Sponsored by: CARiD
Help on Gen4 Ballast
Old Nov 18, 2005 | 10:15 PM
LexAnt's Avatar
LexAnt
Default Help on Gen4 Ballast
Hey guys,
I have a problem. I bought a pair of gen4 ballasts from xenondepot.com. The problem is I don't know how they're going to fit into the regular D2S plug (bulb to ballast). With the ballasts came the plug that goes into the ballast, but that's connected to a black box that switches into 2 different plugs. Xenondepot says that it's designed for a rebased bulb. But when I looked over the regular D2S plug and the connections, i just don't see how to get it to work. Any ideas? did a regular D2S plug come with gen4 ballasts? if so where can i get it?
Here's what i use now for my headlamps:
and here's what the gen4 looks like:
so as you can see in the second pic of the wire that comes with the ballast, the red tab is what goes into the rectangular plug (top plug in pic) and the two wires are for a rebased bulb, how can i get that to the regular plug as shown in the first pic?
Thanks,
Anthony
*edit for pics
Old Nov 19, 2005 | 01:28 AM
rominl's Avatar
rominl
exclusive matchup
in order to conenct to your d2s bulb, you need to have the first type. that's the original factory plug. the second one they are all "aftermarket" from what i know
Old Nov 19, 2005 | 11:34 AM
LexAnt's Avatar
LexAnt
yea that's what i figured, do you know where i can find the original plug? xenondepot also said i could modify but i don't see how i could. any ideas are welcomed
Old Nov 19, 2005 | 03:33 PM
rominl's Avatar
rominl
exclusive matchup
umm, can you just cut the current plug off the current ballast and connect it to the new ballast?
Old Nov 19, 2005 | 03:53 PM
LexAnt's Avatar
LexAnt
can't because in the second set of pics, the connector to the ballast is rectangular. and i'm thinking that extra set of wires with the black box may be the ignitor. looks like i may have to use these:
now i just gotta make sure these plugs will fit the xenondepot plugs.
Old Nov 19, 2005 | 04:18 PM
rominl's Avatar
rominl
exclusive matchup
if not you can just splice the wires and connect them directly
Ben Z
Feb 25, 2011 10:07 PM
hansford22
RX - 1st Gen (1999-2003)
16
Feb 18, 2010 11:53 PM
Dx3
Lighting
Jun 29, 2004 06:15 PM
Din
Lighting
17
Oct 22, 2003 06:58 AM
