View Full Version : Lighting
- Helppp
- '06+ SC430 JDM HID fogs
- HID fog light install **HELP**
- Color bulb on Color lens question
- Hid fogs on 1993 es300???
- HID FOGS...on IS, what do I need to do?!
- 05 rx 6k low beam problem (please help!)
- HID not working on '06 GS300
- Those with TSX Retrofits, please read
- HELP: Glovebox light and trunk light are out (99 SC400)
- Has anyone changed the lighting on a 2nd gen GS gauge cluster?
- Should I change to 3000K Hids in Fogs..6000K Already installed
- New to lights - 08' RX350 help
- H11 Bulbs to HID 6000K Diamond White
- any aftermarket fog lights??
- 07 GS350 with 6k's, Drivers side bulb going off!?!
- headlights & taillights
- Anyone know the intensity of OEM HIDs for IS350?
- HID Ballast
- Whats better for a retrofit??
- LED Interior Lights for ES330. Any advice appreciated!
- looking for a stock xenon look
- DRL LED installed in 2nd gen gs!!
- Exterior Lights and Condensation...
- HID foglights?
- IS350 LED, HID FOG Installed. Products from NIGEL
- Lexus Bulb sizing
- 2G GS430 - fog light question
- Do these fit 2g GS430's with OEM HID's?
- Interior to LED'S
- noob type question
- help in the CT area
- Location of flasher in a 92 sc400
- HID turns on, flickers, then goes off.
- Bad Bulbs? Or something else?
- Drl
- Bulb issue or Ballast issue?
- will chaning reverse light bulb to 7-watt LED cause bulb failure light to come on?
- 2001 ES300 XenonDepot H3 4300K Foglight Kit and randoms
- want to disable 2006 ls430 DRLs
- Foot well and door release lights
- SC300 volume/ temp knob LED DIY
- hid foglights in sc400
- Condensation damage headlights?
- who makes the brightest LED bulbs? (7440/7443 type)
- Fog light Install on 2 gen GS 300
- 2009 Murrano Hid?
- fog light selection
- 1st gen LS retro fit?
- Xeon Depot - Steve
- matching inner lights w/ headlights
- Stock Headliht bulb replacements
- 2nd Gen Gs tail lights
- HID cut off not straight
- retrofit help
- HID fogs cause sound on radio to turn off
- LED drl conversion kit
- about some ebay HIDs i purchased
- dimmer switch for LED??
- LS400 Dome/Interior light bulb help, someone please!
- DIY changing fog bulbs on 1is
- sell white foglight?
- Post Pics of your HIDS
- 2nd Gen GS Lighting Noob Question
- Are all aftermarket HID bulb plugs the same?
- 55w ballast in OEM HID
- Where to buy fog lights to match 8k headlights on 2IS?
- 2IS foglights
- HID problem?
- fog light on only
- Fog lights...Where do you aim them?
- My HeadLights Keep Burning Out! Help??? (SC300)
- Need some honest opinion on these vendors....
- Experts Chime in.... driver side Light pointed down compared to.....
- h.i.d foglight help 06 is250
- Extreme Digital HID kit install help
- HID Help.. not working
- Some Taillights working some not??? HELP
- sc300 high beam lens as driving light. HELP?
- HID problem or bad luck?
- HID Bulb questions!
- Drl"s
- SC430 HID bulbs from AACstyle? intall hard?
- please help
- Need help!
- 2GS Turning signal change
- 93 sc400 halo projector install help
- Polarg/PIAA/Luminic/Mtec/Nokya Life
- Help identify these bulbs
- 94 ls400 red/clear/red
- High/Low Beam bulbs differences in UCF20
- 05 RX 330 brake light replacement
- 2008 LX570 HID Question
- opinions? a few questions too...
- how do you get the H3 HID bulb to stay? (fog) grrr.. noobish Q
- about to buy HID from DDM
- highbeam/foglight
- How to change d2r bulbs ?
- Cutoff Line?
- Aftermarket HID kits
- RX330 DRL to LEDs?
- New HID's in SC300 with pics
- cheap hid kits
- Fog HID; what color is this?
- HID's: XD Xtreme or Oracle?
- Would this count as a "Retrofit"?
- Xeondepot VS PIAA 6000k
- 2nd GEN GS ebay hid headlights will it work on gs wit stock hids
- sc400 sidemarkers
- HID replacement bulb issues
- Hid help!!!
- 2001 gs430 hvac and radio buttons..
- HID Question
- hid foglight problem
- Help identifying bulbs for 2GS stereo/HVAC LED conversion
- How to convert from 9006 to D2R bulbs?
- GS 300 non-HID upgrade to OEM HID
- Difference between HID/non HID-equipped 2IS's?
- 6000K HID D4S - Anyone know where to find?
