View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20
  1. ES250/LS400 Yellow Foglights (GEN I)
  2. Questions about replacing stock halogens with xenons! '90 LS - all help appreciated
  3. any upgrade/replacement for reading lights
  4. Stock Hid Lights On My Gs 400 Where .....
  5. matching stock hids
  6. OEM Lexus Housing
  7. 06 GS300 Projectors
  8. HID conversion
  9. low beams for lx470
  10. blacked-out lights
  11. headlight beam pattern
  12. Learning to work with LED's?
  13. Wtb:2-d2r Bulbs
  14. Fog Light Problem
  15. Help installing Lower rear Brake Light Bulb
  16. GS400 HID vs. Non-HID pictures!
  17. LED headlights
  18. Color Matching
  19. Sylvania SilverStars in size H11 (GX) not available for year
  20. Audi TT Bi Xenon lights
  21. Yellow Capsule Retro
  22. Philips Brand 4600k vs. 6500k Xtreme HID Conversion Kit
  23. SC4 Headlight Cleaning
  24. Sylvania Silverstar lights
  25. QUESTION: 1999 gs300 wants an HID kit
  26. Dying HID bulb
  27. a question about street legal aftermarket lights
  28. replacing ls400 headlight bulbs
  29. help! fuse for wedge bulbs?
  30. one side of hid does not ignite...
  31. HID replacement kit....personal preferences?
  32. hid shield
  33. High wattage ballast!!
  34. Fog light bulb recommendation
  35. Q: xenondepot.com install in SC
  36. Yellow Cap Foglights
  37. light indicator flashing...please help.
  38. banning hid? what do you think?
  39. Is this GB too good to be true????
  40. Is there such thing as a xenon-charged halogen bulb?
  41. whats needed for hid conversion on 98 ls400
  42. did i get rip off?
  43. Help finding yellow fogs for my '99 GS300
  44. When bulbs go bad
  45. Could someone post a picture of Philips 6000K replacement bulb packaging?
  46. Kudos to Steve @ XenonDepot !!!
  47. Where can I buy Philips 6000K HIDS ??
  48. Polarg M6
  49. 2gen GS Fog lights??
  50. Philips Hid Ballast mounting
  51. VERY very lo beams how do i fix
  52. Lights
  53. Evasive loose HID connection
  54. Evasive loose HID connection
  55. HID Conversion kits
  56. One piece headlights for 1st gen LS
  57. 95 es300 Hid installation
  58. tail light relay
  59. Upgrading to HID (involving Self-Leveling Motor)
  60. Colored Housings for HIDs?
  61. Colored Housings for HIDs?
  62. Strange Lighting Problem?
  63. Clearing Corners
  64. Removing moonroof / map light panel for one-of-a-kind / first ever on CL mod?
  65. 96LS warning light on cluster
  66. xenon depot 6500k hids
  67. 2004 ES330 HID Lights.
  68. New Lighting Mods Done
  69. Looking for single OEM HID bulb OR suggenstions on good place to buy 6000K online
  70. adjusting fog lights
  71. Headlight Aiming
  72. Fog light problem
  73. info on aftermarket HID SAFETY issue
  74. high-mounted stop light bulb replacement
  75. backlight light mod
  76. what about these 6000k hid bulbs
  77. led headlights.will lexus follow
  78. LS400 HID/Halogen
  79. LS430 Mirror Puddle Lamps
  80. Sylvania Silver star 9005ST
  81. What do you guys think of these?
  82. Ladies and Gents.....The GS Retro is done!!!!
  83. HID laws in Florida
  84. OEM HID auto leveling system
  85. HID question
  86. reaiming headlights on 94 ls400
  87. Projectors?? hook up?
  88. My own ECE Bosch (E46) Retro on my ES300
  89. New GS retrofit
  90. q45 projectors already installed from japan??
  91. HID High Beams
  92. retro help - removing headlight glass
  93. sc300/400 new body style fog lights
  94. Aftermarket HID vs. OEM Lexus HID's ???
  95. Need help adjusting Headlights UP w.HID
  96. ES300 bulb replacement
  97. HID bulb interchangable?
  98. Has anybody ever had Hi/Low HID kit installed (95 LS) ?
  99. 9006 to OEM HID ballast adapter?
  100. HID kit help
  101. Whoa HID Overload!!! HEhee
  102. GS430 Clear Corners
  103. Does any one have HID Fog?
  104. Holy smokes! Look at this GS retrofit!!!
  105. OEM HID Housing install to NON-HID GS
  106. M6 reverse light application
  107. GS400/GS430 HID Cut-off Line Picture!
  108. 2001 Lexus GS Aftermarket Lights
  109. anyone know how to read schematics???- (for drl mod)!!
  110. Looking for 92-96 ES300 Headlamp set
  111. Ballast mounting?
  112. Foglights on GS430
  113. Please help me on HID stuff. (for IS300)
  114. HID Swap on LS400
  115. 98 GS tail lights....help?
  116. Need verification help: Are these real E39's?
  117. HELLA Ballast compared with PHILIPS Ballast.
  118. es300 rear tail lights
  119. HID headlights
  120. relay? corroded and rusted on my aftermarket HID
  121. Yellow OEM foglights
  122. HID flickering
  123. HIDs?
  124. Fuses
  125. SC400 E39 retrofit Completed
  126. Yellow fogs
  127. what can I do?
