How many quarts?
Old Aug 3, 2018 | 09:12 PM
kcw's Avatar
kcw
Default How many quarts?
I have a 2007 RX 350. Can someone tell me how many quarts of WS fluid I will need if I drop the pan and change the filter on the transmission?
Old Aug 4, 2018 | 07:47 AM
shikbas's Avatar
shikbas
You can measure how much fluid came out and replace
Usually 4-5 quarts
Old Aug 4, 2018 | 08:49 AM
kcw's Avatar
kcw
Thanks, the problem is, I'm not doing the work. I'm taking it to my transmission mechanic. I am buying the fluid and he is doing the work. So, I need to know in advance.
Old Aug 4, 2018 | 01:47 PM
ukrkoz's Avatar
ukrkoz
Word is, they are very sensitive to ATF volume. hence, word of wisdom is to replace EXACTLY same amount that was drained out.
Old Aug 4, 2018 | 01:53 PM
kcw's Avatar
kcw
Thanks, good information. I have heard that also.
Old Aug 4, 2018 | 03:01 PM
ToledoRX's Avatar
ToledoRX
I think you should double check the specs in your owner's manual regarding the amount and the type of WS fluids. Always check in the owners manual and confirm with the shop.
Old Aug 4, 2018 | 04:04 PM
tomr51's Avatar
tomr51
in Australia it is sold in 4L cans, which is the amount you need
Old Aug 4, 2018 | 05:13 PM
kcw's Avatar
kcw
The owners manual doesn't say how much to use because they don't want anyone changing the "lifetime" fluid. It does say it should be WS though.
Old Aug 4, 2018 | 05:32 PM
kcw's Avatar
kcw
Ok. Good to know. Thanks.
Old Aug 6, 2018 | 06:33 AM
nwfsnake's Avatar
nwfsnake
My 2007 RX350 takes 3.5 quarts every drain and fill, so 4 quarts should be plenty.
Old Aug 6, 2018 | 07:29 AM
kcw's Avatar
kcw
Thanks, seems to be about what everyone is saying.
Old Aug 7, 2018 | 08:52 PM
professorm's Avatar
professorm
Yea, its around 4 quarts.
bhaubold
57
Aug 22, 2016 10:03 PM
shui3000
Mar 4, 2011 07:43 AM
luh1612
Feb 24, 2011 06:49 AM
Neil64
Sep 24, 2010 09:30 AM
ThePill
Mar 24, 2008 02:04 PM