- Plug and Play
- hid help
- '02 Sc430 Headlight Adjustment
- Wiring reverse lights into 7 pin tow connector???
- Interior Light Question
- Lighting Replacement Upgrade
- eagle eyes from sabersport on ebay
- Installing resistor for led tails
- Foglight hid kit : /
- Quick turn on/off to signal car infront
- Is350 Hid Question
- '05 ES330 Interior Map Light
- Headlight dilema
- Relay or no relay HID
- Any experience with Piaa 8000K blubs?
- V-LED 2 Watt 194 Bulbs
- LED in DRL housing longevity
- 06 SC430 LED tail light conversion
- How to access GX470 backup lights bulb?
- yellow-er fogs?
- How can i enable DRL in UCF20
- Changing the color of the 2Gs' clock.
- Led/Hid retrofit review from V-LEDS.com in my 00 GS300 (lots of pictures)
- Legality of 3000/3500K Low Beams?
- Installed my 6000k Hid's(Pic's!!!!!!)
- For retro?
- DRL on/off mod
- LED Tails
- HID Fog light fuse blown
- '92 SC400 - tiny headlight bulb
- Few bulb questions
- Help on lighting look
- pix of hid fog light
- Turn off DRL without trun on headlight
- Bohman....dissipointment...
- Swapping Ballast?
- Buying a 2002 ES300 -- HID ?
- Headllight swap 94 ES300 to 96 ES300?
- "Starlight Headliner"
- nevermind...
- Need some help with h3 HID fogs install
- Red lighting
- Aac led dlr
- Whats wrong with this cut off?
- GS fogs
- fog light bulb install
- HID lense on sc300 with cheap hid kit??
- lighting noob looking for some guidance
- Need Input on going HID
- Parking light LED's
- D2S/D2R Adapter Shields with D4S/D4R
- Side View Mirror Bulb Cover - How to remove?
- Help: fitment on side Mirror Puddle Lights
- Blue leds
- Good places to buy led lights!!!!
- Xenon Depot Volt HID KIt: Headlights & Fog
- D4S H.I.D. Bulbs best price you've seen ?
- daylight running light upgrade?
- sc300 fog
- What's with HIDPlanet?
- Change Out Front Floor Lights to LEDS
- Deal Extreme LED's
- Xenon Depot Volt HID kit: fog light installation...
- Help with HID fog install
- TSX retrofit
- 9005 HighBeam/DRL i300 yellow bulb?
- Cut Off color
- Ehh dont know what to do with these.
- About to do retrofit...but confuse w/ the 9006 harness + ballast...
- Ebay projector headlights
- removing Computer light control from HID
- Phillips MPXL DL35
- SC owners w/6k HID's..
- hid install???
- sc300 driver's side H/L won't turn on.
- LED Conversion
- dumb @$$ hids
- 5k vs 6k
- Bulb Size for 2IS
- My auto-leveling quit working, how to diagnose?
- window switch bulbs
- LED H3 light output
- 3rd Brake Light Wiring Harness?
- Fogs ls400
- 98 LS 400 Xenon lighting assembly pics
- 98 es300 dome light relay not working
- License Light Poll
- Has anyone used this flasher before on their LED..
- Best 4 Dollers iv ever spent...
- someone stickie this- youtube video DIY of how retro fitting! VERY HELPFUL
- CCFL Dome lights & License Plate Lights
- DRL Question for GS
- Yellow H3 LEDs?
- Considering retrofit options, looking for opinions
- Has anyone tried these for SC's ORACLE DRL
- Headlights cuting off
- 1GS looking for hi-beam +12v
- Climate control unit bulb size
- legality of HIDs
- OEM Xenon Ballast
- ORACLE Xenon Flashlight> The ultimate flashlight!
- yellow 168 light bulbs?
- 04 LS 430 Fog lamp relay?
- Projectors for the retrofitting projects...
- 98-05 SportDesign radio swap?
- 98-05 GS Fog Light Question
- Long lasting fogs?
- How to wire LED's into the car (power, switch)
- need help with 9006 9005
- Replacing Headlights 99 SC300
- Valeo Projectors
- Old comparison i found: POLARG vs. LED
- What would happen if...
- I'm looking for Cliffud, HID vendor
- 94 es300 hid options
- General fog lights question
- So one of my fog lights isn't working....
- 96 ES 300 Fuel needle out - help
- Bulbs
- is250 side door lights. help !
- Light output vs. voltage
- Luxer interior LED lighting? yay/nay?
- so i just bought some ls460 projectors
- adding Xenon
- 2nd gen gs3 projector headlight retro???
- Hella blue sucks
- Where to buy genuine D4S Phillips bulbs???
- 96 ES300 LED instrument cluster - Factory dimmer still work?
- HID on LS 400 1993
- HID fog light kits plug and play?
- SC300 headlight bulbs
