2008 rx350
Old Sep 13, 2018 | 12:12 PM
Fonzie71's Avatar
Fonzie71
Default 2008 rx350
Hi
my Lexus I was driving it to take my kids to school went ti grocery store and then when I was ready to gobto work won’t start no making any noises Checked fuses and relays look good , battery bought new one , checked starter is working,
I don’t what'swrong. I’m frustrated need my car having a hardship someone can Help me please ?
Old Sep 14, 2018 | 11:05 AM
DennisMik's Avatar
DennisMik
Check the 7.5 amp fuse AM1 that is under the dash to the left of the steering column and the 30 amp AM2 fuse that is under the hood. Don't just look at the fuse, use a meter to check the continuity of them.
Put the transmission shift lever in neutral and try to start the car.
Old Sep 14, 2018 | 12:53 PM
Fonzie71's Avatar
Fonzie71
Thank you, I checked the continuity of the fuses with the meter they are fine also in neutral it didn’t work
Is there anything else I could check?
Old Sep 14, 2018 | 01:03 PM
rich001's Avatar
rich001
Did you check the voltage of your battery? Just because it's a"new" battery, doesn't mean it's good. Also if you can have someone else crank the ignition while you read the voltage at the battery, does it stay at around 11.5 to 12 volts? Another thing it could be is the alternator.
Old Sep 14, 2018 | 02:58 PM
ToledoRX's Avatar
ToledoRX
This. Did you have any accessories plugged in or aftermarket electronics installed? Even with a new battery, parasitic drain can deplete the batteries in a matter of hours.
Old Sep 14, 2018 | 04:45 PM
DennisMik's Avatar
DennisMik
Not sure if you answered this question, but do the other parts of the car have power, such as the lights and radio?
Assuming the battery has a full charge, what I would check next is the start signal that comes from the ignition switch to the starter. Connect one lead from your voltmeter (or a test light) to the trigger wire (black color) on the starter solenoid and the other lead to ground. Then turn the ignition key and see if you get 12 volts when the key is turned. If you do, the starter is bad.
If not, more troubleshooting is needed.
Old Sep 14, 2018 | 06:05 PM
Fonzie71's Avatar
Fonzie71
Yes everything has power except when I want to start the engine , actually bought today a stater relay that goes under brake fluid deposit behing fuse box. Installed new relay thought is going to start working but no.
no more options.
the problem I’m still paying the car .
Old Sep 14, 2018 | 09:09 PM
DennisMik's Avatar
DennisMik
Relays are a pretty reliable thing and 99% of the time are not the problem. As you found out.
Here is the sequence of events for the starter to start the engine:
Note that there are 2 distinctly separate things that must happen at the same time for the starter to work.
Process 1:
12 volts from the battery goes through the AM1 fuse to part A of the ignition switch.
Ignition switch contacts close when key is turned.
12 volts goes from ignition switch to the transmission park/neutral switch.
If transmission is in park or neutral, 12 volts goes to the starter relay energizing coil.
Starter relay energizes and closes internal contacts.
Process 2:
12 volts from the battery goes through the AM2 fuse to part B of the ignition switch.
12 volts goes from ignition switch to the starter relay contacts.
If starter relay is energized, 12 volts goes to the starter solenoid.
Starter solenoid energizes and closes internal contacts.
12 volts from the battery goes to the starter motor.
You can take a wild guess and replace the starter, which has a high probability of being the problem. But rather than spend $175 to $200 on a guess, do the test I mentioned earlier.
Old Sep 16, 2018 | 11:43 AM
Fonzie71's Avatar
Fonzie71
Default update
checked ignition swicth working good
checked box Relay that one is under deposit brake fluid
tested relay named under Starter and IG2.
sparks plugs won’t do the spark.
chariot
16
Jun 6, 2018 11:32 AM
llflyers
GX - 2nd Gen (2010-2023)
May 17, 2018 09:28 AM
Redheadlex
Apr 14, 2018 02:28 PM
crwys
Jun 11, 2014 06:23 PM
TwentyTen
Nov 11, 2006 03:06 PM
