- Brakes: no fluid flow to LR caliper. Any ideas?
- Engine ,VSC and Trac off light
- Missing Amplifier?
- Tune up for Lexus RX 350 due when?
- Warning Lights on dials
- Upcoming 2007 RX 350 Coolant Flush questions
- Updating cell phone
- 2004 RX Fuse Type?
- 2005 Lexus RX330 will not start. Good battery
- Torque spec for PVC
- Insulation heater pad behind the center console
- ignition coil
- Location of power outlets
- SiriusXM radio for 2009 RX350
- Alternator Belt replacement
- Bad Exhaust Smell on Startup
- CD Eject Problems - RX400 Hybrid
- Headlight assembly for RX400h
- Head light bulb help
- 2nd Gen RX ( one of the best looking RX generations )
- Complete window control & door electrics failure - 2008 RX400h
- Car wont start,
- after market head unit issue
- Can I use Lexus 250 abs module in a Lexus 250c
- Shop can't read codes on 2007 RX350
- brake light
- 2006 RX400h error code P1253 Pump Motor Relay
- Efi relay problem
- Install Dashcam 2nd Gen RX
- 2006 rx400h front coolers
- Acceleration
- Low beams are not very bright with D2S bulbs
- Power Steering Pump
- Transmission
- Air suspension RX300 2nd gen
- Low beam bulbs
- Trade 2008 RX350 for 2006 GX470
- What to buy RX 350 2009 or 2010? Please some enlightenment
- 2006 Rx 300
- 2009 rx350 blown motor
- Help with my steering wheel vibration, bump streer, veering to left after rack/pinion
- P0174 engine fault is this related to lambda Oxygene sensor bank 2 sensor 1??
- 2008 RX 350 Vibration/Noise
- Driver AND passenger side air vent cupholder, succes! :)
- Parking break stuck
- Hydraulic lifts for rear door.
- More Powerful Headlights
- Auxiliary adapter for 2007 RX400h
- RX 350 struts
- sunroof drain footwell leak and musty smell
- Oil change question
- Air Conditioning codes for 330
- Idler Pulley Acceptable Play for 2008 RX350
- Car Stuck At WORK!!!!
- Pre-purchase: 08-09 Steering Rack, lines
- MAF Sensor Cleaning
- Have to rock the RX to start it.
- Tire air pressure not sure what to do
- dashboard noise
- Reset Mpg
- Dashboard replacement
- 2008 RX 350 AC stopped working when new battery installed.
- Programming Toyota Fob
- Replacement Mirrors
- 2006 RX330 Dash Light Replacement?
- Gen 2 dash
- Towing a 6 x 12 Uhaul trailer with a 2008 RX350
- Radio antennae problem solved
- Front Seat Removal :: 2007 RX350
- Headlight Assembly & what parts need to be taken off to replace them & labor time?
- Manufactured
- RX 330 Power Steering Fluid
- radio antennae
- Looking for Denso Iridium replacement plug part #s
- Do you have to use Toyota coolant and brake fluid?
- 2008 RX350 Starter Replacement
- Warning lights
- One big screen
- Check Engine light: P1420 Evaporative Canister Small Leak
- 2008 rx 350
- My RX350 (2007) squeaks in the tailgate area.
- is there steering wheel reservoir on Lexus RX 400h year 2008
- intteresting underhood connector problem
- Hybrid AWD Questions
- Intermittent beep beep beeping coming from dashboard in 2005 RX350
- Will 2006 RX 330 autolock if key is outside the car?
- Solution for cracked Key cases
- Highway Humming/Vibration
- What's missing ?
- Engine oil cooling hoses leaked
- 04 RX 400h AWD vibration on Park
- 2007 Lexus RX 350 TPMS wont reset
- 2007 rx400h trailer wire location (with tow package)
- RX400h Cigarette Lighter/Power outlet max amps?
- Wiper Relay Assembly Issues
- Gas gauge/Fuel Level monitor 2005 RX330
- ES350 Struts
- Brake Rotor-Pad Combo @ Amazon RX330
- 2008 RX350 AWD vs 2WD ?
- Problems: How Serious and Should I Sell?
- 2005 RX330 ABS, and other lights come on
- Another Bluetooth Streaming Idea Thread (lol)
- Spare tire valve-extension
- 07 RX350 Alternator Upgrades? what's healthy voltage?
- RX350 trip
- Tires
- Does the cargo mat from the first gen RX fit the second gen RX?
- Aftermarket Tail Light Options?
- Reliability for 2nd Gen RX350???
