Sponsored by: CARiD
HID cut off not straight
Old Feb 15, 2009 | 11:25 PM
ewu888's Avatar
ewu888
Default HID cut off not straight
so I installed ddm tuning's 35W hid kit into my es350...
last night, while I was parked @ my drive way with my HIDs on, I noticed that the cut off for the right lo beam isn't a straight cut like that of the left lo beam. Also, I noticed that the right lo beam is slightly brighter than the left. I know this may be vague, but I appreciate any advice that you guys can give. I'll also post a pic asap so hopefully it will make more sense.
Thanks!
update:
ok I know these pictures are not of the best quality, but here goes
I know this is kind of hard to tell, but the cut off is sort of like ________------ but my --- area is sort of jagged / has some humps and not a crisp cut..any ideas?
I also noticed that my right HID is way brighter and seems to be whiter than my left...as you can see in the pictures.
Last but not least, my friend who has the same kit in his mazda 3 mentioned that my beam's angle seem to be going out in a / direction instead of a | (i'll try to get more pics in later). So when I'm driving at night, my right hand side is way more illuminated than my left. He also said that his car does not experience any of the problems which I have...
So any ideas guys? Do you think its just a simple installation problem? Or I got a bad kit...? Or could it be something worse? Any help would be much appreciated!
Last edited by ewu888; Feb 17, 2009 at 05:27 PM. Reason: adding pics so forum members can better address my problem
Old Feb 16, 2009 | 03:51 AM
GS300Rich's Avatar
GS300Rich
a pic will definately help in this instance.
Old Feb 16, 2009 | 05:15 AM
T4styPh0's Avatar
T4styPh0
Yeah a pic will definately help and if you're talking about hump like cutoff make sure the bulb is seat correctly.
Old Feb 16, 2009 | 09:21 AM
emoshun's Avatar
emoshun
Old Feb 16, 2009 | 12:04 PM
ExTrEmE99's Avatar
ExTrEmE99
The HID cut off should be like this _______----------- thats so your driver side doesnt blind on coming drivers.
Old Feb 17, 2009 | 12:02 AM
GS4_Fiend's Avatar
GS4_Fiend
Thanks!
I know EXACTLY what you mean. I have the same issue I'm trying to figure out how to adjust it. Anybody got a clue? I tried adjusting the vertical but it doesn't help. My cut off is --------______
Old Feb 17, 2009 | 09:21 AM
GS300Rich's Avatar
GS300Rich
somehow this is backwards, is it because the GS headlights are reflective housing? DO you have a pic of the kit?
Old Feb 17, 2009 | 03:37 PM
vwynn's Avatar
vwynn
flip the driver side bulb around i mean give it a 180 turn n put it back in. could be the bulbs are upside down??
my bros sentra.. 1 side is brighter than the other cuz of that so we flipped it. its better now... of course thats a sentra..
Old Feb 17, 2009 | 04:23 PM
ewu888's Avatar
ewu888
the orientation of the bulb matters? I thought the bulbs only go in one way..
Old Feb 17, 2009 | 05:40 PM
iSuxeL's Avatar
iSuxeL
Yes it does matter. Double check how the bulbs are seated.
Old Feb 17, 2009 | 05:46 PM
highstakes's Avatar
highstakes
Yeah, I had same exact problem with my HID kit, cut off was real bad...so took the bulb out and changed the sides, and that fixed the problem for me.
Old Feb 17, 2009 | 05:47 PM
ewu888's Avatar
ewu888
how do i know which way is the right way? thanks!
Old Feb 17, 2009 | 06:05 PM
iSuxeL's Avatar
iSuxeL
There is pretty much only one way for it to sit. As long as its straight.
Old Feb 17, 2009 | 06:24 PM
ExTrEmE99's Avatar
ExTrEmE99
Are you using projector or regular reflector lenses? Also looks like your headlights are aimed to high, i think it should be a tad lower.
Old Feb 17, 2009 | 06:34 PM
ewu888's Avatar
ewu888
i'm using projector lenses. really? how would i go about in aiming my headlights? I looked through the manual and it seems like only the lexus with AFS (auto swiveling lights) can be adjusted..
