How to Replace Brake Lights
Old Jun 28, 2011 | 06:19 PM
AlDavison's Avatar
AlDavison
Arrow How to Replace Brake Lights
Here is the situation.....
When I tap the side of the car, the break light goes back-on. The next day or so, the brake light goes off again. I guest it's not the light bulb because it seems like a short or something , but I don't know. Is there a fix for this or do we have to just go back to the dealer?
Old Jun 28, 2011 | 07:10 PM
HtownBlue's Avatar
HtownBlue
I would check the fluid level as well as the brake lights with the headlights on as well.
Not quite sure what your issue is other than your brake light being on.
Old Jun 28, 2011 | 07:26 PM
AlDavison's Avatar
AlDavison
When it goes off, I have to hit the side of the car to make it go back on.
--Al
Old Jun 28, 2011 | 08:22 PM
salimshah's Avatar
salimshah
25 Year Member
--Al
The socket is squeeze type and the wires are folded over the glass bulb. Pull the bulb out and with a needle nose pliers align the wires. A bit of contact grease will prevent corrosion.
And be careful banging on the side .. the sheet metal can dent.
Salim
Old Jun 28, 2011 | 08:26 PM
AlDavison's Avatar
AlDavison
Salim
I can get the socket out, but the bulb seem fixed. I won't move or turn.
--Al
Old Jun 28, 2011 | 09:09 PM
koric's Avatar
koric
I've had a bulb filament come loose and it would be on and off just like yours is. Try a new bulb first before you go mcguyver on it.
Old Jun 28, 2011 | 09:12 PM
AlDavison's Avatar
AlDavison
How to get the bulb out? It's not made to turn.
--Al
Old Jun 28, 2011 | 10:50 PM
koric's Avatar
koric
It is a wedge bulb. You just yank that sucker out.
Old Jun 29, 2011 | 05:09 AM
AlDavison's Avatar
AlDavison
The brake light is different from a tail light. The tail light socket just screw off. Then I can see the bulb to just pull it off. The brake light is different. The socket is permanent fixed inside the assembly. I cannot even touch the bulb or see it. It's like the whole assembly must come off.
--Al
Old Jun 29, 2011 | 05:31 AM
koric's Avatar
koric
--Al
Ohhh... i think you have to replace the whole LED assembly.
Old Jun 29, 2011 | 06:03 AM
AlDavison's Avatar
AlDavison
That's not so cool.
Old Jun 29, 2011 | 06:20 AM
lexus114's Avatar
lexus114
That's not so cool.:(
No,it`s not. Actually it sucks! Mine was acting up for a while last year, then all of the sudden stopped happening. I suspect I`ll have to replace it sooner than later.
Old Jun 29, 2011 | 06:50 AM
AlDavison's Avatar
AlDavison
How much do the assembly cost if it has to be replaced? Any ideals?
--Al
Old Jun 29, 2011 | 08:05 AM
lexus114's Avatar
lexus114
Not sure, but I suspect not cheap.
Old Jun 29, 2011 | 09:19 AM
HtownBlue's Avatar
HtownBlue
--Al
They run 165 at newlexusparts.com.