- RX330 front brake rotor removal
- Screeching noise when going over bumps & breaking
- How to reset sat nav
- 2008 rx350
- engine pressure line issue
- 2008 RX350: Replace Ignition Switch? (Won't Start)
- Trans cooler leaks
- Road trip update
- Putting high miles on 2008 RX
- Who's the idiot driving this RX
- Clicking sound from transmission when P and R
- What part is this? (Need help identifying)
- Apple Car Play Upgrade-pics please
- cabin noise Lexus 2009 RX350
- brake lights
- NAVI disc player (blue port)
- 2005 lexus rx330 won't shift into second
- After Market & Long-term Ownership RX 350 Recommendations
- Navigation screen
- Part Website
- 2004 RX300 SE-L Suspension low at Rear
- Scratched up Interior door switch bezels- DIY touch-up
- pudding water on passengers side floorboard after heavy rain
- High pitched whine from right front wheel well
- Broke a piece of my vent, is there a replacement piece? (pics)
- I have lost power to my inside mirror
- Bringing RX330 up to AAA grade
- problems with new dashboard
- How do you remove the passenger fender of 2005 lexhs rx330?
- 2007 rx350 AWD rear lower lateral bushing
- So This Happened Today...
- Broken Wires to Glove Box Light
- AC problem
- Rx330 cargo latch
- Interesting Brake Job...
- 2004 Lexus RX330 2/ only 48k miles a couple of issues
- Door Panel Electronics Issues
- Sputtering in Reverse
- Engine splash shield
- Water spill on dash - major outage
- i think radiator
- Wheel well liner fell out!
- Missing coolant?
- warning light won’t turn off on Lexus ES350
- Replaced air strut AWD
- 2005 RX330 loose roof rack; driver side front
- Looking to get a 2009 RX. Opinions appreciated.
- I have a 04 rx330 that wont start.
- 2008 RX400h. AFS still not working. I've tried so much. What else can I try?
- Rolling sound. 2007 RX 350.
- Does anyone ever experience an occasional engine straining noise?
- How to remove abs controller
- 08 RX XM Antenna
- radiator replacement in 2007 rx 400 h lexus
- 2004 RX330 Engine Noise
- Techstream TPMS Error Code - HELP!
- Replacing o2 sensor
- Isimple/grom installation
- A/C problem-Just can't cool enough
- RX350 2009 Flooding in floorboards from Sunroof Drain UNANSWERED
- 2005 Lexus RX330 both rear window outside strips
- RX400h Airconditioning Drain Location
- center console: piece of metal .. ?
- Max wheel size on a 2006 RX 330
- How many quarts?
- Use XM Satellite Antenna Aftermarket Stereo
- What did I do to my parking brake
- Cigarette Lighter and CD Charger Not Working
- 2007 RX 350 passenger side axle removal
- deactivate the auto lock feature
- jobber PVC worth it ?
- Replace Frayed Seatbelt
- 06 400h- upgrading stereo. Has anyone installed a steering wheel control kit
- 2009 RX350 Stereo Wiring Question...
- how long till the batteries fail?
- sound proofing question
- Condensation in my Driver Side Headlight
- PAIRING TO iPOD NANO
- Center console
- Outside Tail Light
- How to Fix a Broken Antenna...
- RX 350 Cheap
- What is this in my RX?
- Need Advice - Buying 04 Rx330
- Gear shift not illuminated
- Center console stuck in forward position
- Squeaky rear seats
- Air Conditioner will not come on
- Need Help looking to purchase headlamp
- Unplug Battery when swapping parts?????
- 2004 RX 330 Ticking Sound
- New owner
- Engine Belt, then A/C Compressor, then Total Engine Failure?!
- Aftermarket Intake Installed
- Lexus RX400H AC stops cooling if idle for too long. Remedy is to shut car off for 5m
- Steering column woes
- 2007 RX350 Front Wheel Bearing DIY
- 04 RX headlight leveling sensor problem
- front wheel hubs & bearing? or just quality bearings?
- Japan AFR sensor installed in a Canadian built RX
- aging 2006 rx330 refresh
- 2008 Rx 350 cold start
- ABS pump or relay issues
- How do i locate the fuse and relay controlling the a.c
- AFS Light still blinking
- Still tailgate
- Check engine light
- Brake bleeding
- power drivers side mirror
- Maintenance for 06 RX400h - Just picked up one
- Advantage to Parts Selling Shops
- where to find a switched circuit under hood - 07 RX350
- cat converters
- Front wheel bearing replacement- torque specs ?
- Best stereo unit for 2007 rx400h
- Used 2008 RX 350???
- What lube for REar Diff...2007 rx400h
- P0443 rx300
- 2004 RX 330 Peeling Black Coating on Side Mirrors
- Interior Lights Work, but Courtesy Lights Won't Turn On
- Gen 3 or Gen 4 RX OEM 18" or 19" wheel and tire package fit? No problem
- About to change my rear diff and CVT for first time
- Ignition cylinder replacement cost
- Looking for a 07-09 RX 350 - questions
- Disabling the turn signal sound? (click.. click..)
- Things That Make You Go Hmmm
- RX330 transmission
- Window stuck in down position
- A/C stops blowing cold when idling
- Climate Control out 2004 330 RX
- Rx 400h a/c problem
- short low rumble vibration when braking?
- Parasitic drain?
- 2007 RX350 Stalling / Hesitation
- Tail & Brake lights
- Window noise driver side
- Power outlet issues.
- switch replacement
- Keyone Bluetooth connected audio playback cover art issue!
- 2004 Lexus RX 330 Sunroof & Starter