  128. guys, need help on certain bulbs
  129. LED Replacement Bulbs
  130. I put in my hid's....bulb didnt fit, i made them fit (aha) BUT...
  131. H3 Fog Bulb Keeps Burning Out???
  132. Can you help please
  133. Help with Hids
  134. hid kit help
  135. 9006 hid on gs300
  136. 9006 HID on a GS300
  137. HID Headlights
  138. Why is it so hot
  139. 6000k burn in time?????
  140. Has anyone?
  141. anyone done the fog mod and had it work normal in auto mode???
  142. Piaa H3C
  143. GX 470 Headlight
  144. HID's in Taiwan
  145. who has sc300, with yellow fogs?
  146. Help Please!!!!
  147. Fog light mod on a gs
  148. HID cuts off sometimes... help..
  149. Healight has a foog look *Help*
  150. HID? Dumb Question
  151. Where can i buy philips 6000k dr2 bulbs
  152. Which Wedge bulbs are you guys using for your SC?
  153. Hacker in the HID forum! (hidforum.com)
  154. Which H3 Bulb will match Silverstar?
  155. HID housing power socket
  156. Small orange lights ( I dont know what they call them)
  157. Adjusting and aligning new headlights in SC
  158. Angel eyes turining differnet colors?
  159. Superflux leds?
  160. Mounting the Ballast in The 400
  161. Connecting the Ballst
  162. Reflectors or Projectors???
  163. whoever said the 9LEDs matched 6000Ks perfectly
  164. Whats The Best HID Bulb for the sc300??
  165. Which light buld should i buy?
  166. Which projector to use?
  167. xenon hid headlamps
  168. ES300 HID RetroFit Pictures/Questions
  169. Weird headlight assembly or not ?
  170. City lights, fogs, and rear lights won't turn on!
  171. Hid
  172. Has anyone bought from jus4bulbs@yahoo.com?????Hey
  173. burn in period for HIDs?
  174. Difference between D2S and D2R?
  175. Changing HID bulbs for 1998 LS400
  176. Removing the projextor
  177. Leveling Motors
  178. LED light bars for turn signals?
  179. Fog light problem... WTF!!!!
  180. Need help. I blew something!!
  181. Dash LEDs
  182. 1995 SC 300 H3 Fog replacement
  183. H4 Hi/Low kit for 95 LS. Any benefits ?
  184. Condensation Problem
  185. Piaa H3 Gt-X Vs Piaa Spark Blue
  186. Where Online
  187. searching for philips ultinon
  188. confused about this custom HID kit i bought.. help please
  189. need good hid's
  190. HID retrofit for 96 LS??
  191. xenon mods
  192. repairing 94 LS Deer Impact damage.
  193. Anyone know much about DDE Halo Lights?
  194. HID conversion
  195. Replacing the 2nd light on the main Headlight
  196. Installing Hella Supertones
  197. headlight bulbs
  198. Piaa Bulbs
  199. how do you adjust headlights
  200. ?
  201. projection headlamp conversion kits?
  202. 01 430 DRL questions
  203. Awesome HID Retrofit featuring a first gen 3000GT
  204. HID's 95 Sc300 Tutorial w/ Pics!
  205. Philips Bulb question
  206. Buying Replacement 6000k bulbs?...
  207. HID questions for ES300
  208. LED's for turn signals??
  209. HID bulb vs. HID kit
  210. Tiny light bulbs inside heated seat switch REPLACEABLE?
  211. sc300 map/dome light bulb part #s
  212. Reconnecting HeadLamps
  213. Clear Lenses
  214. same OEM HID bulb, different color?
  215. MY climate control backlight doesnt work.. wonder why?
  216. IS300 Projectors and HID retrofitted on SC300/400
  217. Headlight accents!! COOL LOOK ON YOUR CAR!
  218. how much effort to retrofit D2R bulbs into the stock GS halogen headlights
  219. 2004 Lexus LS430 LED Tail Lights
  220. JP Tail Turn Signal Testing + LED vs Incandescent Bulbs
  221. ANYONE tried replacing the LEDs in their Dash?
  222. RE: H.I.D. Installation -MANARAY HELP!!
  223. Headlights!!
  224. Bulb Out
  225. Problem: 4500K to 6000K bulbs
  226. Xenon Depot 8000K
  227. Headlights/Turn Signal
  228. UPDATED 2008 Wedge Bulb options (2GS & 3GS) comparison
  229. Daytime Running Lights Module
  230. Removing Headlights on GS300
  231. RX330 HIDs, too low?
  232. Done HID foglight on your GX??
  233. hid costs
  234. Catz HID replacement bulbs
  235. Rear Door Panel Lights Not Working?
  236. Rear Door Panel Lights Not Working?
  237. DRL and HID question
  238. Is there anyway to convert Hid bulb H4 ->9006?
  239. RX330 HID Matching
  240. hid bulb, it only take one shot to...
  241. GX's have projectors? Chance of Retro?
  242. clear fog lamps and new lights for rear spoiler
  243. projectors
  244. Hmmm..what's going on with my foglight? and more...
  245. Hmmm..what's wrong with my foglight?
  246. Hid Harness Missing *Help*
  247. 97 style wing needs brake light wiring?
  248. Puzzling Tail Lamp Problem
  249. 99 gs400 head light wiring
  250. LS400 tail light bulb housing rusted.....
Content Relevant URLs by vBSEO 3.5.2
