminal for a few minutes and see if that does it.
Old Jun 17, 2011 | 06:24 AM
Kostyan's Avatar
Kostyan
could this be a fuel pump?
Old Jun 17, 2011 | 06:35 AM
mandyfig's Avatar
mandyfig
It was running before until the battery was changed. Go trace what might have changed.
Old Jun 17, 2011 | 05:33 PM
HtownBlue's Avatar
HtownBlue
I wouldn't think it was a fuel pump issue, as the fuel pump usually dies completely, not a partial failure causing a low idle due to lack of fuel. I would check the FUSE for the fuel pump, but I wouldn't think the pump went out. If the pump was out or not working, it wouldn't even start.
Old Jun 18, 2011 | 06:45 AM
shikbas's Avatar
shikbas
ok guys i am back,i fixed the car,cleaned the af sensor and the throttle body,car started like new,,,,,thank you for your support
Old Jun 18, 2011 | 07:30 AM
draco's Avatar
draco
Shikbas have you got a walkthrough (with pictures) on how to clean the af sensor and throttle body. Have seen other stuff for RX300, but not anything detailing the RX330/350.
Old Jun 18, 2011 | 07:40 AM
salimshah's Avatar
salimshah
25 Year Member
OR
Just hilight the differences from the RX300 procedure.
Salim
Old Jun 22, 2011 | 02:39 PM
shikbas's Avatar
shikbas
ok guys,sorry no pictures,i just released the rubber housing connected directly to the throttle body,disconnect two hoses to the engine,took that piece of plastic out,sprayed the dody with generous ammount of cleaner fluid,brushed it well with an old toothbrush,respray the area very well,directed the sprayer towarg the sensor there,took the af sensor out and cleaned it,put every thing back,crank the car few times,it started ,smell the cleaner all over the place,running like charm,cut my finger,,always there is something to try and learn,very easy to do
nobelnabil
Sep 9, 2018 03:22 PM
ankurdave
Mar 13, 2017 08:20 PM
lhgdale
Mar 23, 2013 08:23 PM
CKIM
Sep 9, 2005 06:05 PM
LSPiNoY
Oct 14, 2004 12:00 PM
