This is how RX330 works, open the front compartment where the cup holders are located, Reach underneath where the door was and you will find a latch. Squeeze the latch and slide the console backward.
The center console (British English: centre console) in an automobile refers to the control-bearing surfaces in the center of the front of the vehicle interior. The term is applied to the area beginning in the dashboard and continuing beneath it, and often merging with the transmission tunnel which runs between the front driver's and passenger's seats of many vehicles.
You don't move CONSOLE. What is it that you are trying to move?
console slides back and forth via lever in cup holder compartment. my lever presses in but will not move console back. want to get at inside were lever connects to
Yes, on my 08 the unit between the seats does slide forward and back.
You may have an object jamming the track. Check and ad a little elbow grease. Bigger hammer.
