Torque spec for PVC
Old Nov 4, 2018 | 08:38 PM
astowell's Avatar
astowell
Default Torque spec for PVC
Hello, First post. I do more reading in forum than posting.
Edit: just realized I missed spelled PCV Valve, not sure how to change thread Heading.. I did post this late..
Finishing up replacing Valve Gaskets, Spark Plugs and PCV on my 2004 RX330. But for the life of me I can not find the Torque for the PCV. Im putting in a new one and the threads are covered in Thread seal tape. Im using Haynes Manual, even has quite a bit of info discussing its function and testing, but no torque.
I searched these forums threads and no luck. Or perhaps some one could point out I missed it.
Thanks you guys for your help.
Aaron
Old Nov 4, 2018 | 09:52 PM
astowell's Avatar
astowell
If I could be of any help to you guys with changing the Valve Gaskets, please ask questions. Ive done my Land Cruiser valve covers, so had an idea what I would be in for. One thing that seems debatable is taking off the windshield cowl, I felt it was a must and I would recommend even with spark plugs, though it could be done with out. A little extra work for less frustration is worth it...
Next month I will be doing the timing belt, water pump and any thing else in that path..
Old Nov 5, 2018 | 07:22 AM
astowell's Avatar
astowell
Searched a couple other forums and with out getting my the exact vehicle Looks to be 20lb.
I should have taken a picture of the PCV valve, it was the dirtiest I have seen, the RX is just over 200k miles.
Thanks
Aaron
GregZ1969
Apr 17, 2013 09:04 PM
jkreis
Oct 22, 2012 02:04 PM
mabmab1993
Feb 26, 2012 06:54 AM
tritron
Jun 28, 2008 08:25 PM
