i think radiator
i have a 2004 lexus rx 330 with ok get this 284,000 miles and it just started to lose cool air with the air conditioning on while driving and especially when stopped .then as soon as i start to drive the air would come back on and i noticed my temp gauge started to climb,then it would go back down and it started like the fan wanted to go on which it did then shut off like it was not runnign correct.has anyone had this issue and if so help.. could this be a thermostat prob or a fan issue ..thanks for the help in advance
Start with something simple. First check the coolant level in the radiator when the engine is cold. It may be low.
Posted by Mesquite77 in another thread:
Steps from service manual, key is to fill it at radiator filler neck on driver's side, be careful, that is the hot part...
1) Loosen upper drain plug
2) Put a clear vinyl tube on vent plug located on upper drain plug
3) Fill radiator at filler neck (not overflow tank) until vent tube full
4) Install radiator cap, tight
5) Fill reservoir overflow tank
6) Warm up engine and while it is running squeeze the inlet and outlet radiator hoses by hand several times
7) Stop engine and let it cool
8) Remove radiator cap and check for fluid level in radiator
9) If coolant inside radiator (not overflow tank) is not to full mark, repeat steps 1-8 until it is
10) Top off reservoir tank if needed.
Hi, I would lean more towards a fan issue. With the ac on the condenser need air flow while stopped as does the engine to force air through the radiator to cool it. Since you are having loss of ac cooling and engine water temp is rising while stopped, I would say it’s a fan or something in the system like a thermostat switch.
JLeffler
Apr 18, 2013 08:00 AM
bugeyes
Apr 24, 2009 04:19 PM
